| Drive Belt - is there any preventative maintenance? | |
pjas1969 Scooter Rider
Number of posts : 31 Age : 55 Location : Dreghorn Points : 4308 Registration date : 2013-03-12
| Subject: Drive Belt - is there any preventative maintenance? Tue Mar 19, 2013 2:30 pm | |
| Hi there.
Still conducting my fact-finding and since 3 out of the 4 bikes I owned had a chain-drive (the other one being shaft-driven), I'm used to the regular maintenance such chains require; re-tensioning, cleaning & oiling/greasing.
Do the drive belts need any such cleaning?
Will the service-life be reduced if cleaning doesn't occur?
I'm not expecting to encounter desert conditions (not in Scotland!), but I was thinking more about road grime & salt.
I'll appreciate all your thoughts/comments & experience as always.
Thank you in advance,
Paul |
JeffR_ Site Admin
Number of posts : 1103 Age : 65 Location : Bay Area, Ca Points : 9075 Registration date : 2010-05-12
| Subject: Re: Drive Belt - is there any preventative maintenance? Tue Mar 19, 2013 3:02 pm | |
| Paul,
I have never cleaned my belt ever and have had no problems. I change my belt every 16,000 miles so that may be why (it is what Honda recommends too). You can take off the covers and measure it from time to time but I have never done that either. Some don't change their belt until they are well over 20,000 miles but I just don't take that chance myself. If it breaks then you are pushing it. |
| Subject: Re: Drive Belt - is there any preventative maintenance? Tue Mar 19, 2013 3:05 pm | |
| You do know that maxi scooter drive belts are fully enclosed and maintenance free, and are not the open drive belts like the ones used on Harley Davidson motorcycles. Removing the rear wheel doesn't affect the belt either. |
| Subject: Re: Drive Belt - is there any preventative maintenance? Tue Mar 19, 2013 3:17 pm | |
| Regular use is the best maintenance you can do on the Silverwing, There you now have a built in excuse to go for a ride.
Cheers, |
| Subject: Re: Drive Belt - is there any preventative maintenance? Tue Mar 19, 2013 4:19 pm | |
| Hi there,
Many thanks to you all.
Paul |
eddy Maxi-Scooter Rider
Number of posts : 187 Age : 73 Location : Europe Flanders. Points : 5679 Registration date : 2009-11-27
| Subject: Re: Drive Belt - is there any preventative maintenance? Wed Mar 20, 2013 4:53 am | |
| The belt has two main enemies.
- Worn inner sides of the pulleys. - Heat
So, when the drive box is open during the normal maintenance interval...
Check the pulleys and look for black dust in the box. ( a small amount of dust is ok )
Check and clean air filter in the cover of the drive box. ( Cooling )
Eddy |
| Subject: Re: Drive Belt - is there any preventative maintenance? Mon Mar 25, 2013 1:05 pm | |
cvoeb Scooter Rider
Number of posts : 7 Location : USA Points : 4365 Registration date : 2012-12-21
| Subject: Re: Drive Belt - is there any preventative maintenance? Mon Apr 08, 2013 10:16 am | |
| My belt just broke while driving on the freeway. I only have 7k miles, but its an 05 so maybe its just old. I have been noticing some green fuzz coming from that area, should have checked it ( haven't had a chance to make the leroy tool yet). will be changing the belt out today or tomrw. |
JeffR_ Site Admin
| Subject: Re: Drive Belt - is there any preventative maintenance? Mon Apr 08, 2013 12:13 pm | |
| There was just a post about someone buying an older SWing and asked if they should change the oil and belt, I think. I change the belt sooner than I probably need to but it is for my peace of mind. I never go over the 16,000 mile time frame and change it sooner really.
I know some here like to chance it but I hate to push anything. I think the belt is like the tires where it can weaken just with age. I could be wrong but if others have an older SWing it doesn't cost much to change oil and belts. sorry it happened to you but at least now you know you will have a new belt. |
| Subject: Re: Drive Belt - is there any preventative maintenance? Mon Apr 08, 2013 9:34 pm | |
| All useful info.
Thank you,
Paul |
