Coocase brake/running light kit. I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Coocase brake/running light kit. I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Coocase brake/running light kit. I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Coocase brake/running light kit. I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Coocase brake/running light kit. I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Coocase brake/running light kit. I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Coocase brake/running light kit. I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Coocase brake/running light kit. I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Coocase brake/running light kit. I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Coocase brake/running light kit. I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
4 posters
Dom
Dom
Number of posts : 34
Registration date : 2013-04-23
Coocase brake/running light kit. Empty
PostSubject: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 9:26 am
Hi Dennis,
Am I correct in assuming that my 2010 Swing has CANbus set up for the back lights. If so, the Coocase system requires red and black leads to battery and yellow to the power
source for the lights. Will you kit handle that? If it does, I would like to have one.
Dom Morda
Number of posts : 2778
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 9:56 am
Hi Dom,
Sounds like your information on lead wire hook-up is lacking. Can you be a bit specific on lead wire color and use.
Example:
Red wire: +12v none switched (+battery, Not through perfect connector)
Black wire: Chassis ground (-battery, not through perfect connector)
Yellow wire: What????
Thank You sunny
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 10:17 am
If CANbus wiring.
jmaslak
Number of posts : 252
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 11:29 am
The Silver Wing's lights are not CANbus. It uses standard wiring - ground, running lights, brake light, left blinker, right blinker are all separate wires.
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 12:59 pm
Ok. Do you know the respective of the brake light and the running light.
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 1:03 pm
I meant to say respective colors of the lights.
jmaslak
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 1:52 pm
I can't remember the colors, but green is ground. You should be able to use a volt meter or the schematic in the service manual to figure out which other wires is which. For instance, turn on your scooter and measure voltage between the green wire and each of the other four wires in the connector towards the front of the bike behind the door on the left side of the back of the seat pan - the one with voltage is the running light. Then do the same while holding the brake light (use a zip tie on it). Then if needed you can turn on the turn signals and find those.
Of course Dennis's Perfect Connector is easier. He labels everything for you - and they are very high quality parts, well worth the money.
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 6:21 pm
Dennis, I finally figured out the requirements to hook up the Coocase light kit. Your Perfect Connector would make the job a snap. I would like to buy
one. Can you make the wires 12inches.
Thanks,
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 7:52 pm
Hi Dom,
It's been cold, rainy, and windy here my part of Oklahoma for the last three days. I need to get back out in the shop and get some things done.
Do you have turn signals on your Coocase or just running lights and brake lights?
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 8:04 pm
Hi Dennis
It's hot and sunny here in Florida and the humidity is starting to kick in.
Don't mean to rub it in. Smile
Coocase has only brake and running lights. I need a harness with blue green and yellow connecting wires.
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 8:58 pm
Hi Dom,
Please fill in the "?" with the words that go with the color. either Brake, Ground, or Running lights. I need to know.
Blue: ?
Green: ?
Yellow: ?
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 10:30 pm
Actually, only the blue(brake) and green(running) connect into the bike's wiring. The yellow is the ground which connects into Coocase plate. I will email you a copy of the instruction sheet where the wiring diagram is illustrated.
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat Apr 27, 2013 11:05 pm
green and blue (12" leads)...you got it. $27.00 with $3.50 shipping. sunny
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSun Apr 28, 2013 2:01 am
One of those wires goes to a constant 12V source to power the remote control receiver if you have the remote fob for your box. On mine, the 37V box, you have to have a lead to the battery for the alarm and remote opening receiver. If you don't have the remote system then there's no need for a constant unswitched 12V source.
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat May 04, 2013 5:06 pm
Hi Dennis, wondering if you shipped the brake, running light kit.
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat May 04, 2013 5:34 pm
Hi Dom,
I never shipped it to you because you never did pay for it. You did pay for the GPS mount on the 4/25/13. Do you still want the connector?
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat May 04, 2013 6:07 pm
Dennis, paid $30.50 through PayPal on 4/27. Checked, it is marked as unclaimed. Please proceed to claim it. Let me know if there is a problem.
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat May 04, 2013 6:09 pm
By the way, got the mount. Great product, already put to good use.
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat May 04, 2013 6:33 pm
Dom,
what "unclaimed" means is: I did not receive it because you got my PayPal account wrong.
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat May 04, 2013 6:43 pm
Were you able to retrieve it?
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat May 04, 2013 6:52 pm
I see the mistake. I cancelled payment and will reissue correctly.
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat May 04, 2013 7:17 pm
Hi Dom,
Thanks, PayPal received. I'll get in the mail on Monday morning. sunny
Dom
Dom
PostSubject: Re: Coocase brake/running light kit.   Coocase brake/running light kit. I_icon_minitimeSat May 04, 2013 7:24 pm
Thanks Dennis, sorry for the screw up..
» Light on only with running engine
» Turn signal / Running lights
» Turn signal running light problem
» Anyone interested in converting their rear turn signals to be additional brake or running lights?
» brake light
Honda Silver Wing Scooter Forum :: Other Scooters and Motorcycles :: Other Scooter Topics :: DennisB's Shop[Info Only, shop closed]-
