| prep for final drive oil change | |
cotetoi Silver Wing Expert
| Subject: prep for final drive oil change Mon Sep 16, 2013 11:00 am | |
| Hey guys, I know that the engine should be warmed up for an oil change. What does the final drive oil change need? I figure since I can't ride today, I'd do some maintenance on the bike. Thanks. |
| Subject: Re: prep for final drive oil change Mon Sep 16, 2013 12:03 pm | |
| Did you see the pictorial JeffR did? It's in pdf form and there are lots of ideas from other members. Check it out. |
| Subject: Re: prep for final drive oil change Mon Sep 16, 2013 12:04 pm | |
| No need to warm it up --unless it's pretty darn cold in your garage. "Room temp" is good enough. Just drain & refill. Use the same oil as you use in the engine, and put it in using a syringe.
| Subject: Re: prep for final drive oil change Mon Sep 16, 2013 12:40 pm | |
| Thanks, Tim. Just what I was looking for. I've seen the pics by Jeff too. Very informative. |
| Subject: Re: prep for final drive oil change Mon Sep 16, 2013 2:16 pm | |
| Just got it done. Had to improvise the delivery tool. Used the inner straw inside a squirt bottle and the syringe from the vet when my dog was prescribed allergy meds. It came with a flexible length of plastic tubing, which mated perfectly with the straw. It took me a while because the syringe was only 10 ml, and it took about 25 refills; didn't have anything else to play with this afternoon. In all fairness I think the PO had this item serviced not too long ago: oil was green and fairly clear. But my PoM is worth the trouble. |
Dimond Silver Wing Expert
Number of posts : 540 Age : 79 Location : San Francisco Bay Area Points : 5528 Registration date : 2011-08-07
| Subject: Re: prep for final drive oil change Mon Sep 16, 2013 3:32 pm | |
| The 'oil can' from Harbor Freight works great - but not sure if you have Harbor Freight near you. |
| Subject: Re: prep for final drive oil change Mon Sep 16, 2013 3:55 pm | |
| There are other auto supplies stores but a big one is opening soon. Will be interesting to see its inventory. I am frequently in Calais, Me, but it is a small town and only has a Wally. |
| Subject: Re: prep for final drive oil change Mon Sep 16, 2013 4:04 pm | |
| Guessing you can get an oil can just about anywhere! |
