| The lights are on but she won't start :-( | |
+5DennisB RArch Colin B MikeO Haakon 9 posters |
Haakon Scooter Rider
Number of posts : 13 Age : 56 Location : Monterey, California USA Points : 4224 Registration date : 2013-05-23
| Subject: The lights are on but she won't start :-( Thu May 23, 2013 2:14 am | |
| Hi All, Trying to figure out why my Silverwing won't start. I just purchased the wing and was driving her(Mrs. Doubtfire) back from the bay area to Monterey when 15 miles from home I pulled over to check my gear and the bike wouldn't start again.
I checked the usual suspects as this is my 4th bike. Side stand was up, left break lever was pressed, throttle was not twisted. The bike doesn't even turn over so my guess is it could be the battery or perhaps a faulty switch at either the side stand or the starter. Thankfully I have road side so Mrs. Doubtfire will be headed to my mech in the morning.
Thanks in advance for any pointers on what I should be looking for.
Haakon |
| Subject: Re: The lights are on but she won't start :-( Thu May 23, 2013 3:06 am | |
| Have you inadvertantly flicked the Kill Switch? |
Colin B Silver Wing Expert
Number of posts : 586 Age : 72 Location : Windsor, UK Points : 4912 Registration date : 2013-03-20
| Subject: Re: The lights are on but she won't start :-( Thu May 23, 2013 3:36 am | |
| Squeeze the left brake lever VERY hard! Listen for a second click.
RArch Silver Wing Expert
| Subject: Re: The lights are on but she won't start :-( Thu May 23, 2013 8:12 am | |
| When you switch on the ignition you should hear the fuel pump, if not it could be the kill switch/side stand circuit thats prevent it.
Like has been said, you need to squeeze that left brake lever till you hear the second click of the micro switch, theres two one the first is only for the brake light. |
| Subject: Re: The lights are on but she won't start :-( Thu May 23, 2013 10:27 am | |
Number of posts : 199 Age : 63 Location : Athens Greece Points : 4843 Registration date : 2012-04-05
| Subject: Re: The lights are on but she won't start :-( Thu May 23, 2013 2:19 pm | |
| Can be a faulty alarm too...if there's any
Gyro Touring Scooter Rider
Number of posts : 321 Age : 72 Location : Frontenac, Ks Points : 4636 Registration date : 2013-04-07
| Subject: Re: The lights are on but she won't start :-( Thu May 23, 2013 3:11 pm | |
| - MikeO wrote:
- Have you inadvertantly flicked the Kill Switch?
Been there, done that... |
| Subject: Re: The lights are on but she won't start :-( Thu May 23, 2013 6:11 pm | |
| - Colin B wrote:
- Squeeze the left brake lever VERY hard! Listen for a second click.
This was my problem, I was being to soft on the brake squeeze and wasn't initiating the second switch. There was a lot of wind noise yesterday coupled with my hypothermia and frustration. This morning I was able to hear and be patient, she fired up just fine and I drove her all over town and started it right up over 5 times. Problem is solved but I'm still going to put a new Shorai battery in it tomorrow as well as have my mech change the oil and give her a good inspection. - Attachments
- Mrs. Doubtfire
- (164 Kb) Downloaded 13 times
hotwings Silver Wing Expert
Number of posts : 876 Age : 54 Location : Ontario Points : 5566 Registration date : 2012-04-29
| Subject: Re: The lights are on but she won't start :-( Thu May 23, 2013 6:34 pm | |
| I feel your pain. I did the exact same thing when i got my swing home! Couldnt get it to start, called the previous owner, he was baffled. Went online, discovered this site along with the answer here. Was relieved after finding out the "problem". At least i was in my own garage when i first tried starting it. |
Microtouch Scooter Rider
Number of posts : 30 Location : Lancaster Pa Points : 4509 Registration date : 2012-08-24
| Subject: Re: The lights are on but she won't start :-( Thu May 23, 2013 7:59 pm | |
| Something else to consider... The kill switch contacts can corrode over time and prevent it from starting. This happened to me once so I squirted a little contact cleaner in there and all was good. I did the same with the turn signal switch as a preventive procedure. |
| Subject: Re: The lights are on but she won't start :-( Thu May 23, 2013 11:51 pm | |
| - Microtouch wrote:
- Something else to consider... The kill switch contacts can corrode over time and prevent it from starting. This happened to me once so I squirted a little contact cleaner in there and all was good. I did the same with the turn signal switch as a preventive procedure.
What brand is the contact cleaner an where do I squirt it? Haakon |
| Subject: Re: The lights are on but she won't start :-( Fri May 24, 2013 2:49 am | |
| - Haakon wrote:
- This was my problem, I was being to soft on the brake squeeze
Glad it was so simple. I had the same "fault" the day I collected mine from the dealer. |
