| New Plugs installed! | |
Number of posts : 2623 Age : 72 Location : Bullhead City, AZ Points : 7513 Registration date : 2012-05-17
| Subject: New Plugs installed! Fri Aug 23, 2013 7:05 pm | |
| Well today my NGK Iridium plugs arrived! I gapped them at .032 (range is .031-.035). Using the pictorial gotten here on the forum I had no problems! Here are the old plugs: They seem to be OK, in retrospect they probably could have gone a lot longer before replacing. The plug on the left side was REALLY tight. I had to use a breaker bar to get it loose, other side was fine. 16 foot/pounds? I don't think so. Here is the 4 1/2 inch 3/8 socket I purchased at Napa for about 9 bucks. I have one of these but it is at my house in WA... Naturally! One caution, this socket did not have a magnetic or rubber insert to hold the plug. However, due to the angle of the head I was able to insert the plugs in socket without having it fall out in the head. Thank God! Actually the install was quite easy; certainly easier than replacing a headlight bulb The scoot started right up and idled great. I will keep you posted if any good or bad things crop up. I installed NGK CR8EHIX-9 plugs. Just to clarify; both the stock plugs were gapped at .036 upon removal!
hotwings Silver Wing Expert
Number of posts : 876 Age : 54 Location : Ontario Points : 5566 Registration date : 2012-04-29
| Subject: Re: New Plugs installed! Fri Aug 23, 2013 9:22 pm | |
| GHM-PM how many kilometers/miles are on the "old" plugs. Like you say they appear in pretty good condition. |
JeffR_ Site Admin
Number of posts : 1103 Age : 65 Location : Bay Area, Ca Points : 9075 Registration date : 2010-05-12
| Subject: Re: New Plugs installed! Fri Aug 23, 2013 9:24 pm | |
| Glenn,
I had to really use some force to remove my plugs the first time too. I almost thought the factory put locktite on them. lol
I have had my plugs for at least 25,000 miles and they seem to keep their gap still and look good. I don't think the iridium plugs make it run better but they seem to last a long time. |
| Subject: Re: New Plugs installed! Fri Aug 23, 2013 10:16 pm | |
| - hotwings wrote:
- GHM-PM how many kilometers/miles are on the "old" plugs. Like you say they appear in pretty good condition.
8441 US miles. |
eddy Maxi-Scooter Rider
Number of posts : 187 Age : 73 Location : Europe Flanders. Points : 5679 Registration date : 2009-11-27
| Subject: Re: New Plugs installed! Sat Aug 24, 2013 6:58 am | |
| * Spark plugs are actually very simple things. Two electrodes separated by insulation.
What could wear? .. The gap can be increased by the erosion of the metal. Here are the Iridiums the better, but ordinary plugs you can also adjust. I think the ordinary will last at least 40,000 miles.
Of course if appropriate types and the engine is ok.
Maintenance Parts .. oil, filters, spark plugs, coolant, magic additives ...Big business. |
| Subject: Re: New Plugs installed! Sun Dec 01, 2013 8:26 pm | |
| UPDATE:
It is December 1st and my Silver Wing now has 12K on it. Almost 4K on the Iridium plugs! No problems to report, scoot runs GREAT, idles GREAT etc. No complaints so far.
Are OEM plugs bad? No way! But for the small difference in price I am very happy with the Iridium units.
As to changing my OEM plugs at 8K, I have the 5 year Honda warranty on this scoot and since Honda is adamant about a 8K change, felt it would be a good idea... |
| Subject: Re: New Plugs installed! Sun Dec 01, 2013 9:54 pm | |
| Have you balanced (synched) the throttle plates yet? I have checked the synch on 5 different Silverwings, and every one of them was out by at least 5-10mm of vacuum. After proper synching, the guys I did it for said their Swing ran much smoother afterwards, with a more stable idle and better throttle response. Synching the throttle plates will be more beneficial than any spark plug change IMHO, unless of course the plugs are so worn out that they're misfiring. |
| Subject: Re: New Plugs installed! Sun Dec 01, 2013 10:10 pm | |
| I replaced my OEM plugs at 8,000 miles with OEM plugs. Yesterday I hit 48,000miles on the ones I put in at 8,000, so 40,000 on the replacements. I had thought about trying iridium plugs but so far my plugs have always looked as good as the ones pictured in the post above. I will be putting a new belt on sometime this week so I will check the plugs again then. I really don't think I needed to replace them at 8,000 but I wanted to be safe. I kept the old plugs under the seat incase I had any problems and have never needed them.
bigbird, maybe I will also check the sync of the throttle plates when I'm putting the new belt on. |
| Subject: Re: New Plugs installed! Sun Dec 01, 2013 11:25 pm | |
| - model28a wrote:
bigbird, maybe I will also check the sync of the throttle plates when I'm putting the new belt on. Hey Roger. Wait for me to come down to FL again and we can make another video. |
jdeereanton Silver Wing Guru
| Subject: Re: New Plugs installed! Mon Dec 02, 2013 8:42 am | |
| - model28a wrote:
- I replaced my OEM plugs at 8,000 miles with OEM plugs. Yesterday I hit 48,000miles on the ones I put in at 8,000, so 40,000 on the replacements. I had thought about trying iridium plugs but so far my plugs have always looked as good as the ones pictured in the post above. I will be putting a new belt on sometime this week so I will check the plugs again then. I really don't think I needed to replace them at 8,000 but I wanted to be safe. I kept the old plugs under the seat incase I had any problems and have never needed them.
bigbird, maybe I will also check the sync of the throttle plates when I'm putting the new belt on. Iridium plugs will improve the speed at which your money will leave your wallet. That kind of performance is measurable. |
