Ofer Rothmann Scooter Rider
Number of posts : 48 Age : 48 Location : Israel Points : 4288 Registration date : 2013-05-06
| Subject: Enyone know why? Wed Sep 04, 2013 11:59 am | |
| Hi Guys,
Lately I noticed that when I go over a little hole in the road the Silverwing slow down for a second as if I leave the throttle. Do you have any ideas? |
Colin B Silver Wing Expert
Number of posts : 586 Age : 72 Location : Windsor, UK Points : 4916 Registration date : 2013-03-20
| Subject: Re: Enyone know why? Wed Sep 04, 2013 4:07 pm | |
Number of posts : 199 Age : 63 Location : Athens Greece Points : 4847 Registration date : 2012-04-05
| Subject: Re: Enyone know why? Wed Sep 04, 2013 4:36 pm | |
| Check for loose resistor caps on the spark plugs.Most of the times are hard to lock them completely |
rollsroyce250 Scooter Rider
Number of posts : 73 Location : Florida Points : 4616 Registration date : 2012-06-21
| Subject: Re: Enyone know why? Wed Sep 04, 2013 9:54 pm | |
| I would check the sidestand safety switch. Could be an intermittent open circuit caused by the brief impact. Separate the connector, make sure the contacts are not bent or loose, and reassemble. |
GerardButlersHamster Scooter Rider
Number of posts : 32 Location : northern ireland Points : 4142 Registration date : 2013-09-05
| Subject: Re: Enyone know why? Sat Sep 07, 2013 1:28 pm | |
| Yep just like above sidestand cut off switch |
cotetoi Silver Wing Expert
Number of posts : 757 Location : New Brunswick, Canada Points : 5068 Registration date : 2013-06-27
| Subject: Re: Enyone know why? Mon Sep 30, 2013 8:44 am | |
| Hey Ofer, I have noticed the same thing happening on my bike, and I don't know why. But, I think the front forks are probably to blame for that. I get a jarring from my handlebars as I go over any hole, and specially if the road has been chipsealed the surface is not even, and the ride is really rough and the bike just slows and speeds up ever so slightly all the time. What helped me was that I stopped the throttle from jiggling by keeping a slight steady pressure. It kept the revs up and smoothed out the ride. It is in the wrist action, and you'll know when it starts working for you. Somebody else may know why this happens or perhaps someone with upgraded front springs can tell us if they help. |
Dimond Silver Wing Expert
Number of posts : 540 Age : 79 Location : San Francisco Bay Area Points : 5537 Registration date : 2011-08-07
| Subject: Re: Enyone know why? Mon Sep 30, 2013 12:43 pm | |
| - Ofer Rothmann wrote:
Lately I noticed that when I go over a little hole in the road the Silverwing slow down for a second as if I leave the throttle. You may wish to try a throttle lock to see if it just your hand coming off the throttle a bit - the SWing is very sensitive to engine braking. Putting in hypersprings will help reduce 'pothole dive' - it is a great mod. |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7562 Registration date : 2010-02-03
| Subject: Re: Enyone know why? Mon Sep 30, 2013 8:32 pm | |
| Dimond, I agree with your advice to try a throttle lock. I think the Silverwing has the most sensitive throttle of any of my scooters. cotetoi, this may be s stupid question but what is a chipsealed surface? |
