Hello fitted new givi plate today thought i would share some pics
Here is all the kit (plate/bracket/rubber spacer and nuts and bolts)
First took off the grabrail tray thing 4 obvious bolts
Then took off the platic under cover either socket or
crosshead screwdriver will do this
The clever peeps at honda gave 4 guide holes that need to be drilled
I used 8mm metal drill bit
Place rubber spacers with fat bit facing in and at the rear
Then positioned bracket in line withe drilled holes
on top of rubber and did up the 4 larger nuts and bolts
Then put the top plate on using the smaller 4 nuts and bolts
(top tip)do the ones towards the front first they are the harder to get to
Put back the plastic cover
Re bolted back to the scoot
