Latest topics | » It's that time of year again. by Meldrew Today at 3:31 pm
» Silverwing 600 Owner by GHM-PM Today at 6:47 am
» I Need Help With The Brake Bleeding by zrx212 Sun Oct 20, 2024 4:57 pm
» New FPR, new vacuum pipes, still 22mpg by zrx212 Sun Oct 20, 2024 4:35 pm
» A strange howl by 53Scooterguy Sun Oct 20, 2024 11:56 am
» Tip For Bleeding Brakes by zrx212 Sun Oct 20, 2024 9:58 am
» Brake/Start Switch Availability by GHM-PM Sat Oct 19, 2024 7:31 am
» Passenger Back rest by Meldrew Sat Oct 19, 2024 4:36 am
» OE Quality Drive Belt by landisr Wed Oct 16, 2024 1:11 pm
» Mini-Mate Camper by MikeO Wed Oct 16, 2024 7:17 am
| Fuel Pressure Regulator Assembly Tips and part #'s | |
Number of posts : 2387 Location : Winnipeg Points : 7877 Registration date : 2010-05-02
| Subject: Fuel Pressure Regulator Assembly Tips and part #'s Mon Oct 07, 2013 10:18 am | |
| A quick heads up. As your Swing gets older, the likelihood of a fuel pressure regulator failure increases. The rubber diaphragm inside dries out, and pinhole leaks can develop. The leaks cause engine vacuum to suck fuel into the the intake manifold, causing a rich running condition.The symptoms of failure range from stalling shortly after the engine is started, to a no-start flooded engine situation. There are 2 different regulators, depending on your engine serial number.
For engines up to and including S/N 6301885, use regulator part # 16740-MCT-013
For engines with S/N 6301886 and higher, use regulator part # 16740-MFT-641
As always, when replacing the regulator, also install a new O-ring, part # 91302-MCA-000, and do not use any lubrication on the O-ring.
The engine serial # can be found on the left side of the bike, right behind the air cleaner chamber drain hose sticking out below the engine.
This fix is an easy DIY. Despite the service manual saying the intake manifold has to come off, a big job, it doesn't. This can easily be done by just removing the under seat cover, as if you were going to only adjust the throttle plate synchronization.
| | | robert Super Scooter Rider
Number of posts : 267 Age : 81 Location : arizona Points : 5433 Registration date : 2010-09-19
| Subject: Re: Fuel Pressure Regulator Assembly Tips and part #'s Mon Oct 07, 2013 10:46 am | |
| Thanks for the tip bigbird, might be the reason why my 2008 S/W is starting to run a little rough. I'am changing plugs and air filter, if that does,nt fix it, I'll check out the fuel press. reg. |
| Subject: Re: Fuel Pressure Regulator Assembly Tips and part #'s Mon Oct 07, 2013 10:57 am | |
| - robert wrote:
- Thanks for the tip bigbird, might be the reason why my 2008 S/W is starting to run a little rough. I'am changing plugs and air filter, if that does,nt fix it, I'll check out the fuel press. reg.
After doing your maintenance, I'd suggest synching the throttle plates before digging into the fuel pressure regulator. If your plugs are not showing signs of rich running, then definitely synch first. |
Number of posts : 4214 Location : York, North Yorkshire, England UK Points : 9412 Registration date : 2010-11-16
| Subject: Re: Fuel Pressure Regulator Assembly Tips and part #'s Mon Oct 07, 2013 12:27 pm | |
| - bigbird wrote:
- A quick heads up. As your Swing gets older, the likelihood of a fuel pressure regulator failure increases.
That's also true of all us old git's that ride them! |
Number of posts : 4415 Age : 81 Location : damn near Philadelphia, PA Points : 10715 Registration date : 2009-06-12
| Subject: Re: Fuel Pressure Regulator Assembly Tips and part #'s Mon Oct 07, 2013 7:20 pm | |
| Hmmm... I wonder what the difference between the two FPRs could be? That engine # change appears to be from around 2008-2009, just about the time they added the O2 sensor.
If they changed the operating pressure for the injectors I wonder if it's possible to find out the setting of the newer FPR? Is that pressure change covered as an addendum to the Service Manual?
| | | gizmoguy Scooter Rider
Number of posts : 21 Location : portland oregon Points : 4173 Registration date : 2013-06-23
| Subject: Re: Fuel Pressure Regulator Assembly Tips and part #'s Wed Dec 04, 2013 8:41 pm | |
| I found the regulator for my bike on partzilla . Com for $36 (mct version for my 2005) Any idea what part number the silly o ring is?
Thanks for awesome info on how easy it is to swap .
Mike <>< |
| Subject: Re: Fuel Pressure Regulator Assembly Tips and part #'s Wed Dec 04, 2013 10:07 pm | |
| O-Ring (7.8 x 1.9) 91302-MCA-000
