Throttle lock I_icon_minitimeby JohnyC Today at 5:39 am
Throttle lock I_icon_minitimeby JohnyC Yesterday at 10:04 am
Throttle lock I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Throttle lock I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Throttle lock I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Throttle lock I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Throttle lock I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Throttle lock I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Throttle lock I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Throttle lock I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Throttle lock
oldgwingguy
Oldernewrider
Oldernewrider
Number of posts : 2
Registration date : 2015-06-25
Throttle lock Empty
PostSubject: Throttle lock   Throttle lock I_icon_minitimeSat Jun 27, 2015 8:56 pm
I am not sure how to measure my throttle for size to get a throttle lock.  I am looking at vista type.  When I look on Amazon and put in my bike it says it does not fit.  Help?
oldgwingguy
Number of posts : 247
Throttle lock Empty
PostSubject: Re: Throttle lock   Throttle lock I_icon_minitimeSat Jun 27, 2015 9:17 pm
7/8" bar size, you could use a digital caliper to double check.
Oldernewrider
Number of posts : 2
Throttle lock Empty
PostSubject: Re: Throttle lock   Throttle lock I_icon_minitimeSat Jun 27, 2015 9:22 pm
Thanks. I will see if I can find one from a friend.
Number of posts : 1999
Throttle lock Empty
PostSubject: Re: Throttle lock   Throttle lock I_icon_minitimeSat Jun 27, 2015 11:33 pm
This is the one I have on my 08 SWing and it works great: http://tinyurl.com/pv665xl
One thing I just remembered. I had to file the lock where it went between the throttle cables to make it just a bit narrower. Not a problem seeing as it's plastic. But hey, now it's a custom fit.
Deno070
Number of posts : 121
Registration date : 2013-12-06
Throttle lock Empty
PostSubject: Re: Throttle lock   Throttle lock I_icon_minitimeMon Jun 29, 2015 3:38 pm
Oldernewrider, welcome to the site. You'll find a ton of info here. Typically an introduction is done prior to sending off a questions..just saying.
Throttle lock Empty
PostSubject: Re: Throttle lock   Throttle lock I_icon_minitimeMon Jun 29, 2015 4:36 pm
welcome Oldernewrider welcome to the best Silverwing forum on the web. As has been posted above your scooter has 7/8" handlebars.
If you are looking forward to learning and plan on doing your own maintenance you'll find you can do anything you need or want with the service manual and help from this forum.
I add the paragraph below for most new members because there's a lot of information in the links and may save you some work.
Here are some links(3 below in blue)that will help you learn a lot about your Silverwing. If you can't find what you need in the links below the search on this forum works good, and if you still need help just ask and someone will do what they can to answer your questions.
Maintenance, Tips and Hints
Maintenance "Pictorials"
Accessories-Modifications
Throttle lock Empty
PostSubject: Re: Throttle lock   Throttle lock I_icon_minitimeMon Jun 29, 2015 8:29 pm
If you want the best I still recommend the bar end type. Koako is the best of several I've used over the years. The Vista Cruise type are cheap but don't last as well and are more difficult to keep in adjustment.
http://www.webbikeworld.com/t2/kaoko-throttle-control/
Throttle lock 510-80
Throttle lock Empty
PostSubject: Re: Throttle lock   Throttle lock I_icon_minitimeMon Jun 29, 2015 10:41 pm
I didn't realize this was an introduction, so welcome to the forum.
welcome welcome
Throttle lock
» NEP CC-3 throttle lock
» Breakaway Throttle Lock
» Throttle Locks for Swings
» Breakaway throttle lock
