| Missing drain plug o-ring | |
dalehazelton Scooter Rider
Number of posts : 80 Location : Hudson Valley NY Points : 3472 Registration date : 2015-08-18
| Subject: Missing drain plug o-ring Tue Sep 01, 2015 12:36 pm | |
| Hello,
In the process of my first oil change on the Silverwing 600. New to me 2008 with 1,800 miles on it when I brought it home. The oil was low and it had a Hi-Flo brand fliter so I'm assuming the 600 mile service was done. Anyway, there is no o-ring in the drain plug (maybe why it was low - also the filter came off just without even putting the wrench on it!) and I can't find any specs for one here.
I have a large box of nitrile o-rings from Harbor Freight and one may work, but I can't tell from the diagram in the MOM if the o-ring goes OUTSIDE the threads on the plug or if it sits into the well in the plug.
I have also seen an Ebay oil change kit specifically for the SW with a crush washer but there doesn't appear to be one (maybe that's for the smaller Eurpopean SW's). What say ye? |
The Bern Silver Wing Expert
| Subject: Re: Missing drain plug o-ring Tue Sep 01, 2015 2:48 pm | |
| Hi bud IIRC the "O" ring sits in the well in the plug flange. Oil filter is normally, spin on until it touches & then a further 1/4 turn EDIT Drain plug torque 15 N:m / 11 lbf:ft / 1.5 kgf:m Oil filter torque 26 N:m / 20 lbf:ft / 2.7 kgf:m |
| Subject: Re: Missing drain plug o-ring Tue Sep 01, 2015 4:54 pm | |
| Thanks. I made the trip to Honda and got the last o-ring they had. Whoever did first oil change was just sloppy. |
| Subject: Re: Missing drain plug o-ring Tue Sep 01, 2015 7:31 pm | |
| If the oil filter is put on properly you will be able to remove it by hand. I never use a filter wrench to put a filter on and only use one to take off a filter that someone else put on too tight. |
| Subject: Re: Missing drain plug o-ring Tue Sep 01, 2015 9:58 pm | |
| I put the filter on basically hand tight, no wrench. This one came off WAY easier than any I've removed. I'm not a torque wrench guy and would probably get flack for it but I never over tighten things. If it doesn't weep or leak it's tight. I've had too many broken lug nut studs and such on my vehicles to overtighten stuff. I've never had anything loosen or fall off. So far I'm doing okay, knock on wood. |
NWSSC Silver Wing Rider
| Subject: Missing drain plug o-ring Tue Sep 01, 2015 10:06 pm | |
| If I may suggest.While you do not need one now is the time to purchase a cup style oil filter wrench for your oil filter on the S/W. There are all kinds of tools you can use but sooner or later you will wish you had one.Also I know this is not that common but I always fill the filter twice with oil before installing it. The filter will absorb the oil and yes you might loose a few drops of oil(the filter is horizontal) but you will get almost instant oil pressure. Also follow the owners manual for checking oil lever. Howard |
| Subject: Re: Missing drain plug o-ring Tue Sep 01, 2015 10:17 pm | |
| Since you already changed the oil I guess you discovered the oil screen and spring. I was changing the oil on a '04 SW a friend just purchased last year and found the oil screen and spring missing. |
| Subject: Re: Missing drain plug o-ring Wed Sep 02, 2015 7:43 am | |
| I bought a new cap wrench and it turned out I had two that size already in the toolbox.
Spring and screen were there. Much simpler oil change than my VFR. |
| Subject: Re: Missing drain plug o-ring Thu Sep 03, 2015 12:02 am | |
| Simpler than changing oil on my 650GT it has two drains one for the engine and one for the sump. BMW did at least install the filter in a vertical position so that's a bit less messy. |
HORNBLOWER Maxi-Scooter Rider
Number of posts : 171 Age : 69 Location : Birmingham UK Points : 4269 Registration date : 2013-10-08
| Subject: Re: Missing drain plug o-ring Fri Sep 04, 2015 3:23 am | |
| - model28a wrote:
- If the oil filter is put on properly you will be able to remove it by hand. I never use a filter wrench to put a filter on and only use one to take off a filter that someone else put on too tight.
I totally agree with you and have done it by hand for a lifetime but when I changed my oil yesterday I decided to do both the drain plug and filter using my torque wrench. I was amazed at just how much more I had to turn the filter to get to the right torque setting and was expecting something to go snap at any moment!!! |
