Back to the charging system I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Back to the charging system I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Back to the charging system I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Back to the charging system I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Back to the charging system I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Back to the charging system I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Back to the charging system I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Back to the charging system I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Back to the charging system I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Back to the charging system I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
2 posters
Richooker
Number of posts : 8
Back to the charging system Empty
PostSubject: Back to the charging system   Back to the charging system I_icon_minitimeThu Jun 14, 2012 10:57 pm
Hey guys, Richooker again. Finally able to get back to work on my SWing. I had some surgery in April that took a bit longer to recover from than I expected. Anyhow my 2003 600 has a battery that holds voltage after trickle charging. When running on centerstand the voltage drops to the specs that I was advised on in April. The voltage doesn't increase at all at 4K rpm. I've indentified the rectifier on under left panel in the area of the battery. There doesn't appear to be any type of visual problem in the area. I certainly would like some suggestions from you guys. I've been running for basics at the grocery but need to get this up and do some serious touring withmy new bike. Please give me some of that experience you all have built up.
Rick
Richooker
Number of posts : 8
PostSubject: Re: Back to the charging system   Back to the charging system I_icon_minitimeSun Jul 01, 2012 1:14 pm
Well I am in possesion of a new meter and getting ready to remove the front cover for inspection and testing of the rectifier/regulator. I couldn't imagine the rectifier not getting air flow as I thought in previous post. After inspection I'll check resistance in charging coil (alternator side) and the charging side of the rectifier/regulator. Then move to continuity testing on the rectifier/regulator. Should narrow it down then.
Newby,
Richooker
micbusathens
micbusathens
Number of posts : 199
PostSubject: Re: Back to the charging system   Back to the charging system I_icon_minitimeSun Jul 01, 2012 1:38 pm
Don't know....I've change stator coil for second time in a year to my 07
» Wing not charging
» Charging System Malfunction?
» Charging system observation
» Back After 3 Years - Back Wheel Brake Seized Solid
» Low charging
