» Parasitic amperage leak Uintah
Parasitic amperage leak Uintah I_icon_minitimeby GHM-PM Today at 7:57 am
» Rear wheel valve stem
Parasitic amperage leak Uintah I_icon_minitimeby Meldrew Today at 12:28 am
Parasitic amperage leak Uintah I_icon_minitimeby Hop Yesterday at 7:04 pm
Parasitic amperage leak Uintah I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Parasitic amperage leak Uintah I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Parasitic amperage leak Uintah I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Parasitic amperage leak Uintah I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Parasitic amperage leak Uintah I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Parasitic amperage leak Uintah I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Parasitic amperage leak Uintah I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
2 posters
AldusFran
Number of posts : 211
Parasitic amperage leak Uintah Empty
PostSubject: Parasitic amperage leak Uintah   Parasitic amperage leak Uintah I_icon_minitimeToday at 7:40 am
A couple days ago I noticed my swing didn't have enough amps to start bike. After a full charge thescoot would loose enough amps overnight to keep bike from starting. After doing a leak test at negative terminals, there was .90 amp drain. I narrowed it down to 10amp : clock backup-lluggage box light. I disconnected luggage box light connector and realized still a drain. Removed 10amp fuse and left it that way. Anyone else had this experience ?
Number of posts : 2628
PostSubject: Re: Parasitic amperage leak Uintah   Parasitic amperage leak Uintah I_icon_minitimeToday at 7:57 am
The under seat light is a common problem. Most people do take the bulb out. That should help, as to the rest of the drain it's probably memory applications for the scoot and not a problem. Maybe someone else has more suggestions.
» Oil Leak fix
» Rubber Grommetts Oil Leak Repair Question
» Oil leak? Any help?
» Engine oil leak
» Engine Oil Leak - I need to get busy
