| saddle automatic? | |
+7model28a Meldrew tarmacburner2 robert Colin B dspevack calce 11 posters |
calce Scooter Rider
Number of posts : 15 Location : it Points : 3990 Registration date : 2013-07-03
| Subject: saddle automatic? Fri Jul 05, 2013 2:50 am | |
| excuse me, I want to know if he has ever been made automatic opening the saddle |
calce Scooter Rider
| Subject: Re: saddle automatic? Fri Jul 05, 2013 10:46 am | |
dspevack Silver Wing Guru
Number of posts : 2008 Age : 59 Location : Miami, FL Points : 8022 Registration date : 2008-12-27
| Subject: Re: saddle automatic? Fri Jul 05, 2013 11:31 am | |
| I'm sure a custom shop could rig something up for you, but in 10 years on silverwing forums, I have never seen anyone with an auto opening seat. |
calce Scooter Rider
| Subject: Re: saddle automatic? Fri Jul 05, 2013 12:11 pm | |
calce Scooter Rider
| Subject: Re: saddle automatic? Fri Jul 05, 2013 2:20 pm | |
| I understand. The answer is still NO it hasn't been done. Why do you need such a thing? |
calce Scooter Rider
| Subject: Re: saddle automatic? Fri Jul 05, 2013 3:10 pm | |
| you've already created the change because it pops up with the remote ... but don't saddle it raises .... put a small electric actuator cylinder? |
Colin B Silver Wing Expert
Number of posts : 586 Age : 72 Location : Windsor, UK Points : 4723 Registration date : 2013-03-20
| Subject: Re: saddle automatic? Fri Jul 05, 2013 3:20 pm | |
| calce, I think you need to use a different online translator. |
robert Super Scooter Rider
Number of posts : 267 Age : 81 Location : arizona Points : 5274 Registration date : 2010-09-19
| Subject: Re: saddle automatic? Fri Jul 05, 2013 8:16 pm | |
| calce,
Everyone understands your question, but nobody has ever heard of someone doing it, if you do manage to do it let us know. Ride Safe. |
Number of posts : 1099 Age : 70 Location : Cleveleys, Lancashire, England Points : 6345 Registration date : 2010-03-27
| Subject: Re: saddle automatic? Sat Jul 06, 2013 3:48 pm | |
| The simplest way to do it would be to use a more powerful gas strut, but not too powerful as you want to be able to close it easily.
Google translation (Il modo più semplice per farlo sarebbe quello di utilizzare una molla a gas più potente, ma non troppo potente come si vuole essere in grado di chiudere facilmente.)
Youtube (Italian) https://www.youtube.com/watch?v=B-l5RmlR5cQ
Cheers, |
Number of posts : 4179 Location : York, North Yorkshire, England UK Points : 9218 Registration date : 2010-11-16
| Subject: Re: saddle automatic? Sat Jul 06, 2013 3:58 pm | |
| Even easier swop the Silver Wing for a Peugeot Satelis 500, you can open the seat remotely from the key fob. |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7369 Registration date : 2010-02-03
| Subject: Re: saddle automatic? Sat Jul 06, 2013 6:22 pm | |
| Here are two ways you could use along with a more powerful gas strut like in the link that tarmacburner2 gave you.
http://www.dashzracing.com/remote-control-trunk-release-conversion-kit-tr-u100.html?gclid=CN2_kavKh7gCFcSj4AodJx8A3w
http://www.aliexpress.com/item/Free-shipping-universal-High-Class-Trunk-Release-Kits-3001Life-cycle-30-000-times-Compatible-with-any/827837824.html |
hotwings Silver Wing Expert
Number of posts : 876 Age : 54 Location : Ontario Points : 5377 Registration date : 2012-04-29
| Subject: Re: saddle automatic? Sat Jul 06, 2013 10:02 pm | |
| I recall seeing a youtube video awhile back that shows a silver wing rigged out with a actuator that opened the seat with a push button on a keyfob. Dreamt of having this option It can be done. |
calce Scooter Rider
| Subject: Re: saddle automatic? Sun Jul 07, 2013 9:32 am | |
| @ hotwings ... Yes it can put a more powerful piston, because then no longer closes ... the video posted by tarmacburner2 shows only that pops up .... the problem is then close |
| Subject: Re: saddle automatic? Sun Jul 07, 2013 10:30 am | |
| I'm sure that someone could bodge together a car window motor & mechanism along with a remote car door (or trunk) lock solenoid which can be activated by a key fob. The key fob could operate a relay which in turn operated the solenoid to unlock the seat, the same relay would also trigger the window motor...
However the whole lot would probably take up a large amount of space in the Silverwing trunk.
calce Scooter Rider
| Subject: Re: saddle automatic? Sun Jul 07, 2013 10:53 am | |
| If possible, put an electric actuator. It's quite thin with a run of 25 cm. that raise at least 10 kg and a run of at least 5 cm per second ... |
| Subject: Re: saddle automatic? Sun Jul 07, 2013 11:26 am | |
| The youtube does say if you are interested contact him.
Se ti interessa acquistarlo contatta: uomo-vitruviano@libero.it
Calce, you will be able to email in your own language so good luck. Calce, si sarà in grado di e-mail nella vostra lingua in modo buona fortuna.
Cheers,
| Subject: Re: saddle automatic? Sun Jul 07, 2013 2:52 pm | |
| You should definitely take an air bag from a car steering wheel and mount it under the seat to activate when you turn the key...
calce Scooter Rider
| Subject: Re: saddle automatic? Sun Jul 07, 2013 3:13 pm | |
salaxan Scooter Rider
Number of posts : 16 Age : 52 Location : Greece Points : 4690 Registration date : 2011-08-06
| Subject: Re: saddle automatic? Sun Jul 07, 2013 5:38 pm | |
| Yes I have done this, using an electromagnetic lock from a car. The power taken from the rear position lights and operates only when the key is turned on.
open the saddle with a button |
calce Scooter Rider
| Subject: Re: saddle automatic? Sun Jul 07, 2013 11:09 pm | |
| @ salaxan ... Open the saddle electron magnetic lock from a car ... the saddle, stands up on its own? |
| Subject: Re: saddle automatic? Mon Jul 08, 2013 4:41 pm | |
| - calce wrote:
- @ salaxan ... Open the saddle electron magnetic lock from a car ... the saddle, stands up on its own?
Yes, I changed the shock with a stronger one! |
calce Scooter Rider
| Subject: Re: saddle automatic? Tue Jul 09, 2013 3:11 pm | |
tvanloon Scooter Rider
Number of posts : 16 Age : 69 Location : Winona, Minnesota Points : 4353 Registration date : 2012-07-06
| Subject: Re: saddle automatic? Wed Jul 10, 2013 11:57 am | |
| I suggest a bottle of little blue pills under the seat...of course you probably won't be able to close the seat for a couple of hours after it's raised. |
calce Scooter Rider
| Subject: Re: saddle automatic? Wed Jul 10, 2013 2:10 pm | |
| Actually my seat raises just fine but I have seen the advertisements;) |
| Subject: Re: saddle automatic? | |
