jwt827 Scooter Rider
Number of posts : 11 Age : 87 Location : Akron Ohio Points : 4136 Registration date : 2013-08-14
| Subject: senser for drive belt light Tue May 06, 2014 6:29 pm | |
| Does anyone know where the senser is located and how it works ?What makes the v light come on? I have replaced the drive belt and the rollers,rode the bike for 50 miles or so,no problem the ride I took today the light came on ,I extinguished the light by holding down the two buttons then turning on the ignition the light flashed several times then went out as soon as I started off again the light came back on I did the same proceedure several times but the light would not stay off.I replaced the belt and the rollers according to the video post on this forum and all seems well except for the light problem,any info would be appreciated. |
| Subject: Re: senser for drive belt light Tue May 06, 2014 7:03 pm | |
| Beside coming on at 16,000 miles, the V light can be triggered by the relationship between engine RPM and rear wheel speed. That is to say that if the RPMs are too high for the speed then the Combination Meter will "see" that anomily as the belt being worn and slipping.
The V light has been known to come on if Dr Pulley sliders are installed and when aggressively accelerating. Because, when initially accelerating, the Dr Pulleys put the engine RPMs much closer to the optimum power band of the engine.
That said, I have no idea why your V light is triggering.
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4809 Registration date : 2012-06-15
| Subject: Re: senser for drive belt light Tue May 06, 2014 7:58 pm | |
| I agree with Cosmic_Jumper.
Since it didn't come on before you changed your belt, but it does come on now, and you don't mention messing with anything else, my guess is that you did something wrong putting the belt on. Are you sure the front pulley was not catching on the belt when you tightened it? It's important that you don't tighten against the belt.
It's also vital that you use the proper torque with a torque wrench. Too loose and the bolt comes out and you can break the splines on the front pulley (among other things). Too tight and the bolt will deform (it's a very special bolt that needs exact torque) and loosen after a bit (if you tightened it too much, you need a new bolt). I do NOT recommend using an impact wrench instead of a pulley holder either - that can also result in improper torque (and it's a bad idea for other reasons).
If you put in weights that are very light, that can also cause this I hear. I run 26g Dr. Pulley sliders with no V light ever, and I ride fairly aggressively. If you used Dr. Pulley weights, it's possible that you installed the weights wrong (there's a proper orientation). It also might be possible that the weights are somehow hung up or out of alignment.
I would NOT ride the scooter until you (or someone else) looks at that front pulley. I'd also inspect the splines on the crankshaft and front pulley (hopefully if you see any wear it's on the front pulley - if you do see wear, you need to replace the front pulley). |
