Slight fuel smell from a stop I_icon_minitimeby JohnyC Today at 5:39 am
Slight fuel smell from a stop I_icon_minitimeby JohnyC Yesterday at 10:04 am
Slight fuel smell from a stop I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Slight fuel smell from a stop I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Slight fuel smell from a stop I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Slight fuel smell from a stop I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Slight fuel smell from a stop I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Slight fuel smell from a stop I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Slight fuel smell from a stop I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Slight fuel smell from a stop I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
3 posters
aerosilverwing
Number of posts : 23
Registration date : 2012-02-09
Slight fuel smell from a stop Empty
PostSubject: Slight fuel smell from a stop   Slight fuel smell from a stop I_icon_minitimeMon Feb 27, 2012 3:00 am
Since these bikes are new to me, I don't know if I should be smelling unburnt fuel on takeoff from stop?
As a side note....
When I got the bike, the idle was up to about 1500rpm. Seemed high to me. I put it to about 900-1000 and idles good to me. I saw which adjustment screw was correct to adjust the idle, so I know I got that right and it was smelling before I adjusted the idle.
Any ideas why it is smelling like unburnt fuel?
I don't see any wet fuel on or around the fuel cap.
toolboxjesse
toolboxjesse
Number of posts : 330
PostSubject: Re: Slight fuel smell from a stop   Slight fuel smell from a stop I_icon_minitimeMon Feb 27, 2012 12:23 pm
What year and how many miles on the bike? it might be a damaged fuel hose.
Jesse in Atlanta
aerosilverwing
PostSubject: Re: Slight fuel smell from a stop   Slight fuel smell from a stop I_icon_minitimeMon Feb 27, 2012 12:50 pm
Jesse in Atlanta
2002, 15,000 miles.
toolboxjesse
toolboxjesse
PostSubject: Re: Slight fuel smell from a stop   Slight fuel smell from a stop I_icon_minitimeMon Feb 27, 2012 1:06 pm
If you resolve the idle and you still smell it I would check the fuel lines- the bike is 10 years old after all.
Jesse in Atlanta.
aerosilverwing
PostSubject: Re: Slight fuel smell from a stop   Slight fuel smell from a stop I_icon_minitimeMon Feb 27, 2012 1:15 pm
bigbird wrote:
If you put a voltmeter on your battery you will see that a 900-1000 rpm idle is not so good.
If you put an oil pressure gauge on your engine you will see that a 900-1000 rpm idle is not so good.
If you put vacuum gauges on the throttle bodies you will see that a 900-1000 rpm idle is not so good.
If you put an exhaust analyzer in the muffler you will see that a 900-1000 rpm idle is not so good.
There are reasons why Honda's recommended idle is 1300 plus or minus 50 rpm.
Well, damn. I can't wait until I get my shop manual. Thanks guys
PostSubject: Re: Slight fuel smell from a stop   Slight fuel smell from a stop I_icon_minitimeMon Feb 27, 2012 5:43 pm
https://www.silverwing600.com/t3565-silverwing-gas-odor#32388
» Do you stop with one,two,or no feet down at stop sign?
» Fuel tank removal (fuel pump replacement)
» Slight oil leak
» slight backfiring thru the exhaust
» Intermittent strong gas smell
