| Remove trunk light bulb ... help | |
+11bikerboy Old Limey ScooterBJ Colin B Meldrew ericclapham GHM-PM dspevack KurtPerthWA Dale N. Greysilver 15 posters |
Greysilver Silver Wing Rider
Number of posts : 493 Age : 78 Location : Arizona Points : 4420 Registration date : 2014-04-08
| Subject: Remove trunk light bulb ... help Wed May 14, 2014 8:37 pm | |
| I did a search, this topic and found about removing the light bulb. Ok, got that. How do I get the plastic cover off? I see no screws. (No, I have not pit crewed for Jackie Stewart). Thank you for your answer. |
Number of posts : 1999 Age : 78 Location : Princeton, MN Points : 6077 Registration date : 2014-02-13
| Subject: Re: Remove trunk light bulb ... help Wed May 14, 2014 11:09 pm | |
| You just have to pry it off. I forget whether the tabs are on the sides or front and back. I just used a small screwdriver to get mine off. |
KurtPerthWA Silver Wing Guru
Number of posts : 1711 Age : 75 Location : Belmont, Perth WA Points : 8160 Registration date : 2009-01-19
| Subject: Re: Remove trunk light bulb ... help Thu May 15, 2014 6:29 am | |
| Replace the globe with LED globe. That way it will still start in the morning if your seat doesn't latch properly. |
dspevack Silver Wing Guru
Number of posts : 2008 Age : 59 Location : Miami, FL Points : 8213 Registration date : 2008-12-27
| Subject: Re: Remove trunk light bulb ... help Thu May 15, 2014 8:36 am | |
| There is also a drop in replacement of that fixture which adds a switch to it. This way you can manually switch it on and off and never have to worry about whether the seat has latched properly. Its about $25+shipping.
Dan |
Number of posts : 2625 Age : 72 Location : Bullhead City, AZ Points : 7517 Registration date : 2012-05-17
| Subject: Re: Remove trunk light bulb ... help Thu May 15, 2014 8:59 am | |
| I installed the Honda/Acura unit that mentions above. It works slick and is easy to install. Do a search on here for the exact part number (that is what I did). Or simply remove the bulb altogether... |
Number of posts : 106 Age : 81 Location : Adelaide,Sth.Australia Points : 4087 Registration date : 2014-01-30
| Subject: Re: Remove trunk light bulb ... help Thu May 15, 2014 1:11 pm | |
| GHM-PM and/or dspevack - More info perleeeeease!!!Do a search on where ???? "It's about $25 + shipping."- from where???? |
Number of posts : 4218 Location : York, North Yorkshire, England UK Points : 9448 Registration date : 2010-11-16
| Subject: Re: Remove trunk light bulb ... help Thu May 15, 2014 1:42 pm | |
| Why don't you just remove the bulb and buy a $5 LED light, and keep it under the seat. |
Colin B Silver Wing Expert
Number of posts : 586 Age : 72 Location : Windsor, UK Points : 4914 Registration date : 2013-03-20
| Subject: Re: Remove trunk light bulb ... help Thu May 15, 2014 1:50 pm | |
| Agreed! The built in light is pretty useless, once you have anything under the seat, as the light from it is obscured. Stick a light to the underside of the seat. NO chance then of flattening the bike's battery if you don't fully close the seat. |
| Subject: Re: Remove trunk light bulb ... help Thu May 15, 2014 3:13 pm | |
ScooterBJ Maxi-Scooter Rider
Number of posts : 170 Location : Colorado USA Points : 4248 Registration date : 2013-11-14
| Subject: Re: Remove trunk light bulb ... help Thu May 15, 2014 5:54 pm | |
| I removed my entire light, sealed off the wires and made a cover for the hole. I never trusted the light anyway. |
| Subject: Re: Remove trunk light bulb ... help Thu May 15, 2014 6:49 pm | |
| Thank you everyone. I'm sure I'll remove at least the bulb and eventually the fixture. It looks exactly like a misfortune waiting to happen. I'll probably get an LED light and keep it in the trunk. |
Old Limey Silver Wing Expert
Number of posts : 921 Age : 80 Location : BOLTON LANCASHIRE ENGLAND Points : 6298 Registration date : 2010-06-09
| Subject: Re: Remove trunk light bulb ... help Fri May 16, 2014 2:27 pm | |
| Greysilver by all means remove the bulb(one of the first things i did) but, don't take the fitting out. You may want to sell in the future,as i intend doing soon so you just have to put the bulb back. Dennis B has many fittings and advice on bypassing unwanted things, but his advice is always do not cut or remove any standard fittings or joints. |
| Subject: Re: Remove trunk light bulb ... help Sat May 17, 2014 1:24 am | |
| TY Limey, I did exactly that, remove bulb, replace plastic lens and keep bulb in an envelope. I don't have the expertise to remove the mount anyway. |
bikerboy Silver Wing Rider
Number of posts : 405 Age : 81 Location : Leyland England Points : 5373 Registration date : 2011-05-12
| Subject: Trunk light bulb Sat May 17, 2014 1:44 am | |
| I replaced my fitting with the switched one but hardly ever used it. It's probably easier to carry an LED torch in the glove box, it is a lot more versatile and useful out on the road. |
| Subject: Re: Remove trunk light bulb ... help Sat May 17, 2014 7:23 am | |
| - bikerboy wrote:
- I replaced my fitting with the switched one but hardly ever used it. It's probably easier to carry an LED torch in the glove box, it is a lot more versatile and useful out on the road.
