Number of posts : 341 Location : Surprise, AZ. Points : 5789 Registration date : 2010-04-30
| Subject: Accessory Socket for the US Version Thu Jun 06, 2013 4:06 pm | |
| I found a 12v accessory outlet at Radio Shack that does not require a backing nut. The socket has fingers that snap out when seated in the mounting hole.
Using the under dash mount in the kit as a template, enlarge the hole and cut a notch in the left pocket to keep the socket from spinning. I used a Dremel 1/8 straight router bit free hand until the socket fit.
There is a rubber cover on the socket that needs to be removed due to the thickness of the plastic of the dash to let the fingers seat and hold properly.
http://www.radioshack.com/product/index.jsp?productId=3896268&znt_campaign=Category_CMS&znt_source=CAT&znt_medium=RSCOM&znt_content=CT2818117
robert Super Scooter Rider
Number of posts : 267 Age : 81 Location : arizona Points : 5463 Registration date : 2010-09-19
| Subject: Re: Accessory Socket for the US Version Fri Jun 07, 2013 7:49 pm | |
| Bought a 12 V socket at Cycle Gear for $10.00, hooked up to battery, put small notch on bottom of battery cover for wires to extend out. Easy and cheap way to charge my cell phone. |
