crankcase breather I_icon_minitimeby MikeO Thu Nov 14, 2024 11:23 pm
crankcase breather I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 11:05 pm
crankcase breather I_icon_minitimeby terryweasely Thu Nov 14, 2024 3:48 am
crankcase breather I_icon_minitimeby AldusFran Mon Nov 11, 2024 2:21 pm
crankcase breather I_icon_minitimeby xwelder Sat Nov 09, 2024 8:46 pm
crankcase breather I_icon_minitimeby landisr Sat Nov 09, 2024 5:46 pm
crankcase breather I_icon_minitimeby Dale N. Fri Nov 08, 2024 3:07 am
crankcase breather I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 1:24 pm
crankcase breather I_icon_minitimeby Siataukreg Thu Nov 07, 2024 8:45 am
crankcase breather I_icon_minitimeby kbcmdba Tue Nov 05, 2024 12:56 am
 crankcase breather
4 posters
tankyuong
tankyuong
Number of posts : 475
crankcase breather Empty
PostSubject: crankcase breather   crankcase breather I_icon_minitimeMon Aug 24, 2009 8:00 pm
Does anybody know where the crankcase breather is to clean, anyone have a picture thanks.
Number of posts : 1020
PostSubject: Re: crankcase breather   crankcase breather I_icon_minitimeMon Aug 24, 2009 8:47 pm
tankyoung,
My manual says:
CRANKCASE BREATHER
  • Service more frequently when ridden in rain, at full throttle, or after the scooter is washed or overturned. Service if the deposits level can be seen in the transparent section of the breather hose.
The air cleaner chamber drain hose is (and their description is lousy) under the left side of the bike just forward of the center stand.
Remove the air cleaner chamber drain hose plug from the hose end and drain deposits into a suitable container, then reinstall the hose end plug.
Sorry, can't get you a picture but it's easy to spot.
Hope this helps.
Registration date : 2009-07-18
PostSubject: Re: crankcase breather   crankcase breather I_icon_minitimeMon Aug 24, 2009 11:55 pm
That's a good reminder, I know the older Goldwings would actually begin to run rough because the drain container would fill up and the gunk would eventually back up the tube until it built up in the air filter box enough to get sucked down the engine. Newer ones have a plugged drain tube like the SW. I check mine with every oil change which seems to work out well.
dickie
dickie
Number of posts : 240
PostSubject: Re: crankcase breather   crankcase breather I_icon_minitimeTue Aug 25, 2009 1:58 am
As exavid stated this is a good reminder for all of us. DickO's discription should help everyone. Thanks guys. Dick
crankcase breather
» Dumb question: where is crankcase breather plug?
» Breather tube question.
» Leaking Crankcase
» Right Crankcase Cover
» crankcase vent