I agree, I replaced mine with the switched model and use it seldom but it does look good and if I ever sell won't have to swap them back out. I carry a small LED flashlight up near the owners manual for serious light. |
mslinda Scooter Rider
Number of posts : 8 Location : Ft Myers, Forida Points : 3841 Registration date : 2014-06-02
| Subject: Trunk Light Blub Mon Jun 02, 2014 7:10 pm | |
| I had the same thing that happened to me when I got my silverwing. Left the seat up and came out 2 days later and bike was dead. Charged the battery, got it to work and removed the trunk bulb, as I don't use it at all.
| Subject: Re: Remove trunk light bulb ... help Mon Jun 02, 2014 10:04 pm | |
| I just order several of these: http://tinyurl.com/oma5dzm and keep them on hand in all my vehicles. They run on AA batteries and are very bright. |
hotwings Silver Wing Expert
Number of posts : 876 Age : 54 Location : Ontario Points : 5568 Registration date : 2012-04-29
| Subject: Re: Remove trunk light bulb ... help Tue Jun 03, 2014 3:25 pm | |
| Removing the bulb is admitting your old (Dspevack are these words soft enough ) |
| Subject: Re: Remove trunk light bulb ... help Tue Jun 03, 2014 3:42 pm | |
| - hotwings wrote:
- Removing the bulb is admitting your old
But old people at least had an education that taught the difference between 'your' (belonging to you) and 'you're' (abbreviated form of 'you are'). Anyway, what's your point |
| Subject: Re: Remove trunk light bulb ... help Tue Jun 03, 2014 5:21 pm | |
| I think that removing the bulb avoids the problem, while the switch fixture corrects the problem, and there is nothing wrong with either one.
I don't know what age has to do with that. |
| Subject: Re: Remove trunk light bulb ... help Wed Jun 04, 2014 6:27 am | |
| Collinb- never wuz wun fer dat fancy book lurnin, |
| Subject: Re: Remove trunk light bulb ... help Wed Jun 04, 2014 8:29 am | |
| I think because I bought my SWing new it made a difference. I was more inclined to replace the fixture than simply remove the bulb. Now if the scoot had been 10 years old... In any case, either solution works and I KNOW from experience during the last two years that had I not read on this forum about the problem I would have had at least one dead battery. The seat just does not always close properly although it looks like it does.
So regardless which approach you use... Use one!!! |
LDB Maxi-Scooter Rider
Number of posts : 157 Age : 67 Location : Houston Points : 4044 Registration date : 2014-05-19
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 12:38 am | |
| I'm thinking remove the bulb and stick one of these to the bottom of the seat. I just have to be sure it isn't in the area where my helmet parks while I'm off the bike. I don't think there would be enough clearance.
http://www.bedbathandbeyond.com/store/product/stick-n-39-click-lights-set-of-3/1014296999 |
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 6:40 am | |
| - LDB wrote:
- I'm thinking remove the bulb and stick one of these to the bottom of the seat. I just have to be sure it isn't in the area where my helmet parks while I'm off the bike. I don't think there would be enough clearance.
