| ABS Model ???? | |
pauldeere Scooter Rider
Number of posts : 19 Location : SW ohio Points : 4083 Registration date : 2013-09-19
| Subject: ABS Model ???? Sun Sep 22, 2013 7:50 pm | |
| I recently purchased a 2007 Silverwing. I've ben reading as much as I can on this forum to educate myself particularly on maintenance items. I see mentioned that some models are equiped with ABS brakes and some are not. Question: How can I tell if my Scoot is a ABS model?... Thanks in advance..... |
LN Scooter Rider
Number of posts : 64 Location : Austin TX Points : 4533 Registration date : 2012-08-18
| Subject: Re: ABS Model ???? Sun Sep 22, 2013 9:42 pm | |
| My first bike was without ABS and I was very close to die to many times. If I only had an ABS model, I would've been able to avoid the car in front of me. Both my wheels locked and I went for a sleigh ride in the last direction I was pointing ... powerless. Search on YouTube for ABS motorcycle test. I personally think that should be illegal to sell a bike without it. There is no way a human can pulsate the brakes as fast as the ABS does. ABS / NON ABS 1. Turn bike on. Does the first light on the left stay ON RED ? ABS 2. Look at the front wheel. Left side, as you are sitting on it. See the round holes from the brake disk...that is not it, look closer. You will see a small ring , the size of your palm with many rectangular holes in it. ABS Picture on the left is the ABS model . The one on the right is not http://www.honda.co.jp/SILVERWING/equip/brake/image/pic01.jpg See the ring with the little holes. You will be able to see that on any bike just by looking at the front wheel 3. The same ring is on the rear wheel. ABS Good luck |
Number of posts : 2616 Age : 72 Location : Bullhead City, AZ Points : 7480 Registration date : 2012-05-17
| Subject: Re: ABS Model ???? Mon Sep 23, 2013 9:28 am | |
| Paul, your SWing may have ABS or not. Check the pic above and you should be able to tell. My 2012 came with ABS as it is no longer an option. Now after having it over a year I would not likely switch to a bike without that feature. True for years we got by without it on our 2 wheelers, as we did in our cars. BUT this feature works so well and requires no particular service, in fact does not even come in to play UNLESS you need it, so for safety's sake it is a good option. My son was on a freeway in So. Cal last week and (on a KLR 650) was immediately behind an accident, in fact he locked up his rear tire to avoid rear-ending one of the vehicles. He started to slide and rear tire started to swing out...he released brake and was able to control the bike and avoid the accident by inches. Point is he has a worn spot on his new rear tire now and ABS would have helped him loads. He is a very experienced rider and a professional driver, I shudder to think of the end result for a beginning bike rider. End of sermon for today! |
Number of posts : 4214 Location : York, North Yorkshire, England UK Points : 9418 Registration date : 2010-11-16
| Subject: Re: ABS Model ???? Mon Sep 23, 2013 12:10 pm | |
| It's even simpler on an FJS Silver Wing, the front mudguard/fender has ABS & Combined Brake System printed in big lettering on each side. Don't forget you've got to pull the brakes on hard enough for the ABS to kick in and that's normally harder than on a non ABS equipped motorcycle or scooter. Also you're conditioned not to lock up the brakes, I've felt the ABS pulsing through the handlebars quite early on my 650 Burgman but I've never noticed it on the Silver Wing. |
Dimond Silver Wing Expert
Number of posts : 540 Age : 79 Location : San Francisco Bay Area Points : 5509 Registration date : 2011-08-07
| Subject: Re: ABS Model ???? Mon Sep 23, 2013 4:35 pm | |
| Guessing that you asking the question means it is not ABS - please let us know. If not, ride the SWing and see how you like it - maybe keep it for a while. If you like it and ride it often then IMHO you should buy one with ABS and then sell your 2007 - you will not regret this move. |
| Subject: Re: ABS Model ???? Mon Sep 23, 2013 7:34 pm | |
| Checking the scoot, using the pics. as guidlines, my 2007 is not ABS........Thanks for the info.... |
cotetoi Silver Wing Expert
Number of posts : 757 Location : New Brunswick, Canada Points : 5040 Registration date : 2013-06-27
| Subject: Re: ABS Model ???? Tue Sep 24, 2013 12:39 pm | |
| I checked my 2005 scoot for the distinguishing rings on the brakes. They are there, and so is the ABS light on the dash. I read somewhere that this is a $1000.00 option. I got a great bike for a great price !! I love every minute I ride on it. |
Mr Magic Fingers Scooter Rider
Number of posts : 24 Location : Dartmouth, Nova Scotia, Canada Points : 4091 Registration date : 2013-09-14
| Subject: Re: ABS Model ???? Sat Oct 05, 2013 7:25 am | |
| - Meldrew wrote:
- It's even simpler on an FJS Silver Wing, the front mudguard/fender has ABS & Combined Brake System printed in big lettering on each side.
This is not always the case... at least around here. I have looked at several Swings before I purchased this one for my wife. A few had the ABS feature but none had the graphics on the front fender. Look for the ABS light and the inner rotational disc. Also, the model number has the letter "A" at the end somewhere I think, though not 100% sure. In any respect, I am making up a custom graphics package for her and having the vinyl cut by a local shop. It will feature a unique ABS logo among others. She loves the idea that it is a Silverwing... a little sister to our Goldwing and wants the same pin striping so they will match. Tim. |
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8534 Registration date : 2010-02-17
| Subject: Re: ABS Model ???? Sat Oct 05, 2013 8:16 am | |
| Tim, the Swings you looked at were probably not the FJS version. Different areas of the world get different ones. This is one reason we encourage new members to introduce themselves. I hope we see some pictures of your graphics package. It sounds interesting. |
| Subject: Re: ABS Model ???? Sat Oct 05, 2013 10:36 am | |
| Yes… Hers is an FSC600 according to the paper work. A Canadian version I guess?
I am still learning the in’s and out’s of this bike. I know when I look up the fender on some of the on-line parts houses; they show the fender with the ABS decal on it.
Anyhow, it will get some “bling” over the next few months.
Tim.
| ABS Model ???? | |
