| Trunk light switch. | |
+10Loosemarbles Meldrew Dale N. Garfeild Delray GoonerKev Cosmic_Jumper Easyrider john grinsel Nobody 14 posters |
Nobody Scooter Rider
Number of posts : 7 Age : 66 Location : UK Points : 1971 Registration date : 2019-07-09
| Subject: Trunk light switch. Fri Jul 26, 2019 11:47 am | |
| After a couple of no starts due to a flat battery I took out the trunk bulb and all is well. Can anyone tell me the location of the switch so I can check it? Cheers. |
| Subject: Re: Trunk light switch. Fri Jul 26, 2019 12:27 pm | |
| Just leave bulb out---get flashlite if necessary. Worked for me for over 90,000 miles. |
| Subject: Re: Trunk light switch. Fri Jul 26, 2019 1:03 pm | |
| Others like me have replaced the light fixture with the ones come in the Honda car trunk light. The mount and electrical connectors are the same. It comes with an on/off switch. Costs about $30 depending where you live. |
| Subject: Re: Trunk light switch. Fri Jul 26, 2019 1:55 pm | |
| The actual switch is part of one of the two seat latch mechanisms. Best to follow Mr Grinsel's advise. |
GoonerKev Silver Wing Rider
Number of posts : 409 Age : 70 Location : Reigate, Surrey, UK Points : 2510 Registration date : 2019-04-09
| Subject: Re: Trunk light switch. Fri Jul 26, 2019 5:52 pm | |
| Lose the Bulb and carry a Torch in there, no probs after that |
| Subject: Re: Trunk light switch. Sat Jul 27, 2019 12:42 am | |
| Thanks to you all for the advice Torch it is. |
| Subject: Re: Trunk light switch. Sat Jul 27, 2019 12:10 pm | |
| There are people who like to add junk(electronic) to the SilverWing----they probably do not ride much or go distant places---remember the bike has no kick starter/ability to be bump started. Less strain on battery always better----nice to have the thing start on cold morning in Canada or AK. I rode mine. |
Delray Touring Scooter Rider
Number of posts : 399 Age : 71 Location : Delray Beach FL Points : 2814 Registration date : 2018-07-07
| Subject: Re: Trunk light switch. Sat Jul 27, 2019 2:09 pm | |
| "There are people who like to add junk(electronic) to the SilverWing----they probably do not ride much"
One has nothing to do with the other. |
| Subject: Re: Trunk light switch. Sat Jul 27, 2019 4:37 pm | |
| Yes it does----keeping the electric original helps keep starting reliable, when you are in the strangest places-----and hate walking. try a long trip sometime. |
| Subject: Re: Trunk light switch. Sat Jul 27, 2019 4:44 pm | |
| Long trips keep the battery fully charged. |
| Subject: Re: Trunk light switch. Sun Jul 28, 2019 2:04 am | |
| Why argue about this old chestnut again, it's been well documented on here and other maxi scooter forums that an under seat/trunk light without a switch can and will flatten the battery if the seat isn't closed properly.
The Silver Wing's under seat light has always been useless as it's located right at the rear, it's spread of light is poor, and any large items stored near it will effectively block out the light.
In reality how often does anyone poke around under the seat in darkness looking for stuff. It's already been mentioned in similar topics over the years that removing the bulb and keeping a cheap torch or LED light under the seat is much more useful for this and other uses.
Even if you don't carry an alternative light source under the seat, just about everyone has a mobile/cell phone on them which has a Flashlight function in the Control Centre.