http://www.bedbathandbeyond.com/store/product/stick-n-39-click-lights-set-of-3/1014296999 The only issue with the stick on lights is the glue that holds the light seems to melt when the bike is in the sun on those hot summer days, making the light fall off. Tried it on my topbox but keeps falling off. Maybe a little epoxy would fix this, but would make the cheap light permanent!! |
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 7:46 am | |
| - hotwings wrote:
http://www.bedbathandbeyond.com/store/product/stick-n-39-click-lights-set-of-3/1014296999 The only issue with the stick on lights is the glue that holds the light seems to melt when the bike is in the sun on those hot summer days, making the light fall off. Tried it on my topbox but keeps falling off. Maybe a little epoxy would fix this, but would make the cheap light permanent!! I used one of these lights in my left front cubby and it worked great. But as was stated it fell off relatively quickly... I glued it with an epoxy type glue and it has been attached for over 2 years with no problems. |
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 10:59 am | |
| If you are going to use a light other than the built in one, I recommend something like this. You can keep it in your hand or wear it like a headband and put light where you want it. Dan |
Number of posts : 2387 Location : Winnipeg Points : 7909 Registration date : 2010-05-02
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 3:06 pm | |
| They also come in handy if you're ever doing any shaft mining. Open pit, not so much. |
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 3:29 pm | |
| - hotwings wrote:
If riding a scooter dont keep you humble, strapping this to your head to get something will! I guess it will be at night so hopefully you wont get noticed I don't think it takes humility to use this. Its a tool. Based on the tone of your comment I would guess you think choosing not to use it is a function of vanity. |
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 3:43 pm | |
| - bigbird wrote:
- They also come in handy if you're ever doing any shaft mining.
Open pit, not so much. :lol!: |
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 4:36 pm | |
I think only a tool would wear such a tool while driving their scooter. |
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 4:52 pm | |
| - bigbird wrote:
- dspevack wrote:
- I don't think it takes humility to use this. Its a tool.
I think only a tool would wear such a tool while driving their scooter. Ignoring for a moment that that's a derogatory and unnecessary comment, similar to JG saying. "Only real riders yatta yatta"... We were referring to wearing this while standing over your bike trunk or open seat using it to see whatever it is you are doing. Sometimes you need two hands, and a fixed light on the interior top of your seat or trunk can end up giving you shadows where your arms and hands are. Putting on a headlight means the light is always where you need it. Now back to what I was ignoring....do I need to spell it out for you further Terry? |
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 7:47 pm | |
| Sorry, I misinterpreted. All I could picture was a scooter rider wearing one in lieu of a headlight. To keep one in the seat storage area would be a good idea in an emergency. |
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 8:18 pm | |
| - bigbird wrote:
- Sorry, I misinterpreted. All I could picture was a scooter rider wearing one in lieu of a headlight. To keep one in the seat storage area would be a good idea in an emergency.
Although I've never done it because there have always been better alternatives.... The theory of the third brake light being central and high for other drivers to better notice also applies to headlights. So if one was going to extremes to be careful...on say, a rental scooter that did not have additional lighting...wearing a headlamp while riding would serve a valuable, though not aesthetic purpose. It would also have the benefit of lighting where you turn your head, where as your scooter would just light directly in front of you. Amusingly, if at night you turn your head a lot, or bounce your head in time with the music, you would appear as a lunatic driver to oncoming traffic. They would definitely steer clear of you. Necessity is often the mother of invention, but rarely fashion. (Good save btw) Dan |
| Subject: Re: Remove trunk light bulb ... help Mon Jun 23, 2014 11:11 pm | |
| Subject: Re: Remove trunk light bulb ... help Wed Jun 25, 2014 6:40 am | |
| I too opted for the light with switch for the trunk. As some have previously stated, it was not quite a 5min.job,mainly because the two springy plastic retainer lugs did not have enough give to allow the assy.to be pushed into the existing cut-out.This was overcome by a little "adjustment"wih a heat gun! As a portable torch ,I use a little gizmo called a Blocklite Mini Compact. |
| Subject: Re: Remove trunk light bulb ... help Wed Jun 25, 2014 7:26 am | |
| I can see myself turning on the switchable light and forgetting to turn it off just as likely as the current light not turning off due to the seat being improperly latched. |
| Subject: Re: Remove trunk light bulb ... help Wed Jun 25, 2014 8:16 am | |
| - LDB wrote:
- I can see myself turning on the switchable light and forgetting to turn it off just as likely as the current light not turning off due to the seat being improperly latched.
Then you are probably a good candidate for removing the bulb totally... |
