No fuel pressure I_icon_minitimeby zrx212 Yesterday at 4:40 pm
No fuel pressure I_icon_minitimeby Meldrew Yesterday at 4:37 pm
No fuel pressure I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
No fuel pressure I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
No fuel pressure I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
No fuel pressure I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
No fuel pressure I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
No fuel pressure I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
No fuel pressure I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
No fuel pressure I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 No fuel pressure
4 posters
crankshaft
Number of posts : 3
Registration date : 2012-09-28
No fuel pressure Empty
PostSubject: No fuel pressure   No fuel pressure I_icon_minitimeFri Sep 28, 2012 2:09 pm
Has anybody removed the fuel tank from sw 600 , I have no fuel pressure and traced problem to fuel pump , does tank drop out the bottom and how does the inside of fairing come off to gain access to fuel tank , manual on order but can't wait 1.5 weeks for manual to arrive. has anybody tried this. help!!!
Number of posts : 2778
PostSubject: Re: No fuel pressure   No fuel pressure I_icon_minitimeFri Sep 28, 2012 2:51 pm
Hello,
What year is your Silverwing?
If it's an older SWing good chances it's your FPR (fuel Pressure Regulator) gone bad.
crankshaft
Number of posts : 3
PostSubject: Re: No fuel pressure   No fuel pressure I_icon_minitimeFri Sep 28, 2012 3:14 pm
Hi Dennis B , Thanks for your reply , My Silverwing is a 2003 , I have voltage at fuel pump and pulled high pressure line at fuel rail , no fuel pressure and no fuel pump sound. So my question is how to remove fuel tank, and how do you get off the inner panels of fairing. Again thanks for any advise.
PostSubject: Re: No fuel pressure   No fuel pressure I_icon_minitimeFri Sep 28, 2012 3:28 pm
1. Place bike on centerstand.
2. Remove seat. (remove terminals from battery)
3. Remove both black foot mats.
4. Remove top frame/engin cover.
5. Remove both passenger foot pegs.
6. Remove the big center cover.
7. Remove wire and hoses from pump.
8. Un-bolt Gas pump and filter unit. Remove from tank. (good idea to replace filter if you have it out of tank).
http://www.powersportsplus.com/parts/search/Honda/Scooter/2006/FSC600D+AC/FUEL+TANK/parts.html
That was easy.... cheers
Reassemble in reverse order.
PostSubject: Re: No fuel pressure   No fuel pressure I_icon_minitimeFri Sep 28, 2012 3:38 pm
That sounds odd. Fuel Pumps aren't known to fail, but if yours has you don't need to pull the whole tank. If you do need to remove the tank you pretty much have to remove most of the front body panels along with the tunnel cover to access the mount bolts and then the tank drops down out of the frame.
Meanwhile, you can remove the 6 or 8 bolts, two hoses and wiring from the the fuel pump assembly which is mounted in the top of the fuel tank. You've already removed the seat & under seat cover to access that high pressure hose anyway. Remove that high pressure hose where it attached to the tank as well as the return line (at the opposite end of the fuel rail). After removing all that stuff the fuel pump/filter/sending unit should easily be removed from the tank. It may take a bit of 'encouragement' though. Be cautious of that hefty gasket though.
Don't forget to drain the tank before removing the pump assembly.
Good luck, and please let us know how you make out.
crankshaft
Number of posts : 3
PostSubject: Re: No fuel pressure   No fuel pressure I_icon_minitimeFri Sep 28, 2012 4:34 pm
Hey thanks Dennis B and Cosmic-jumper, Its good to know I don't have to pull fuel tank, just looking at it, I didn't see how it would come out, going to start digging in to it this weekend. Will let you know how it turns out. Again many thanks to you guys for your help.
PostSubject: Re: No fuel pressure   No fuel pressure I_icon_minitimeFri Sep 28, 2012 5:28 pm
Well...we try to help....i was just wondering, did you check the fuse that powers the pump?
micbusathens
micbusathens
Number of posts : 199
PostSubject: Re: No fuel pressure   No fuel pressure I_icon_minitimeFri Sep 28, 2012 5:36 pm
At my 08 you can hear for three seconds the fuel pump raising pressure every time you turn on main switch (with kill switch at on position)...if that helps
No fuel pressure
» cranking but not starting!! Help!!
» Fuel Pressure Regulator
» Fuel pressure regulator
» Fuel Pressure Regulator - does it need changing?
