Oil has smell of gas. I_icon_minitimeby sonuvabug Yesterday at 4:19 pm
Oil has smell of gas. I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Oil has smell of gas. I_icon_minitimeby sonuvabug Yesterday at 4:06 pm
Oil has smell of gas. I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Oil has smell of gas. I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Oil has smell of gas. I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Oil has smell of gas. I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Oil has smell of gas. I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Oil has smell of gas. I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Oil has smell of gas. I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
3 posters
ScootRGuy
Number of posts : 55
Registration date : 2013-01-28
Oil has smell of gas. Empty
PostSubject: Oil has smell of gas.   Oil has smell of gas. I_icon_minitimeSat Aug 17, 2013 10:55 am
Hey guys,
I was checking the oil last night on my 2004 Swing with about 5300 miles on the clock and I noticed my oil has a fairly strong odor of gas. I changed the oil at 5200 so it only has 100 miles since last oil and filter changed. Seems like I remember the last time I changed the oil it also had and odor of gas. The oil looks perfect, clean with a light honey color. I only use the recommended Honda motor oil. I get 50+ miles per gallon so I doubt that is fuel leaking into the oil. My concern is that over time the gas can wash away the oil on the bearings causing engine failure. It would be interesting to hear from others about this if you check your oil by wiping the dip stick on a paper towel then checking it for the odor of gas.
Thanks!
Gary
Last edited by ScootRGuy on Sat Aug 17, 2013 10:56 am; edited 1 time in total (Reason for editing : Mia spelled word)
PostSubject: Re: Oil has smell of gas.   Oil has smell of gas. I_icon_minitimeSat Aug 17, 2013 5:29 pm
It could be that you've got a leaky fuel injector. While you are parked for the night, etc, drops of fuel could be leaking into the cylinder, past the rings, then down into the crankcase.
rollsroyce250
Number of posts : 73
Registration date : 2012-06-21
PostSubject: Re: Oil has smell of gas.   Oil has smell of gas. I_icon_minitimeSat Aug 17, 2013 5:40 pm
Fuel pressure regulator has started to fail. The regulator diaphragm develops holes, gasoline is sucked into the intake manifold by way of the vacuum tube that operates the pressure regulator. Order a new regulator O-ring when you order the new regulator.
ScootRGuy
PostSubject: Re: Oil has smell of gas.   Oil has smell of gas. I_icon_minitimeSat Aug 17, 2013 7:02 pm
That sounds very likely, thanks for the suggestion.
» Gas smell?
» Intermittent strong gas smell
» can you smell burning rubber?
» I like the smell of castor oil in the morning...
» Slight fuel smell from a stop
