| right angle valve stem? | |
+6Old Limey Winger61 MikeO honda_silver ucwinters moosedaisy 10 posters |
moosedaisy Scooter Rider
Number of posts : 84 Location : Charleston, SC Points : 4711 Registration date : 2012-05-22
| Subject: right angle valve stem? Thu Jun 07, 2012 8:48 pm | |
| Recently I had a set of tires changed at cycle gear. They said with the rubber mounted goldwing right angle valve stems it was their policy to replace them at every tire change. They were 6$ which seems steep. So this leaves me with two question. Do you agree that the right angle stems need to be changed and where can I buy these online for less than $6?
Dom |
ucwinters Scooter Rider
Number of posts : 43 Age : 76 Location : Universal City, TX Points : 4752 Registration date : 2012-01-07
| Subject: Re: right angle valve stem? Thu Jun 07, 2012 9:02 pm | |
| I put these on my ST1300 and pleased w/ them - should work on the Silverwing.
http://kurveygirl.com/shop/index.php?cPath=27 |
| Subject: Re: right angle valve stem? Thu Jun 07, 2012 9:06 pm | |
| Or you could try these and save some money - will probably put them on the Silverwing:
http://www.st-owners.com/forums/showthread.php?108528-19-99-Angled-Valve-Stem-Sale-is-Back!-All-colors!-Black-Blue-Red-Silver-and-Gold&highlight=ariete+valve+stem |
| Subject: Re: right angle valve stem? Fri Jun 08, 2012 12:12 am | |
| - ucwinters wrote:
- Or you could try these and save some money - will probably put them on the Silverwing:
http://www.st-owners.com/forums/showthread.php?108528-19-99-Angled-Valve-Stem-Sale-is-Back!-All-colors!-Black-Blue-Red-Silver-and-Gold&highlight=ariete+valve+stem I have the Ariete valve stems. I do not believe I will need to replace them. |
| Subject: Re: right angle valve stem? Fri Jun 08, 2012 6:00 am | |
| The right-angled valve on the rear of my bike split; I'd had a new tyre and very soon after it started losing air at an alarming rate. I was in the UK and managed to find a man at lunchtime on the Saturday who said he'd have a look and discovered the split where valve meets rim. I now have a stubby, ordinary valve in but he gave me a screw-on right-angled adaptor in case I need it.
Great chap - hadn't ever taken the rear wheel off a maxi before but set to with efficiency....and only charged me £20 ! In the meantime, his wife provided tea and coffee for me and the rest of the group I was with.
www.jjmotorcycles.co.uk |
Winger61 Silver Wing Rider
Number of posts : 452 Age : 75 Location : Louth, Lincolnshire, UK Points : 5633 Registration date : 2010-10-15
| Subject: Re: right angle valve stem? Fri Jun 08, 2012 6:17 pm | |
| That's at Mavis Enderby, only 20 miles from where I live!
There is a story, true or otherwise, of a direction sign near there, to the village of Mavis Enderby, and the neighbouring village of Old Bolingbroke.
The sign read 'To Old Bolingbroke and Mavis Enderby', to which someone had added 'The gift of a son'!
| Subject: Re: right angle valve stem? Sat Jun 09, 2012 4:34 am | |
| Highly likely - English wit rules! |
Old Limey Silver Wing Expert
| Subject: Re: right angle valve stem? Sat Jun 09, 2012 12:26 pm | |
| The one thing that really annoyed me was trying to check my tyre pressure on the rear tyre with that right angled valve. I do my pressures weekly, and it was really getting to me , so, when i changed tyres i had an ordinary valve fitted and each time i change tyres i have new valves. I still have to lie on the floor to check the tyres but, for me,it is easier with the straight valve. |
Dimond Silver Wing Expert
| Subject: Re: right angle valve stem? Sun Jun 24, 2012 11:56 pm | |
| - ucwinters wrote:
- I put these on my ST1300 and pleased w/ them - should work on the Silverwing.
http://kurveygirl.com/shop/index.php?cPath=27 +1 BigTime! Cycle Gear is right - replace them every time OR do the Kurvey Girl thing! I love my right-angled METAL valve stems - but you will need to grind a bit away on the rear so that they fit. You will likely NEVER need to replace the metal valve stems.
Hammy Touring Scooter Rider
Number of posts : 362 Age : 47 Location : Philadelphia, PA Points : 5686 Registration date : 2010-05-22
| Subject: Re: right angle valve stem? Mon Jun 25, 2012 12:24 am | |
| What size Ariete fits our wheels? |
| Subject: Re: right angle valve stem? Mon Jun 25, 2012 1:30 am | |
| Subject: Re: right angle valve stem? Mon Jun 25, 2012 6:58 am | |
| First if safety is of any value to you, replace valve stem with standard short rubber ones. Right angle llike Gold Wing are designed to be tied down---don't work that way on silver wing--think of little wheel going around at 80 mph.
Good tire procedure is change valve stem every tire change.
The lay down procedure to inflate or check tire good exercise.
Honda put some thought into what works for SilverWing and tackle box techs usually cannot do better. High speed deflations are not fun. |
bikerboy Silver Wing Rider
Number of posts : 405 Age : 81 Location : Leyland England Points : 5370 Registration date : 2011-05-12
| Subject: Re: right angle valve stem? Mon Jun 25, 2012 8:38 am | |
| The Ariete stem fits fine but we had to remove the little tab on the rim that holds the bracket for the OE rubber stem. Checking the pressures is still a PITA (I also lie on the floor to make this easier) but at least the metal stem doesn't move when you press against it. |
| Subject: Re: right angle valve stem? Mon Jun 25, 2012 8:40 am | |
| I use a Slime air compressor that screws onto the valve (instead of that silly clamp thing almost all other air compressors use), and the air compressor also stops at the pressure I want. Even so, it's definitely a PITA to check pressure on the rear. |
