| Help..Throttle not closing | |
cvoeb Scooter Rider
Number of posts : 7 Location : USA Points : 4365 Registration date : 2012-12-21
| Subject: Help..Throttle not closing Tue Apr 16, 2013 10:04 am | |
| I just did a belt change and now my throttle takes a long time to spin back freely on its own, I have to manually close it. Before I take it apart again any one have any suggestions. This all happened after my belt broke while riding.. Bike only has 7k miles but is an 05. |
jdeereanton Silver Wing Guru
| Subject: Re: Help..Throttle not closing Tue Apr 16, 2013 1:02 pm | |
| With little information -
Did you have the bike transported to a location after the belt broke? If so, did that transport involve a tie-down strap on the throttle grip?
If the answer to both questions is yes, then look to see if the rubber grip on the throttle is 'binding' against the bar end weight. if it is, simply slide it away from the bar end weight and see how that works. |
cvoeb Scooter Rider
| Subject: Re: Help..Throttle not closing Tue Apr 16, 2013 4:16 pm | |
| Yes to both and thanks that worked.. Saved me a lot of work and headache. But it was stuck on the inner side not the side of the bar weight. Strapping the bike must of caused the grip to move to the left some. If I peel it out just a little it spins freely. Now I just need to figure a way to push the grip to the right some. |
bikerboy Silver Wing Rider
Number of posts : 405 Age : 81 Location : Leyland England Points : 5371 Registration date : 2011-05-12
| Subject: Re: Help..Throttle not closing Tue Apr 16, 2013 5:24 pm | |
| A blast of compressed air can help if you have the facility. |
| Subject: Re: Help..Throttle not closing Wed Apr 17, 2013 8:17 am | |
| - cvoeb wrote:
- Yes to both and thanks that worked.. Saved me a lot of work and headache. But it was stuck on the inner side not the side of the bar weight. Strapping the bike must of caused the grip to move to the left some. If I peel it out just a little it spins freely. Now I just need to figure a way to push the grip to the right some.
Good news, and you're welcome. I've seen it go that way as well. It can be time consuming to move the grip, just stay with it. Best wishes. |
Number of posts : 330 Age : 51 Location : Atlanta, GA Points : 5355 Registration date : 2011-05-13
| Subject: Re: Help..Throttle not closing Wed Apr 17, 2013 4:12 pm | |
| try windex- it's slippery when wet but won't leave residue.
Jesse in Atlanta |
| Subject: Re: Help..Throttle not closing Wed Apr 17, 2013 7:24 pm | |
| I think you are now trying to move rubber hand grip? Long thin screwdrive, lube with WD 40---slide screwdriver down on throttle barrel, squirt---grip will come off---then wash grip in dish soap, clean throttle barrel with gas or similar-----to hold grip on I use rubber cement or there is even grip cement out there, some people use hair spray, gas has worked.
Idea get grip on so it doesn't slip----requires quick work to slide on and position where you want
Next time bike to be hauled use upper fork tubes---"Quick Ties" help. I would use four point tie down, and parking brake as there is no"in gear". |
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4810 Registration date : 2012-06-15
| Subject: Re: Help..Throttle not closing Wed Apr 17, 2013 10:37 pm | |
| Does anyone have a picture of a bike tied by the fork tubes, as John suggests? Sounds like a great idea, but I have never seen it done that way. |
derekg Scooter Rider
Number of posts : 79 Age : 77 Location : Stirling Scotland Points : 5293 Registration date : 2010-09-02
| Subject: Re: Help..Throttle not closing Sun Jul 28, 2013 9:26 am | |
| jdeereanton...thanks very much..Just had this problem of the throttle not returning and sticking on...didnt know what to do...until I read your post. I had recently transported my Scooter by trailer tieing the front end with a canyon dancer.(where did they get that name from?) Fixed problem in 5 minutes... A simple solution to a simple problem...but only simple when you know! thanks again. |
