| Intermittent failure of Head Light! | |
+4J.R. model28a Waspie steveonfarm 8 posters |
Number of posts : 117 Age : 65 Location : Vienna (Austria) Points : 5019 Registration date : 2011-08-14
| Subject: Intermittent failure of Head Light! Mon Nov 05, 2012 2:32 pm | |
| Dear Silverwingers, I have another conundrum to put to you all What I thought was a blown headlamp bulb (dipped beam), turns out to be some kind of electrical fault! Occasionally when I start my bike, and sometimes even when riding, my headlamp (dipped beam) fails to work. When this happens, I have made the following observations:- The 2 small sidelights stay on The trigger switch for the full beam bulb works but the main trip switch does not!! In fact my friend watching from an upstairs window says that both headlamp bulbs come on when I apply the trigger switch!!! But he may have been mistaken ........ All other lights are operating correctly Any suggestions? SteVe |
Number of posts : 2392 Age : 72 Location : Portland, UK Points : 8142 Registration date : 2009-07-26
| Subject: Re: Intermittent failure of Head Light! Mon Nov 05, 2012 3:46 pm | |
| The obvious place to look is the light switch. Now I will bow to more superior knowledge. |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7552 Registration date : 2010-02-03
| Subject: Re: Intermittent failure of Head Light! Mon Nov 05, 2012 5:50 pm | |
| Try cleaning the contacts in the starter switch. |
J.R. Scooter Rider
Number of posts : 32 Age : 69 Location : Watertown, Minnesota Points : 5596 Registration date : 2009-08-25
| Subject: Re: Intermittent failure of Head Light! Mon Nov 05, 2012 5:55 pm | |
| Same experience with mine. Final result was that the bulb was not making a connection in the socket. Vibration over time seemed to be the problem. When I went to replace it the bulb came on. Hope this helps. J.R.
Winger61 Silver Wing Rider
Number of posts : 452 Age : 75 Location : Louth, Lincolnshire, UK Points : 5628 Registration date : 2010-10-15
| Subject: Re: Intermittent failure of Head Light! Tue Nov 06, 2012 1:25 am | |
| My local (first class) spannerman recommended spraying WD40 over the switches, and then working them on and off a few times. Apparently it cleans off the contacts without the need for taking things apart. Quick,cheap fix, worked for me! Just remember to wipe eveything clean afterwards!
Graham |
Number of posts : 4217 Location : York, North Yorkshire, England UK Points : 9439 Registration date : 2010-11-16
| Subject: Re: Intermittent failure of Head Light! Tue Nov 06, 2012 10:34 am | |
| I'd go with the spray and wiggle routine before fiddling around with the bulb. Fiddling around in the confined space where the headlight bulbs are needs both patience and dexterity and a small torch and mirror are useful to have. I've found taking the rubber dust cover off rather fiddly if it's not been removed before, and spraying it with rubber lubricant makes it a lot easier to put back on and remove in the future. |
Old Limey Silver Wing Expert
Number of posts : 921 Age : 80 Location : BOLTON LANCASHIRE ENGLAND Points : 6290 Registration date : 2010-06-09
| Subject: Re: Intermittent failure of Head Light! Tue Nov 06, 2012 12:36 pm | |
| Last year coming home in the dark my headlight bulb suddenly went out, the two sidelights were still on but no dipped beam, main beam still worked. in my case it was my recently fitted handle bar mitts which were somehow interfering with the trigger switch, which seemed to cut out the main dip beam. I would be looking at the trigger switch first if i were you. |
| Subject: Re: Intermittent failure of Head Light! Tue Nov 06, 2012 12:40 pm | |
| Thank you so much everybody!! Especially, Old Limey in Bolton who I think has nailed my problem! I too use those excellent Italian muffs and my trigger switch has become sticky to the point where it almost stays on!! Now where's that old can of WD40 ...................................... SteVe |
RArch Silver Wing Expert
Number of posts : 613 Age : 57 Location : West London, UK Points : 5408 Registration date : 2011-11-07
| Subject: Re: Intermittent failure of Head Light! Tue Nov 06, 2012 4:44 pm | |
| Nice, it sounds like an easy fix and thanks for letting us know.
Would it be worth spraying the switchgear once a year as a bit of preventative maintenance?
| Subject: Re: Intermittent failure of Head Light! Tue Nov 06, 2012 5:06 pm | |
| WD40, liquid maintenance in a tin. |
| Subject: Re: Intermittent failure of Head Light! Wed Nov 07, 2012 12:24 pm | |
| Thats what this site is all about. Helping each other, if possible from our experiances, i'm glad my contribution helped someone, just as Bigbird, Jeff and many others have helped me in the past. |
| Subject: Re: Intermittent failure of Head Light! Wed Nov 07, 2012 4:19 pm | |
| - RArch wrote:
- Nice, it sounds like an easy fix and thanks for letting us know.
Can't see why not, certainly wouldn't do any harm. |
| Subject: Re: Intermittent failure of Head Light! Sun Nov 11, 2012 5:58 am | |
| Quick update: A quick squirt of WD40 in and around the switching gear on the left handlebar seems to have completely cured this problem Thanks guys! SteVe |
| Subject: Re: Intermittent failure of Head Light! Sun Nov 11, 2012 9:55 am | |
| - steveonfarm wrote:
- Quick update: A quick squirt of WD40 in and around the switching gear on the left handlebar seems to have completely cured this problem
Thanks guys!
SteVe I refer to my answer above!!!! 'maintenance in a tin' |
