| front bearings? | |
Lordbal Scooter Rider
Number of posts : 22 Age : 52 Location : South Carolina Points : 5030 Registration date : 2011-03-15
| Subject: front bearings? Tue Jun 05, 2012 6:50 pm | |
| I think my front bearings are going, I hear a scraping\light grinding coming from the front. Nothing stuck under the wheel well, already removed and checked. Read the topic on removing the front wheel, which is something I can do. What I want to know is can I replace the bearings myself, is it easy? And are there any tutorials and\or tips anyone can share? And, if not done immediately, about how much more ride can I get out of them, and what are the consequences if I am out on the road and they go entirely? Only been 30 miles since I noticed the noise. If not the bearings then what? Thank you |
tankyuong Silver Wing Rider
Number of posts : 475 Age : 49 Location : Missouri Points : 6292 Registration date : 2009-07-12
| Subject: Re: front bearings? Tue Jun 05, 2012 10:45 pm | |
| brake pad dragging noise? |
| Subject: Re: front bearings? Tue Jun 05, 2012 11:21 pm | |
| hmmm possibly, although they are new and installed by a honda dealer shop. |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7552 Registration date : 2010-02-03
| Subject: Re: front bearings? Wed Jun 06, 2012 12:16 am | |
| Did your dealer use OEM pads? My dealer put non OEM pads on (EBC I think) I took it back as they were dragging and was told they would seat in. Long story short they ruined my disk. I went to the parts department and was told use only Honda OEM parts so I got anew disk and OEM pads and put them on myself and all was fine. I well never have anyone else but me do them again and with OEM parts. My 2 cents |
Old Limey Silver Wing Expert
Number of posts : 921 Age : 80 Location : BOLTON LANCASHIRE ENGLAND Points : 6290 Registration date : 2010-06-09
| Subject: Re: front bearings? Wed Jun 06, 2012 12:28 pm | |
| Lordbal, how many miles has the bike done? Not advisable to run on worn bearings(if confirmed) at all. |
Number of posts : 199 Age : 63 Location : Athens Greece Points : 4837 Registration date : 2012-04-05
| Subject: Re: front bearings? Wed Jun 06, 2012 5:11 pm | |
| Try to apply some braking to the front using your right lever only.If the noise changes then your pads need some time to"seat" |
| Subject: Re: front bearings? Thu Jun 07, 2012 7:28 pm | |
| got almost 60,000 miles on it. tried the braking, no change. dont really know if they used oem or not. I would imagine because of the mileage, it is the bearings. no worries, I just ordered new ones today. should get them next week. So they are easy to install myself? |
| Subject: Re: front bearings? Fri Jun 08, 2012 1:05 pm | |
| The real expert is Bigbird, but i have changed wheel bearings a few times,take your time think twice before acting.With the wheel off(and on a bench)heat up the bearings or the metal holding them in: not red hot, just very warm, the idea is to expand the metal. With a drift or punch of some kind tap around the lower bearing through the upper one moving all around until it comes out.Then repeat from the inside on the other one. With the casing heated as before(after cleaning)use the old bearing to gently tap the new bearings into place.Try not to put any pressure on the inner bearing at any time. This is how i have fitted mine. If someone more knowledgeable than me disagrees or advises a different way of doing them then take thier advice. |
Number of posts : 2392 Age : 72 Location : Portland, UK Points : 8142 Registration date : 2009-07-26
| Subject: Re: front bearings? Fri Jun 08, 2012 3:44 pm | |
| When fitting bearings I tend to place the new bearings in the freezer for an hour or so before installing. |
| front bearings? | |
