» Fun times ahead
Draggin Front Brake I_icon_minitimeby Loosemarbles Today at 3:49 pm
» Dashboard Square
Draggin Front Brake I_icon_minitimeby MikeO Today at 4:11 am
» Hello From MD
Draggin Front Brake I_icon_minitimeby GHM-PM Yesterday at 7:15 am
» LED Headlights
Draggin Front Brake I_icon_minitimeby landisr Mon Oct 28, 2024 11:35 pm
Draggin Front Brake I_icon_minitimeby DescendingRaven Mon Oct 28, 2024 5:15 pm
» Ignition Switch
Draggin Front Brake I_icon_minitimeby POCAHONTAS Sun Oct 27, 2024 9:07 pm
» Lift Without A Lift
Draggin Front Brake I_icon_minitimeby landisr Sat Oct 26, 2024 5:25 pm
Draggin Front Brake I_icon_minitimeby xwelder Sat Oct 26, 2024 3:18 pm
Draggin Front Brake I_icon_minitimeby xwelder Fri Oct 25, 2024 5:00 am
» Handlebar Holder Recall
Draggin Front Brake I_icon_minitimeby xwelder Thu Oct 24, 2024 9:12 am
 Draggin Front Brake
RArch
Charlie bravo
Charlie bravo
Charlie bravo
Number of posts : 9
Registration date : 2013-05-04
Draggin Front Brake Empty
PostSubject: Draggin Front Brake   Draggin Front Brake I_icon_minitimeMon May 13, 2013 1:46 pm
Hi All
Picked up the Wing on Friday, only a three and a half hour drive to get it !, then on to see family whilst over that way, got home Sunday and unloaded the van today. Rode it into the shed and up on to the bench for a check over, it seems to have been serviced as the shop said they would, well the oil is clean and it has a new filter screwed on, the sales chap mentioned that the front brake was sticking on a bit so the workshop had stripped the front calliper cleaned every thing and it was now fine .......... it aint Evil or Very Mad ! the front drags badly, to the point that I would not take it for even a short ride, phoned the shop and told the tale, and suggested they post me a seal kit and a bottle of fluid as I prefer to spanner than to drive, OK they said, but they phoned later and said they wouldn't send the seals out, and they must have the bike in to see what the trouble is, as there must be something wrong with it Shocked and it is their responsibility if I hurt myself due to a malfunction, which is good in a way .... I guess ... but this will be 7 hours of van driving and 2 hours of waiting around .... whilst they put new seals in Rolling Eyes then when I tell them that next Saturday I will bring it in 11 am sharp have your mechanics on stand by, they say "I don't think we can do it then" Evil or Very Mad after a small explosion they have agreed to do it then or sub out the job to a Honda Dealer that can.
The pistons all move easily, the calliper floats freely on lovely greased pins, and the 2011 bike has only done 4500 summer miles, I think the seals have got a little hard due to lack of use, perhaps I am wrong, I had better be ! what happens if they can't fix it there and then Question Exclamation Exclamation Exclamation
Interesting fact which I learned ages ago : the piston seals are an odd shape, a bit square in section, these 'roll' a little when you apply the brake, when you release the brake the seals 'roll' back taking the pistons with them, the seals are the piston return spring, once you know that, many a dragging brake can be deduced and therefore fixed.
I know I should be grateful that the Dealer is taking things seriously, but I bought a newish Honda because I was getting fed up spannering the 1946 Matchless ... O well, thats life.
Will update this post when they find out what the cause is.
RArch
RArch
Number of posts : 613
PostSubject: Re: Draggin Front Brake   Draggin Front Brake I_icon_minitimeMon May 13, 2013 2:08 pm
What a pain in the a**...
deadhorse
http://www.rcmodeltalk.co.uk
agreat
Number of posts : 32
Registration date : 2013-04-03
PostSubject: Re: Draggin Front Brake   Draggin Front Brake I_icon_minitimeMon May 13, 2013 4:04 pm
Just as well you didn't have to ride it home, the dealer should have road tested it, How are they going to compensate your time & fuel etc.
