errant clock I_icon_minitimeby sonuvabug Yesterday at 4:19 pm
errant clock I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
errant clock I_icon_minitimeby sonuvabug Yesterday at 4:06 pm
errant clock I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
errant clock I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
errant clock I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
errant clock I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
errant clock I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
errant clock I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
errant clock I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 errant clock
BeechLeaf
Number of posts : 2
errant clock Empty
PostSubject: errant clock   errant clock I_icon_minitimeTue Apr 08, 2014 4:11 pm
Hi! Last year I purchased a used 2002 SWing that only had about 2,000 miles on it. It runs great! My only "problem", annoyance really, is that every time I start 'er up, the clock shows 1:00AM.  How can I fix this?
JeffR_
JeffR_
Number of posts : 1103
errant clock Empty
PostSubject: Re: errant clock   errant clock I_icon_minitimeTue Apr 08, 2014 4:16 pm
Move to somewhere where it is always 1:00am. problem solved.
errant clock Empty
PostSubject: Re: errant clock   errant clock I_icon_minitimeTue Apr 08, 2014 4:58 pm
That's mighty strange. The clock circuit is part of the Meter Control board. Usually the clock will default to 12:00 and the Trip odometers default to zero if the battery is disconnected or the Meter Panel is disconnected. But the clock remains running and the trip odos retain their miles if the ignition switch is turned OFF.
Why your clock defaults to 1:00 is puzzling. Do your trip odos zero out as well? If so then possibly you may have a problem with the ignition switch breaking the circuit to the Meter board. if the odos retain their miles and the clock resets then you might have to check with your Honda dealer service manager orntech to see if there is a service bulletin issued for that problem.
In any case, please let us know what the resolution may be.
Last minute thought: Check for a loose or corroded connection at the 16pin/12pin wire harness connection at the front side of the Meter Control board. Youll have to remove the windshield garnish (the W shaped panel) to see that plug.
Number of posts : 2008
errant clock Empty
PostSubject: Re: errant clock   errant clock I_icon_minitimeTue Apr 08, 2014 5:04 pm
Does it default to 1:00am or 1_:00 am?
If the latter you have two problems.
1. No constant power to the dash (likely a short)
2. A defective LCD display at the clock.
BeechLeaf
Number of posts : 2
errant clock Empty
PostSubject: Re: errant clock   errant clock I_icon_minitimeTue Apr 08, 2014 9:05 pm
JeffR- thats an awful lot of moving! What do you propose I do when I need to cross oceans/deserts/tundras?  Shocked  Razz
Cosmic Jumper- The trip odometer also resets to 0.0 every time, yes. I'll have to figure out what the meter control board is and the removal of such tomorrow. I'm a little bit excited. I'm a first time bike owner and I did my very first 2-wheeler oil change today (thank you, forum, for the pointers!) I'm hoping I can also fix that little issue myself as well.
dspevack- it defaults to 1:00am.
Thank you all for your suggestions!
jmaslak
Number of posts : 252
errant clock Empty
PostSubject: Re: errant clock   errant clock I_icon_minitimeTue Apr 08, 2014 10:30 pm
It may be that your battery is weak.
errant clock
» clock setting
» Clock Reset merge
» Clock issues
» World Clock
» Problem - with KEEPING the clock set
