| rear end chatter | |
mikelx5 Scooter Rider
Number of posts : 10 Location : seattle wa Points : 3424 Registration date : 2015-05-07
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: rear end chatter Sat Oct 31, 2015 7:35 pm | |
| I have a chatter all the way to about 50 mph then it smoothes out. I have 24g sliders in the vario and a slipon muffler. When I was in the cvt I noticed a couple of grooves that looked like an oring slot on the rear clutch. Looked up in the service manual it is exactly that. so my question is could that cause a lot of chatter if those orings are not there.
Another problem is the tall windshield rattling alot has anybody found a fix for this yet. the rubber piece will not maintain shape could that be the cause. |
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: Re: rear end chatter Sat Oct 31, 2015 7:58 pm | |
| First state how old machine is and how many miles. Might help is noise tracing.
Tall Windhield----what make? |
NWSSC Silver Wing Rider
![NWSSC](https://2img.net/u/3413/63/00/33/avatars/522-39.jpg)
Number of posts : 418 Age : 86 Location : Mt Prospect IL 30 miles west of Chicago Points : 5774 Registration date : 2010-03-03
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: rear end chatter Sat Oct 31, 2015 11:11 pm | |
| Hello Mike.Like the previous S/W rider said,we need to have a little more information. First the groves you see are exactly what you said. Although rather particular they are to hold the inner race of the bearing in the left outer cover.I doubt if they are the cause of your concern. Off hand your chatter is probably more of a harmonic vibration caused by some plastic in the front end or something in the exhaust system. About your wind screen,did it come with extra brackets? I would tell my(customers) patients, tell me as much of the systems as you can and I will try and do the diagnosing.Let us know what you find so we can all learn from your experiences. Thank you. Howard |
Number of posts : 247 Location : Hocking Hills Points : 3776 Registration date : 2015-02-08
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: Re: rear end chatter Sun Nov 01, 2015 4:06 am | |
| Chasing sounds, lordy what an adventure, right up there with electrical problems when aftermarket items have been added. That said what one gent told me and what appeared to be a noise up in the dash area was actually a loose front fender mounting bracket. I would look for loose items first, maybe a bolt / screw / tap that would do it's thing in one area but sound from another. MOST IMPORTANT is when you find it tell us |
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: Re: rear end chatter Mon Nov 02, 2015 10:25 pm | |
| The bike has 45,000 on it and it's a givi windshield |
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: Re: rear end chatter Tue Nov 03, 2015 6:16 am | |
| Slipon muffler with a loose bolt / shield, perhaps internally a loose baffle? Try thumping the muffle good to see if you can hear anything loose. One other thing was this something that started out slowly then got worse or was it a sudden happening? |
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: Re: rear end chatter Tue Nov 03, 2015 11:35 pm | |
| A friend's bike had a rattle from the rear end that turned out to be that wire guard around the bottom of the muffler cover that was bent a bit and rattling against the cover. |
transam86 Maxi-Scooter Rider
![transam86](https://2img.net/u/3413/63/00/33/avatars/132-52.jpg)
Number of posts : 140 Age : 61 Location : Gray GA Points : 5860 Registration date : 2009-02-25
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: Re: rear end chatter Thu Nov 05, 2015 10:09 am | |
| im thinking belt slap maybe? |
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: Re: rear end chatter Thu Nov 05, 2015 10:36 am | |
| Rear clutch-----45,000 miles, worn out?, non stock parts? My suggestion put drive train back together with stock parts including rollers in front, belt how old? After near 400,000 miles on these rubber band drive scooters experience----the drive lines do wear out, grooves in pulley, etc. They do function well with stock parts/fresh OEM belts, etc
Givi windshield installed correctly?, all well nut there? check |
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: Re: rear end chatter Thu Nov 05, 2015 6:19 pm | |
| One way to isolate rattling body panels, windshield rattles and such is to use some masking tape to cover joints. In this case tape along the crack between the windshield and the front cover, tape along the sides of the front cover. I use 2" wide masking tape for that kind of work. Tape every thing in the areas of the rattle, test ride and remove the tape a bit at a time until the rattle comes back. |
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: Re: rear end chatter Thu Nov 05, 2015 7:27 pm | |
| Paul |
![rear end chatter Empty](https://2img.net/i/empty.gif) | Subject: Re: rear end chatter Thu Nov 05, 2015 11:19 pm | |
| great idea paul and ill look again to see if it is grooves but i doubt it I didnt notice it while I was in there. i have roughly 50,000 miles on scoots and modding them but just mostly low cc scoots. |
