Charging system observation I_icon_minitimeby xwelder Today at 9:06 am
Charging system observation I_icon_minitimeby GHM-PM Today at 8:06 am
Charging system observation I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Charging system observation I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Charging system observation I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Charging system observation I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Charging system observation I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Charging system observation I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Charging system observation I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Charging system observation I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
2 posters
Hiyo
Hiyo
Number of posts : 94
Registration date : 2019-10-22
Charging system observation Empty
PostSubject: Charging system observation   Charging system observation I_icon_minitimeThu Oct 24, 2019 12:59 pm
Might as well say it. . Motorcycle charging systems give a certain amount of watts. Mostly designed to charge the battery and run the lighting and motor essentials. There isn't usually much left over for extras wired in. Some touring bikes have giant alternators and put out lots of extra watts, so room for accessories. I don't think our scoots have a very big wattage output. It is probably maybe 300-400. Add up all the light wattages the rest charges the battery. You could figure it out and know for sure. Pretty sure I would want heated something or other in Canada or Ak. I have commuted in 25 drg. F also hit 40's on a long trip with no electronic gear. Bbbbbbr
Number of posts : 1384
PostSubject: Re: Charging system observation   Charging system observation I_icon_minitimeFri Oct 25, 2019 7:37 pm
SW rated at 441 watts as per service manual at 5k rpm's. I often use a heated vest or jacket liner on colder mornings or all day if needed. Jacket liner pulls about as much current as the high beam 5 amps or 60 watts. SW can run heater gear and not cause a battery discharge .
Most heated gear uses at temp. controller that pulses the voltage so it's not a constant draw. No problems so far but don't use it that often. Volt meter never drops below 13.8 with jacket liner on high.
» Charging system
» Charging System Malfunction?
» Back to the charging system
» An Observation
» Silly observation...
