HORNBLOWER Maxi-Scooter Rider
Number of posts : 171 Age : 69 Location : Birmingham UK Points : 4269 Registration date : 2013-10-08
| Subject: Handbrake light. Tue Dec 03, 2013 12:46 pm | |
| When I bought my Silverwing the hand brake hardly worked and the dash light was intermittent. I adjusted the hand brake and to start with the dash light worked perfectly, during the past week the thing has stopped working and briefly flashed once today as i pulled the brake on. Is this a common fault and any ideas where to start to sort it out please. |
| Subject: Re: Handbrake light. Tue Dec 03, 2013 12:56 pm | |
| Sounds like dirty switch contacts to me.
You can remove the right side glove box and located the hand brake switch there. It's not at all convenient to actually get your hands on in that location but, perhaps, you can spritz the switch with electrical contact cleaner or WD40 so that the switch works better
| Subject: Re: Handbrake light. Wed Dec 04, 2013 7:28 pm | |
| Thanks for that Tim Ill start taking things to bits and get my 12 year old son to get his hands in there. Andy |
peter hayward Scooter Rider
Number of posts : 2 Location : Mijas, Spain Points : 3729 Registration date : 2014-09-11
| Subject: Re: Handbrake light. Fri Sep 12, 2014 5:39 pm | |
| Just bought my elderly Wing and the handbrake doesn't work at all. Is this an easy fix for an amateur? |
| Subject: Re: Handbrake light. Fri Sep 12, 2014 7:59 pm | |
| It depends on what's wrong. Does the handle pull up at all? A service manual is a must have if you plan to service your scooter yourself. I highly recommend picking one up. |