lcseds
Number of posts : 54
Registration date : 2011-02-15
PostSubject: Re: Draggin Front Brake   Draggin Front Brake I_icon_minitimeMon May 13, 2013 7:49 pm
We had a 2009 Swing. My wife drove it one morning and the brake seemed stuck. Stuck to the point the fluid boiled and she lost all brakes (don't ask me how someone would not know the brakes were engaged while riding). Amazing she got it to a parking lot safely. Rotor had turned blue. Still has about one month of warranty and only 3600 miles. Dealer cleaned calipers, new pads and fluid. When they contacted Honda on the warranty claim, Honda ordered a parts capture to determine the failure. Now the entire brake system, front and rear, plus all fittings, hoses and clamps were sent to Honda engineering. I mean right down to the clips. Waited a couple weeks and they had replaced everything except one metal fitting. They finally released it back to us using that one old piece because it was backordered with no ETA. Problem did not crop up again in the few thousand miles we added, but we lost confidence in that bike. Please be careful. Brakes should not "stick". Ours was and ABS bike. Would have been a $1500 or so repair if it went out of warranty.
PS, I have a 2012 now. Did not lose faith in the model, just the one we had.
ScootRGuy
Number of posts : 55
Registration date : 2013-01-28
PostSubject: Re: Draggin Front Brake   Draggin Front Brake I_icon_minitimeTue May 14, 2013 7:41 am
I'm having the same issue, I replaced the brake pads, clean the caliper, pad pin and now it just sticks enough that you can hear the pads rubbing on the rotor. My next project is bleeding the brakes and replacing the brake fluid. What led me to believe the brakes were dragging was the sound it made at various speeds, the sounds seems to be amplified by the plastic fender and front cowl. They act like a speaker and make the brake dragging sound awful.
Gary
Charlie bravo
Charlie bravo
Number of posts : 9
PostSubject: Re: Draggin Front Brake   Draggin Front Brake I_icon_minitimeSat May 18, 2013 1:18 pm
Three hours eighteen mins drive, dropped off scoot, they were waiting for me and got on with the job, after about an hour the calliper seals were replaced and the brake assembly was all back as it should be, "just need to bleed the system now" said the mechanic, .......... Half an hour later I asked if the little bleeders were causing a problem, he said that as the system is large, the bleeding is not quite as easy as some, he used a vacuum bleeder, and it still took him an hour, and he test drove it, and declared it good.
I felt the wheel, it does turn quite easy, but still a little draggy, not much, but a bit, mechanic said that is just how they are ....... I put it in the van and drove three and a half hours home.
So, it is much better, and the dealer got on with it, we'll done Sutton Honda of Tamworth UK, but no offer of fuel help, or a free bike cover or anything, guess that is dealers for you. Off to ride now, review coming soon, as is a givi v47 topbox I just won on eBay !
jmaslak
Number of posts : 252
PostSubject: Re: Draggin Front Brake   Draggin Front Brake I_icon_minitimeSun May 19, 2013 1:04 pm
Charlie, after a relatively normal 20+ mile commute for me, the front caliper is warm (enough so you don't want to put your hand on it for more than a few seconds, but you can put your hand on it for a few seconds without burns), but not hot - I'm amazed how well the single disc cools (probably why Honda felt no need for two discs). You might just keep an eye on it to make sure it's not dragging in use by watching the temperature.
It seems very odd that the seals would go bad just from sitting (the '07 we have doesn't have any braking problems, but I know it was sitting for a couple years, and I don't think the brake was ever messed with because the factory assembly marks for the caliper holding bolts are still lined up). Of course that was also garage kept in dry conditions, so maybe that's a difference. Part of me also wonders if something is physically out of alignment (maybe the bike has some impact or drop damage?). Hopefully however the seals, new fluid, and proper bleeding will get things fixed (it is a pain to bleed, due to the CBS).
Charlie bravo
Charlie bravo
Number of posts : 9
PostSubject: Re: Draggin Front Brake   Draggin Front Brake I_icon_minitimeMon May 20, 2013 2:59 am
Just unlucky seals I guess, I have had the same issue with BMW and others, some seals last over 10 years, some don't, it's the same with fork seals.
I will check my temperature of calliper after the next ride.
Draggin Front Brake
» Front brake caliper
» front brake
» Keep the front brake covered - always! Do you? How so?
» front brake light
» Front brake check!
