dog carrier on Givi Monokey bracket? I_icon_minitimeby JohnyC Today at 5:39 am
dog carrier on Givi Monokey bracket? I_icon_minitimeby JohnyC Yesterday at 10:04 am
dog carrier on Givi Monokey bracket? I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
dog carrier on Givi Monokey bracket? I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
dog carrier on Givi Monokey bracket? I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
dog carrier on Givi Monokey bracket? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
dog carrier on Givi Monokey bracket? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
dog carrier on Givi Monokey bracket? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
dog carrier on Givi Monokey bracket? I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
dog carrier on Givi Monokey bracket? I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Colin B
stanly
stanly
Number of posts : 49
Registration date : 2013-04-05
dog carrier on Givi Monokey bracket? Empty
PostSubject: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeMon May 20, 2013 1:22 pm
Givi Luggage (topcase)– is there a way to use their mount for something other than their luggage, say mounting a dog carrier? About a 40lb dog so the backpack type solution won't work.
Colin B
Colin B
Number of posts : 586
Registration date : 2013-03-20
PostSubject: Re: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeMon May 20, 2013 1:59 pm
If you remove the monokey plate (the thing like a toilet seat!) you should be left with brackets that are bolted to the swing luggage rack.
It should be fairly easy to bolt anything else to those.
Number of posts : 3314
PostSubject: Re: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeMon May 20, 2013 4:22 pm
40pound dog on back way up high=might get you killed----GIVI box with hole cut in top works for under 10 lb dog----but you can still feel him there. My last dog, Moose rode to James Bay/Alaska/Baja/Europe/Korea that way. Old age got him.
GIVI "ears" can be used to bolt something else to.
stanly
PostSubject: Re: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeMon May 20, 2013 7:17 pm
Can't picture this, whatever it is, mine doesn't have a hole in center.
is a pretty high suppose, dog smell in Givi box=???
plus box I have is small
"ears"?
Should I have mentioned that I'm not Givilingual?
PostSubject: Re: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeMon May 20, 2013 10:33 pm
Is isn't the size of the box, it is the weight high above and to the rear of the axle.. 40 lb dog needs big box, too.
Colin B
Colin B
PostSubject: Re: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeTue May 21, 2013 2:04 am
You don't have this?
dog carrier on Givi Monokey bracket? Givi-M5-Plate
Perhaps you have this?
dog carrier on Givi Monokey bracket? Givi-M35-plate
Whichever, the same principle should apply. The monokey plate will be bolted to metal plates (ears) which are in turn bolted to the bike. Remove the monokey plate and fix your dog box to the metal ears.
However, comments above re weight and balance are valid and should be heeded.
stanly
PostSubject: Re: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeTue May 21, 2013 12:40 pm
I want out and took another look with topcase off, I have view #1 Embarassed
I see - Under the monokey plate
Valid points on having weight behind axle
I'd like to retain the quick dismounting feature of the monokey system to mount different case/carrier.
Guessing from the alt suggestions that you can't buy only a part that's the equivalent of a case attachment part seperate from the case?
Number of posts : 4218
PostSubject: Re: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeTue May 21, 2013 12:59 pm
Givi dealers have a manual of replacement parts for every top box and side case in their entire range, just about every component is available.
stanly
PostSubject: Re: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeWed May 22, 2013 1:50 pm
^^^ thanks, I don't see anything like this on GiviUSA.
PostSubject: Re: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeWed May 22, 2013 4:18 pm
In US call GIVI USA---dealers for the most part know little
Number of posts : 3837
PostSubject: Re: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeWed May 22, 2013 4:45 pm
I shouldn't think Givi include the part that fits on the plate in their spares list as it's an integral part of each bag and box.
Somerled
Somerled
Number of posts : 177
Registration date : 2011-06-02
PostSubject: Re: dog carrier on Givi Monokey bracket?   dog carrier on Givi Monokey bracket? I_icon_minitimeSat Jun 22, 2013 5:29 pm
Yeah, I wouldn't recommend a 40 lb dog on the back of the Swing either. If you want a safe answer (if not an inexpensive answer) I would recommend the Bushtec Tow-Tow trailer. Quite happy with mine!
https://www.silverwing600.com/t4519-dog-trailer
» Having trouble with my Givi monokey top box
» givi monokey E-46 Box experience with SilverWing.
» WANTED: Brackets for Givi Monokey trunk
» Givi AF214 - Metal Bracket Positioning
» Looking for 7811 ST HO SWT 400/600 (Fehling - Side Case Holder for Givi/Kappa (Monokey) Case) New or Old
