» Parasitic amperage leak Uintah
Spark plugs burn out I_icon_minitimeby JohnyC Yesterday at 12:35 pm
» Rear wheel valve stem
Spark plugs burn out I_icon_minitimeby Meldrew Yesterday at 12:28 am
Spark plugs burn out I_icon_minitimeby Hop Sun Nov 24, 2024 7:04 pm
Spark plugs burn out I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Spark plugs burn out I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Spark plugs burn out I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Spark plugs burn out I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Spark plugs burn out I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Spark plugs burn out I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Spark plugs burn out I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
walidcheb
walidcheb
Number of posts : 2
Registration date : 2012-12-29
Spark plugs burn out Empty
PostSubject: Spark plugs burn out   Spark plugs burn out I_icon_minitimeWed Jun 19, 2013 2:11 pm
Hi all, does anyone have an idea why the spark plugs burn out so quickly?
i replaced them 2 months ago when the bike ran poorly along with the air filter, and in no time it started doing so again and today on my way back from work it stopped.
i took the plugs out and they were all black at the tip and the ceramic had a yellow color ring, like they were 2 years old.
i think there is something causing this problem because i installed the standard NGK plugs.
your help is much appreciated.
Number of posts : 2778
PostSubject: Re: Spark plugs burn out   Spark plugs burn out I_icon_minitimeWed Jun 19, 2013 3:31 pm
Hi walidcheb,
Sounds like there is a small hole in your Fuel Pressure Regulator Unit in your scooters EFI system.
One more thing...Welcome to the forum.
PostSubject: Re: Spark plugs burn out   Spark plugs burn out I_icon_minitimeFri Jun 21, 2013 12:47 pm
http://www.ngksparkplugs.com/tech_support/spark_plugs/faqs/faqread.asp
Which is closest to your spark plugs?
I switched to the NGK Iridium plugs and found they lasted longer than the original NGK plugs.
eddy
Number of posts : 187
PostSubject: Re: Spark plugs burn out   Spark plugs burn out I_icon_minitimeSat Jun 22, 2013 4:05 am
Tell how your plugs look by this link.
When both (recommended)plugs are look the same (bad),then you can 't blame the plugs.
Most likely the problem is in the air/fuel ratio.
Like Dennis suggests.
Iridium plugs do not solve a problem.
They only live longer.
Eddy
http://edho@operamail.com
NWSSC
NWSSC
Number of posts : 418
PostSubject: Re: Spark plugs burn out   Spark plugs burn out I_icon_minitimeSat Jun 22, 2013 4:52 pm
I agree that I sounds like the spark plug condition is a symptom of another problem.Are they the correct plugs according to the manual? Have there been any other modifications? I have not herd of any one having a ignition coil problem on a S/W but if you could borrow one for a few days it might be worth a try.  Howard
walidcheb
walidcheb
Number of posts : 2
PostSubject: Re: Spark plugs burn out   Spark plugs burn out I_icon_minitimeFri Jun 28, 2013 2:09 pm
Thank you all guys for the advise, i too agree now that it is not a spark plug issue, as i replaced them last week and the problem reappeared in less than a week.
I will send it to repair next week and will post what was the problem, that is if the mechanic told me what was it, because sometimes they tend to get discreet.
Thanks again.
» Silverwing spark plug upgrade?
» Gimmick Spark plugs
» change spark plugs
» Spark Plugs
» spark plug replacement
