| Having to use key to open seat | |
+3hotwings trouble1100 SteveO 7 posters |
SteveO Scooter Rider
Number of posts : 43 Age : 80 Location : Grand Prairie, Texas Points : 4162 Registration date : 2013-08-15
Number of posts : 341 Location : Surprise, AZ. Points : 5784 Registration date : 2010-04-30
hotwings Silver Wing Expert
| Subject: Re: Having to use key to open seat Sun Nov 16, 2014 4:48 am | |
| Looks good guys. Think i will do the same. |
Colin B Silver Wing Expert
Number of posts : 586 Age : 72 Location : Windsor, UK Points : 4907 Registration date : 2013-03-20
| Subject: Re: Having to use key to open seat Sun Nov 16, 2014 9:57 am | |
| What about security? Are there no thieves in the US of A? |
LDB Maxi-Scooter Rider
Number of posts : 157 Age : 67 Location : Houston Points : 4037 Registration date : 2014-05-19
| Subject: Re: Having to use key to open seat Sun Nov 16, 2014 12:35 pm | |
| What is wrong with using the key to open the seat? |
| Subject: Re: Having to use key to open seat Sun Nov 16, 2014 1:43 pm | |
| - LDB wrote:
- What is wrong with using the key to open the seat?
The key is still used, removable if one feels necessary! It would be nice not to have to fumble to get a key, usually by having to shut the bike off to get that key, especially in my own garage!! |
| Subject: Re: Having to use key to open seat Sun Nov 16, 2014 2:18 pm | |
| LDB, as an old and forgetful guy I was always running around town getting stuff, then at the Swing get the key out, open the seat, put stuff under it, close the seat and sit on the Swing to start it and remember that the key was still in the lock. This way all I have to do is turn the knob to open the seat. Colin B far as the security goes when you feel the need to lock it up, just pull the knob and drop it under the seat. You will always have a key with you.
SteveO |
| Subject: Re: Having to use key to open seat Sun Nov 16, 2014 3:15 pm | |
| Not arguing, SteveO; just curious. If it works..... |
| Subject: Re: Having to use key to open seat Sun Nov 16, 2014 8:27 pm | |
| - Colin B wrote:
- What about security? Are there no thieves in the US of A?
Hell no! We all walk around with guns, keeps folks honest! |
| Subject: Re: Having to use key to open seat Mon Nov 17, 2014 4:34 am | |
And the statistics show it........ |
| Subject: Re: Having to use key to open seat Sat May 16, 2015 10:56 pm | |
| The only real downside I see to that is the cut off key also still fits the ignition. I know a Goldwing rider who made a similar cut off key to make it easier to open the gas flap. At a rest stop one of his buddies started the guy's bike while he was in the restroom. He wasn't amused to find his bike idling when he came out. |
| Subject: Re: Having to use key to open seat Sun May 17, 2015 1:12 am | |
| The cut off key is not long enough to fit all the way to the bottom of the Silverwings ignition. You can open the seat, remove the gas cap and lock/unlock the left glove box, but it is not long enough to start the scooter. |
| Subject: Re: Having to use key to open seat Sun May 17, 2015 10:43 am | |
| What did you use to cut the key? |
| Subject: Re: Having to use key to open seat Sun May 17, 2015 3:55 pm | |
| - model28a wrote:
- The cut off key is not long enough to fit all the way to the bottom of the Silverwings ignition. You can open the seat, remove the gas cap and lock/unlock the left glove box, but it is not long enough to start the scooter.
Very good! The fellow with the Goldwing apparently didn't think of that. |
| Subject: Re: Having to use key to open seat Sun May 17, 2015 5:15 pm | |
| exavid I've never ridden a Goldwing so I don't know if the ignition key needs to be as long as the Silverwings key. |
| Subject: Re: Having to use key to open seat Sun May 17, 2015 9:03 pm | |
| It's actually a good bit shorter so the technique might not work on a GW. The ignition key was one of my main gripes when I got my first SW. It really required an accurate insertion to get the thing to go all the way in. One of my friend's SW does the same thing, fits into the seat lock easily but touchy going into the ignition. Buffing the key and lubing the lock didn't help much. Luckily he's getting more accurate at getting the key in the ignition. |
| Subject: Re: Having to use key to open seat Sun May 17, 2015 9:11 pm | |
| - exavid wrote:
Very good! The fellow with the Goldwing apparently didn't think of that. I made the same short key-knob for my 2004 GL-1800 and it would NOT go deep enough in to the trunk or the ignition to work. Could it be that his was to long? No man on earth would ever make claim to that! |
