NWSSC Silver Wing Rider
Number of posts : 418 Age : 87 Location : Mt Prospect IL 30 miles west of Chicago Points : 5848 Registration date : 2010-03-03
| Subject: Dealing with hard to find stripped bolts. Mon Feb 10, 2014 7:59 pm | |
| On occasion I've had to repair threads on bolts (metric or otherwise) that were not readily available nor did I have a dye to chase the thread.You can make such tool from a section of fine tooth hacksaw blade about 4-6 inches long.Round off one end and sharpen it(similar to a knife blade edge)to narrow it so it will fit into the thread pattern.Install the bolt in a vice to hold it and gradually trace the pattern around the bolt.With a little patience it will work every time. |
DickO Founding Member
| Subject: Re: Dealing with hard to find stripped bolts. Mon Feb 10, 2014 10:22 pm | |
| "NWSSC", Great idea; I'll try that one of these days if I happen to be in a bind. One of the handiest tools I've ever owned however, was a machinest's thread file. The one I have has worked wonders on the (I guess) SAE threads I've had to deal with. It is a double ended (half and half) six inch hand held unit that contains eight different thread sizes. Works about as good as anything I've run in to, other than a tap and die set. Anyway, thanks for the new suggestion. Question.... just pure curiosity... What does the NWSSC, stand for?? |
| Subject: Re: Dealing with hard to find stripped bolts. Mon Feb 10, 2014 10:42 pm | |
| Thank you. You are most welcome. NWSSC- North West Suburban Scooter Club. The club was organized about 10 years ago and covers a radius of approximate 75 miles north and west of Chicago. Wanted more or less of a generic name that would not discriminate. |
