| FI light came on . | |
moonshiner Scooter Rider
Number of posts : 94 Age : 56 Location : TN Points : 4969 Registration date : 2011-08-06
| Subject: FI light came on . Mon Mar 30, 2015 10:34 pm | |
| the other day while idling , i had the FI indicator light up and it started idling rough like it was going to stall, i gave it a little throttle and the light went out and then it idled correctly , i don't think that has happened before , but it did stall while idling not long after i bought it , ran some Lucas through it never noticed any other problem till the other day , has anybody had similar problems , or how to check the codes on a silver wing ,i saw somewhere that a weak battery can cause similar problems with Honda's , i have a very low miles parts bike , so parts are not a problem , most of my mechanic chores have been points , carbs and tire changes , so i am still learning this computer age stuff ..
thanks Keith |
| | | model28a Silver Wing Guru
| Subject: Re: FI light came on . Tue Mar 31, 2015 12:13 am | |
| Mileage? Age? Those are two things that should usually be given when asking for help diagnosing a problem. |
| Subject: Re: FI light came on . Tue Mar 31, 2015 2:06 am | |
| Subject: Re: FI light came on . Tue Mar 31, 2015 4:08 pm | |
| Not to be discouraging, but the Factory Service Manual (FSM) has a 70 page chapter on the FI system, including Fault Codes and EFI test procedures. So it's kind of difficult to work with you on this. You do have a FSM right?
However, you should probably balance the throttle body air adjustment screws with a manometer or carb balancing meter before going to any more serious measures. While you are at it you should check all those little air/vacuum lines for leaks as well.
Good luck, and please let us know how you make out with this problem. It will help others on the forum. members.
| Subject: Re: FI light came on . Tue Mar 31, 2015 5:02 pm | |
- Not to be discouraging, but the Factory Service Manual (FSM) has a 70 page chapter on the FI system, including Fault Codes and EFI test procedures. So it's kind of difficult to work with you on this. You do have a FSM right?
Tim no i don't have a factory service manual , i have tested and replaced a couple of ECMs on a few cars, can one happen to find a FSM online ? |
| Subject: Re: FI light came on . Tue Mar 31, 2015 5:30 pm | |
| - moonshiner wrote:
- 2004 , 35,000 mi
Thank you for your information, have you ever replaced the fuel pressure regulator? Below(in blue)is a post by bigbird on the subject. I'll look around and see if I can find any links for service manuals, I just had my local Honda dealer get one for me but I'll admit that's not a very cheap way to go. Fuel Pressure Regulator Assembly Tips and part #'s |
| Subject: Re: FI light came on . Tue Mar 31, 2015 5:55 pm | |
| Here is a link I've found (below in blue) to buy a factory service manual for only $30. I hope this link helps someone. SERVICE MANUAL Here is what I found with an Ebay search. Service manuals on Ebay. |
| Subject: Re: FI light came on . Tue Mar 31, 2015 7:19 pm | |
| - model28a wrote:
- moonshiner wrote:
- 2004 , 35,000 mi
Thank you for your information, have you ever replaced the fuel pressure regulator? Below(in blue)is a post by bigbird on the subject. I'll look around and see if I can find any links for service manuals, I just had my local Honda dealer get one for me but I'll admit that's not a very cheap way to go. Fuel Pressure Regulator Assembly Tips and part #'s thank you model28a no , i have never replaced the fuel pressure regulator but i will check it out . i have been working on it today , the battery is going bad , i will replace that first, and keep working . i also found that when it warmed up the idle was only about 800 rpm's , so i adjusted it back up to 1,100 and i checked all the vacuum hoses . |
| Subject: Re: FI light came on . Tue Mar 31, 2015 7:29 pm | |
| knowing my luck if it is the fuel pressure regulator the one on the parts bike will have the wrong part # |
