| Up and running ! | |
Bluepaul Scooter Rider
Number of posts : 5 Age : 59 Location : Solihull, England Points : 4186 Registration date : 2013-05-23
RArch Silver Wing Expert
Number of posts : 613 Age : 57 Location : West London, UK Points : 5390 Registration date : 2011-11-07
| Subject: Re: Up and running ! Fri May 31, 2013 2:56 pm | |
| Subject: Re: Up and running ! Fri May 31, 2013 3:48 pm | |
| - RArch wrote:
- Bet that was a ride to remember. Now that you've the AF214 fitted can you repeat it and give us a wet weather review
A search turned this up, it may help: https://www.silverwing600.com/t2813-intercom-wiring Thanks for the link, obviously I need to perfect my search technique ! Hopefully I wont experience that journey again ! |
Number of posts : 4214 Location : York, North Yorkshire, England UK Points : 9418 Registration date : 2010-11-16
| Subject: Re: Up and running ! Fri May 31, 2013 6:02 pm | |
| Where you from in Cumbria mate, I'm originally from Carlisle and then lived in West Cumbria for nearly 40 years until I retired last year and moved to York. I can't say I'm missing anything, apart from Cumberland Sausage. |
Number of posts : 3830 Age : 75 Location : Seaham, Co Durham, UK Points : 9675 Registration date : 2009-06-29
| Subject: Re: Up and running ! Sat Jun 01, 2013 2:36 am | |
| Hello Paul. Re Starcom:
I had mine under the seat in the tool-kit recess. The mechanic at my dealers wired in a power lead which came up through the hole in the recess. It was live when the ignition was on. I trailed the Starcom extension leads round the outside of the recess (there’s a gap in the edge of it at the back which I routed the leads through) and out under the front of the seat. It seems as if they’ll be trapped but they won’t be. I had to half-close the seat when getting leads into position. It was then easy to reach down when I was sitting on the bike and plug in my helmet and music leads. There’s plenty of space so one could run leads for every plug-in device via that route. I used coloured tape to identify which lead was which. I haven’t yet installed the unit on my new bike but will in due course. It’s not the tidiest of solutions but worked very well and didn’t look bad. The tool-kit then resided in the main part of the under-seat storage. Incidentally my first Starcom unit was the basic one with a battery in it; I used to carry it in a bumbag with the leads trailing out and wear it when I was riding. That was when I had my X9’s.
I've just uploaded a picture into my gallery in which you can see the leads (just about!). The one that's connected is the music lead, the other is for my helmet and is disconnected so just hanging down. The picture is entitled 'Waiting For The Ferry' and is on Page Two.
HTH |
| Subject: Re: Up and running ! Sat Jun 01, 2013 7:01 am | |
CathyN Silver Wing Expert
Number of posts : 771 Location : USA Points : 6020 Registration date : 2010-11-15
| Subject: Re: Up and running ! Sat Jun 01, 2013 12:30 pm | |
| Paul,
Welcome to the forum.
Bob and I use a Starcom system also. He ran the leads under the tunnel on the left. I have a surface mount connection in front of the seat on the left. This is where I plug in my helmet lead. I also had one for my push to talk lead for my walkie next to it. He changed the PTT to a handlebar mount on my ram mount (left side). He ran the lead up through the tunnel up the handlebar. We did this this spring.
When I was riding the PTT lead would come loose and disconnect form the vibration from some of the rougher roads. This new set up seems to be working quite well for me.
I also, have a 12 volt plug next to the helmet lead on the tunnel. I can connect this to my tunnel bag which has a 12 volt connection inside the bag.
Sorry I don't have pictures. I am terrible about learning how to post on the forum.
We do like the Starcom system.
Hope this helps.
Cathy |
| Subject: Re: Up and running ! Tue Jun 04, 2013 5:41 pm | |
| Paul,
I forgot to mention I have my unit attached with Velcro or it might be double sided foam. We have it on the front panel under the seat storage area. We tried it where the "tool kit" is, if you can call it a tool kit. It seemed to get quite hot there. The cables and leads have more room to fit in the storage area space better in my opinion. I can take some photos and e-mail them to you. Just send me a PM with you address.
Mike,
I could e-mail them to you too. Maybe you can post them here on the forum for me.
Cathy |
