| Givi Monolock Top Case Mounting | |
hankster Maxi-Scooter Rider
Number of posts : 140 Age : 72 Location : Fort Myers FL Points : 3462 Registration date : 2015-11-14
| Subject: Givi Monolock Top Case Mounting Sat Nov 14, 2015 8:08 pm | |
| I have a Givi B47NTML Monolock top case on my current scoot that I want to move over to the SWing. Has anyone used the universal mount that comes with the Monolock case instead of the mount designed for the SWing? If so, how well did that work out? |
The Bern Silver Wing Expert
| Subject: Re: Givi Monolock Top Case Mounting Sun Nov 15, 2015 5:25 am | |
| Yep, works fine, take the spoiler off, turn it upside down remove the coverplate, there are 4 obvious cast lugs with indents drill them through, offer up the mounting plate mark & drill through, bolt on & reverse the process |
| Subject: Re: Givi Monolock Top Case Mounting Sun Nov 15, 2015 8:33 am | |
Jinglebob Super Scooter Rider
Number of posts : 297 Location : Sacramento Points : 6016 Registration date : 2009-07-18
| Subject: Re: Givi Monolock Top Case Mounting Wed Jul 26, 2017 6:34 pm | |
| What did you use to drill the holes? I tried new Cobalt hardened steel bits and can't get through the spoiler metal. |
dekare Maxi-Scooter Rider
Number of posts : 125 Location : MN Points : 3159 Registration date : 2016-08-09
| Subject: Re: Givi Monolock Top Case Mounting Thu Jul 27, 2017 7:50 am | |
| - Jinglebob wrote:
- What did you use to drill the holes? I tried new Cobalt hardened steel bits and can't get through the spoiler metal.
Jeez. Drill bit turning in the right direction, and the drill not in reverse? |
| Subject: Re: Givi Monolock Top Case Mounting Thu Jul 27, 2017 10:42 am | |
| Boy, do I feel stupid. Truth is, I bought a cheap drill and didn't even think it was reversible until you motivated me to go check. Problem solved. Thank you. |
| Subject: Re: Givi Monolock Top Case Mounting Thu Jul 27, 2017 1:37 pm | |
steve_h80 Silver Wing Guru
| Subject: Re: Givi Monolock Top Case Mounting Thu Jul 27, 2017 2:42 pm | |
| Well confessed Jinglebob, I'd have just crept of to a corner and never discussed the matter again :-) |
