| automatic choke problem | |
serkanpinar Scooter Rider
![serkanpinar](https://2img.net/u/3413/63/00/33/avatars/4877-49.jpg)
Number of posts : 10 Location : turkey Points : 2550 Registration date : 2017-09-30
![automatic choke problem Empty](https://2img.net/i/empty.gif) | Subject: automatic choke problem Tue Mar 20, 2018 7:01 pm | |
| greetings from Turkey
the engine stays above 2000 rpm after the start and unfortunately the cycle does not fall why it can be welded
sorry for my bad english
carolina wing rider Touring Scooter Rider
Number of posts : 305 Age : 70 Location : Mebane NC Points : 2888 Registration date : 2018-01-22
![automatic choke problem Empty](https://2img.net/i/empty.gif) | Subject: Automatic choke Wed Mar 21, 2018 12:33 am | |
| Is your engine idling smoothly? Does it skip or hesitate when applying throttle? |
![automatic choke problem Empty](https://2img.net/i/empty.gif) | Subject: Re: automatic choke problem Wed Mar 21, 2018 4:04 am | |
| - carolina wing rider wrote:
- Is your engine idling smoothly? Does it skip or hesitate when applying throttle?
work properly yes |
![automatic choke problem Empty](https://2img.net/i/empty.gif) | Subject: Re: automatic choke problem Wed Mar 21, 2018 12:00 pm | |
![automatic choke problem Empty](https://2img.net/i/empty.gif) | Subject: Re: automatic choke problem Wed Mar 21, 2018 5:44 pm | |
| Possible ?? sticking throttle cable. |
![automatic choke problem Empty](https://2img.net/i/empty.gif) | Subject: choke Wed Mar 21, 2018 6:03 pm | |
| If the idle adjustment does not help and the cables are not sticking the only other thing I can think of is a possible air (vacuum) leak somewhere. |
The Bern Silver Wing Expert
![The Bern](https://2img.net/u/3413/63/00/33/avatars/3758-23.gif)
Number of posts : 897 Location : Telford, UK Points : 4556 Registration date : 2014-11-20
![automatic choke problem Empty](https://2img.net/i/empty.gif) | Subject: Re: automatic choke problem Wed Mar 21, 2018 7:01 pm | |
- If the idle adjustment does not help and the cables are not sticking the only other thing I can think of is a possible air (vacuum) leak somewhere.
Ditto To check for air leak, easiest way is (with engine running) spray injector to cylinder head mounting rubbers with carburetor cleaner & listen for change in engine sound/rev's |
![automatic choke problem Empty](https://2img.net/i/empty.gif) | Subject: Re: automatic choke problem Sat Mar 24, 2018 1:47 pm | |
| it only lasts long in cold weather |
![automatic choke problem Empty](https://2img.net/i/empty.gif) | Subject: Re: automatic choke problem Sat Mar 24, 2018 2:32 pm | |
| The 'fast idle unit' is connected to the throttle body and is controlled by the coolant temperature. That's why the scoot must be at full operating temp before adjusting the idle (either via the idle adjustment screw or the air mixture screws as well). So in cold weather it takes longer for the coolant temp to raise and therefore the idle speed will be higher for a longer time.
So as has been said previously, check the air filter then check for a vacuum leak. Then adjust the idle screw after the engine is up to operatinh temperature.