It's an altogether brighter LED light than that weedy bulb under the seat too. Go to any rock or pop concert these days and fans are waving their phones about, just like they used to do with cigarette lighters back in the day. |
| Subject: Re: Trunk light switch. Sun Jul 28, 2019 4:49 am | |
| Say's it all, Take bulb out & use a torch or the mobile Flash. Simples |
Garfeild Scooter Rider
Number of posts : 8 Location : Kent England Points : 1700 Registration date : 2020-04-02
| Subject: Re: Trunk light switch. Wed Apr 08, 2020 12:48 pm | |
| I’ve had trouble with other scooters, with under seat lights, particularly a burgman 400 which I fixed the non working Light, then it flattened the bloody battery, so I unfixed it again, end of problem. My silverwing light doesn’t work, so it’s going to stay that way, a cheap torch, or as meldrew says, use your phone, Will be a better light anyway. |
| Subject: Re: Trunk light switch. Thu Apr 09, 2020 12:49 am | |
| I did like everybody is saying and threw the bulb away just after I bought my 08 SWing. I have a small LED flashlight/torch under the seat and use that. |
| Subject: Re: Trunk light switch. Thu Apr 09, 2020 2:01 am | |
| There's no need to remove or throw the bulb away, just cover it with bubble wrap or similar so that the contacts are covered and it doesn't illuminate with the seat raised, and push it back into place.
That's the flat battery problem solved for you, and whenever you sell the Silver Wing you know as soon as you remove the wrap and put the bulb back in you have a trunk light that works again. |
| Subject: Re: Trunk light switch. Thu Apr 09, 2020 7:30 am | |
| Did anybody ever get to the bottom of this issue, i.e. where the fault lies? and is there a fix? |
| Subject: Re: Trunk light switch. Thu Apr 09, 2020 1:53 pm | |
| I think the 'fault', if that's what it is, lies almost completely with the rider who fails to shut the seat properly. I know mine is quite tight so I have to be careful; the seat, that is. |
| Subject: Re: Trunk light switch. Thu Apr 09, 2020 2:07 pm | |
| MikeO, are you saying that yours works OK without running the battery flat? |
| Subject: Re: Trunk light switch. Thu Apr 09, 2020 2:27 pm | |
| No, because the bulb had already been removed by the previous owner. In fact, I've removed the bulb myself in all the other maxiscooters I've owned. I became aware soon after I bought 'The Crowman' that, sometimes when I was riding, the seat came unlatched. I guess it could be adjusted but it's not worth the hassle. So far, I've remembered to check when I leave the bike. |
cookkees Scooter Rider
Number of posts : 12 Location : Pittsburgh, PA Points : 1648 Registration date : 2020-06-03
| Subject: Re: Trunk light switch. Thu Jun 04, 2020 7:44 pm | |
| - Dale N. wrote:
- I did like everybody is saying and threw the bulb away just after I bought my 08 SWing. I have a small LED flashlight/torch under the seat and use that.
So....how exactly does one remove the bulb? Any trick to it? |
| Subject: Re: Trunk light switch. Thu Jun 04, 2020 8:22 pm | |
| Nothing fancy. Pry the lens cover off and remove bulb. Don't short anything across bulb terminals and all good.
Welcome from the other side of the state. Allentown. I was out your way last fall Somerset and up to Erie after that. Took a quick tour of Flight 93 Memorial. Rt 30 is nice east of there closer to Pittsburg becomes suburbia with traffic and malls. |
| Subject: Re: Trunk light switch. Fri Jun 05, 2020 7:55 am | |
| - Meldrew wrote:
- There's no need to remove or throw the bulb away, just cover it with bubble wrap or similar so that the contacts are covered and it doesn't illuminate with the seat raised, and push it back into place.
That's the flat battery problem solved for you, and whenever you sell the Silver Wing you know as soon as you remove the wrap and put the bulb back in you have a trunk light that works again. Like Meldrew I was concerned about taking out the bulb cause I knew that if needed I would NEVER be able to find it. LOL I sprang for a new Honda/Acura part with a switch. Easy install and looks and works fine: https://www.hondapartsnow.com/genuine/honda~light~assy~34260-SH3-004.html That said the light is not great and I have only used it a couple of times since 2012 and I do carry a small flashlight/torch also. The main thing is to make sure it (light) doesn't run down your battery. |
| Subject: Re: Trunk light switch. Fri Jun 05, 2020 12:29 pm | |
