badaboum Scooter Rider
![badaboum](https://2img.net/u/3413/63/00/33/avatars/2916-78.jpg)
Number of posts : 58 Location : Paris Points : 4210 Registration date : 2013-05-23
![Noise suppressor Plug change Empty](https://2img.net/i/empty.gif) | Subject: Noise suppressor Plug change Wed Mar 05, 2014 3:30 am | |
| Hey guys, I have an SWT which is basicaly the same engine as the Silverwing 400. I have my ''noise supressor'' 30700-KY2-701 that is defective and I got a new one. How do I remove the wire going into the plug ? ![Noise suppressor Plug change Cap-assy-noise-s_medium30700KY2701-01_4c6b](https://2img.net/h/images.cmsnl.com/img/products/cap-assy-noise-s_medium30700KY2701-01_4c6b.jpg) Thanks |
![Noise suppressor Plug change Empty](https://2img.net/i/empty.gif) | Subject: Re: Noise suppressor Plug change Wed Mar 05, 2014 8:17 am | |
| Ok guys,
I have found the solution...
Just need to pull a bit stronger than what I did..
subject closed |
![Noise suppressor Plug change Empty](https://2img.net/i/empty.gif) | Subject: Re: Noise suppressor Plug change Wed Mar 05, 2014 8:19 am | |
| Unscrew the cap from the wire. Don't twist the wire --it will/may break internally. |
![Noise suppressor Plug change Empty](https://2img.net/i/empty.gif) | Subject: Re: Noise suppressor Plug change Wed Mar 05, 2014 8:21 am | |
| Well I have applied a mouvement of unscrewing and pulling at the same time
The swapping of the new part was the same
The engine is starting
waiting for the first rain to see if some humidity is stopping me from starting the engine... |
![Noise suppressor Plug change Empty](https://2img.net/i/empty.gif) | Subject: Re: Noise suppressor Plug change Wed Mar 05, 2014 12:54 pm | |
| I have seen a couple of incidents here where rain & humidity have effected the coil as well as the plug wires, causing the scoot to either not start, or to cut out while at speed. Microscopic cracks in the coil body causing moisture to effect the coil function.
So the message here is that, if your noise supressor/plug cap fix doesn't solve the problem, then bit the bullet and replace the coil AND plug wires.
One Honda shop replaced the coil and then used similar plug wires from another model. And while the fix worked initially it soon failed again because those (incorrect) plug wires were causing too much resistance, or impedience, or something like that. When the plug wires were replaced with Silverwing-specific wires all was, and remains, well. HTH
![Noise suppressor Plug change Empty](https://2img.net/i/empty.gif) | Subject: Re: Noise suppressor Plug change Thu Mar 06, 2014 6:13 am | |
| Hey
I have experienced some issue with the system refusing to start during winter pourring rains.
I found out that each time my cap was a bit ''not in position''
It was actually a bit damager (one rubber part was worn)
I hope that replacing it will remove this issue
