Rotella T5 ( energy saving )oil I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Rotella T5 ( energy saving )oil I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Rotella T5 ( energy saving )oil I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Rotella T5 ( energy saving )oil I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Rotella T5 ( energy saving )oil I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Rotella T5 ( energy saving )oil I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Rotella T5 ( energy saving )oil I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Rotella T5 ( energy saving )oil I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Rotella T5 ( energy saving )oil I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Rotella T5 ( energy saving )oil I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
tankyuong
Mudnman
Number of posts : 757
Rotella T5 ( energy saving )oil Empty
PostSubject: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeMon Nov 10, 2014 7:21 pm
Rotella heavy duty diesel oil is highly recommended by motorcyclists on other Honda motorcycle forums. I happened to pick up a  gallon of the stuff in Wal-Mart and realised when I got home that it is the energy saving type!
My question is: Will it work in the SWing, where there is not a wet clutch per se.?
Okay, I read the Rotella thread and realise that this is loaded question. However, I'd like to hear from people who have actually used it, and from those with expert knowledge of the SWing and its engine to voice an opinion as to the oil's suitability. All I know is that the SWing has no conventional clutch mechanism, so why would friction modifiers matter, if not actually benefit the engine?
I'm all ears. Thanks.
Mudnman
Number of posts : 218
Registration date : 2014-01-15
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeMon Nov 10, 2014 8:25 pm
T-6 is what I used.
Number of posts : 2387
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeMon Nov 10, 2014 8:32 pm
I'll chime in first.
You're right, there is no wet clutch, which the moly in the energy saving oil would eventually interfere with.
The other issue is the valve train. Motorcycle (and Rotella T and T6) oils have extra ZDDP (basically zinc) and other metals added to the oil to protect and lubricate the valve train. The high pressures and loads on diesel engines require better lubrication. Some people believe that the same extra protection is required for high rpm valve trains. If so, my question would then be, how come high rpm valve trains, like those in exotic engines such as Porsche to name one, don't require heavy duty diesel type oils?
So I don't believe that diesel or motorcycle specific oils are required for a non-wet clutch engine.
However, if it were me, and I have no scientific basis to go by, I would not run energy conserving oil in any engine whose manufacturer tells me to specifically not run energy conserving oil.
Honda knows a lot more what its engine's require for lubrication than I do. That's why even the Silverwing specifies a JASO MA rated oil, not an energy conserving oil.
I expect John Grinsel to chirp in shortly about how his gazillion miles of rubber band 2 wheeling have gone tickety-boo while using WalMart's cheap house brand automotive motor oil.
So, in the end, you have lots of opinions, but no definitive scientific answer.
tankyuong
tankyuong
Number of posts : 475
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeMon Nov 10, 2014 9:35 pm
i tried energy conserve oil once and didnt notice any difference
Number of posts : 2621
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeMon Nov 10, 2014 9:59 pm
I have used both also and noticed little or no difference. Used Rotella T-6 last time.
Tourezrick
Number of posts : 83
Registration date : 2014-09-12
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeTue Nov 11, 2014 12:05 pm
I'm a fan of Mobil 1, which I have used in a Prius, a Jaguar X Type, a '69 Corvette with a bored and stroked engine, oil cooler and Accusump. I only wish Mobil 1 had been around in the early '70's when I was racing sports cars! Have no doubt they would have saved me lots of grief.
That being said, and having 25,000 miles on the clock on my 2002, warranty issues are not a consideration any more. I would like to know why Honda sticks with its recommendation to not use synthetic, and would like to know what Honda race teams use in their engines.
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeWed Nov 12, 2014 2:24 pm
Well, deed done: T5 is in the crankcase, with Fram 6704 oil filter. SWing is down for the long winter sleep: battery off. She'll get a light beauty treatment a little later on and maybe a massage here and there. I've got a chair lined up in case she needs company.
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeThu Nov 13, 2014 2:19 am
Shouldn't bother the SW engine at all. The only consideration about friction modifiers in motorcycle usage is the problem with wet clutches. You don't want to reduce friction in a clutch. The engine in the SW is water cooled and not a high revving design. Demands are much the same as on a typical automobile engine and oils that are suitable for those are suitable for the SW or any other water cooled scooter that has a similar transmission system. If one kept very good fuel burn records the friction reducing oils might show a slight increase in mileage. I know my last SW had no problem with DELO and my current BMW650GT doesn't seem to mind either. DELO is an oil designed for diesel engines. I ran my 1500 Goldwing over 175,000 miles with the stuff and when I sold it the compression was still almost the same as new and it wasn't burning any oil between changes.
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeThu Nov 13, 2014 7:38 pm
Thanks for all the input, guys. That's exactly what I was looking for. Exavid, you reassured me tremendously. You have used the stuff yourself and your various rides had no problems. I have no problem either with the folks who stay with the manufacturers' recommendations. I am not cutting corners, just opting for a cheaper product that works just as good.
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeThu Nov 13, 2014 8:25 pm
Rolling Eyes Did Ex mention that he gives a life time warranty with all his oil recommendations?...But you've got ride the SW out to his place to collect on that warranty. Operative word here being 'ride'.
You might also take note that he doesn't actually ride a SW any longer. Wink
Now just where are Meldrew's acidic remarks or Mr Grinsel's well-aged research when we need them?
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeThu Nov 13, 2014 9:37 pm
Nooooooo, please don't go there!
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeFri Nov 14, 2014 12:36 am
Two subjects seem to get beaten to death on motorcycle forums. Lubricating fluid and those large black round rubber things.
Yes, I don't have a SW at the moment. I bought and sold two Silverwings and a Burgman 650 before finding my BMW650GT. None of the first three scooters had ABS which is mostly why I ended up with the GT. I won't rule out another SW in the future though. If I came across a nice one with ABS some day I might bite though it's hard to get a Jeep, car, K1100LT and more than one scooter in the garage. So many scooters to ride so little time... Though maybe if I sold my table saw...
Actually there were a couple of reasons I went with the GT. I bought it in February. It has a heated seat and grips besides the ABS. Did I mention February and a heated seat?
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeFri Nov 14, 2014 6:44 am
I would worry that the rotella would wreak havoc on the flux capacitor! Also i think the sludge pump will struggle to push it thru! Hopefully you filtered it thru a cheese cloth to remove the ZDDP and the friction modifiers out of it before pouring it in, otherwise i think your screwed!! Heaven only knows what the hydrocarbons and the polalphaolefins will do! Have mercy, what about the polyinternal olefins? If you decide to leave the oil in, i wouldnt go over the 10kph mark. Just kidding........
Simple rule for oil: pour flavor of the month in (usually whatever is left over from atv,lawnmower,car etc), ride the bejeezus out of it.
PostSubject: Re: Rotella T5 ( energy saving )oil   Rotella T5 ( energy saving )oil I_icon_minitimeFri Nov 14, 2014 8:03 am
I'll keep you guys posted; you'll have to wait awhile, though. Getting our first dusting of the four-letter word today on the Bay of Fundy. So, what do SWingers do when they can't SWing?
» Saving time.
» Oily to bed, oily to rise. Rotella T6
» Money Saving Idea for Christmas
» Rotella T6 5W-40 as Final Drive oil
