| Towing a Solverwing | |
bjkaraoke Scooter Rider
Number of posts : 22 Age : 67 Location : Austin Points : 3941 Registration date : 2014-03-08
| Subject: Towing a Solverwing Thu Oct 22, 2015 11:42 am | |
| I am making a trip to Texas and was wondering if anyone has used one of these before and if so is it necessary to remove the drive belt |
| Subject: Re: Towing a Solverwing Thu Oct 22, 2015 12:04 pm | |
| - bjkaraoke wrote:
- I am making a trip to Texas and was wondering if anyone has used one of these before and if so is it necessary to remove the drive belt
I did not get an image of the product in question. Maybe others can help. |
DickO Founding Member
| Subject: Re: Towing a Solverwing Thu Oct 22, 2015 1:12 pm | |
| Me neither... looks like one of those facebook placeholders that won't open for me either.
The Bern Silver Wing Expert
| Subject: Re: Towing a Solverwing Fri Oct 23, 2015 5:23 am | |
| I'm gonna guess bjkaraoke means one of these (or similar) ... .... if that's the case then, no you don't need to remove the drivebelt bud, bud |
| Subject: Re: Towing a Solverwing Fri Oct 23, 2015 5:27 am | |
| Ha H, I got it ..... - bjkaraoke wrote:
- I am making a trip to Texas and was wondering if anyone has used one of these before and if so is it necessary to remove the drive belt http://www.ebay.com/itm/Motorcycle-2-Receiver-Trailer-Hitch-Carrier-Pull-Behind-Hauler-Tow-Towing-Rack-/360741837790?hash=item53fde39bdemXKNL-7I9H0TssEo6I2z_8w&vxp=mtr
... OP had trapped the ebay link in image tags, reply with quote & remove the tags & all is how it should be
| Subject: Re: Towing a Solverwing Fri Oct 23, 2015 5:30 am | |
| And now I demand a prize for amazingly accurate guess work |
Cookie Super Scooter Rider
Number of posts : 233 Location : Essex UK Points : 5041 Registration date : 2011-10-03
| Subject: Re: Towing a Solverwing Fri Oct 23, 2015 5:55 am | |
| I certainly wouldn't tow it like that. The bearings inside the driven pulley would be spinning all the time. They are only grease lubricated and normally only spin when the bike is stationary with the engine idling. I doubt they are intended for constant operation. Just my thoughts I hasten to add. |
| Subject: Re: Towing a Solverwing Fri Oct 23, 2015 7:47 am | |
| Indeed there is that point to bear in mind Cookie, also over prolonged periods the rear tyre will wear badly in the middle |
dalehazelton Scooter Rider
Number of posts : 80 Location : Hudson Valley NY Points : 3467 Registration date : 2015-08-18
| Subject: Re: Towing a Solverwing Fri Oct 23, 2015 9:26 am | |
| I think those exist only because manufacturers needed a way to keep people busy and use up left over steel. They are a really dumb idea for ANY kind of motorcycle. If you have a hitch just buy a used utility or boat trailer. |
