Steering stem I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Steering stem I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Steering stem I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Steering stem I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Steering stem I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Steering stem I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Steering stem I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Steering stem I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Steering stem I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Steering stem I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 Steering stem
3 posters
tinman
Number of posts : 1298
Steering stem Empty
PostSubject: Steering stem   Steering stem I_icon_minitimeMon Apr 08, 2013 9:27 am
I had my front wheel of the ground the other day and notice the wheel kept going to the left . My Service manual Indicates a loose bearing . I tried to buy a adjustable pin spanner and could not find one at the auto supply store .Has anyone tried to use the rear shock pin spanner in the tool kit for a fit on the bearing nut. I would hate to take the front cover of ,if I don't have a pin spanner to do the job.
Steering stem Empty
PostSubject: Re: Steering stem   Steering stem I_icon_minitimeMon Apr 08, 2013 12:07 pm
There are several posts on-line for DIY steering stem tools. Many of which use cut down larger diameter deep sockets or sections of galvanized steel plumbing pipe.
Time to hit the Flea Markets
That said, you might check with Honda for their tool price. Sometimes, "sometimes", their Special Tool prices are quite reasonable.
NWSSC
NWSSC
Number of posts : 418
Steering stem Empty
PostSubject: Re: Steering stem   Steering stem I_icon_minitimeMon Apr 08, 2013 12:19 pm
I do not think this is a problem unless you have some other symptom, for instance generally loose searing. The brake caliper is on the left side and may be enough to pull the steering to the left when the front wheel is off the ground.The stem bearings (on the S/W) are ball bearings and do not require a heavy preload. A spring scale is used for this adjustment.
tinman
Steering stem Empty
PostSubject: Re: Steering stem   Steering stem I_icon_minitimeMon Apr 08, 2013 5:44 pm
I manage to tighten the bearing using The shock pin spanner ,and using a fish scale on the fork nut for adjusting the weight pressure .I repaired a broken tab that fell to the ground when i removed the screw .I will finish putting everything back together tomorrow.
Steering stem
» Steering stem nut.
» Steering Stem Socket
» Steering stem nut tool
» Valve stem on back wheel
» Steering stem top nut octagonal socket
