| Rough starting, not going to warmup revs | |
+5exavid Old Limey Cosmic_Jumper john grinsel ridr44 9 posters |
ridr44 Scooter Rider
Number of posts : 72 Age : 70 Location : Long Island, New York Points : 5397 Registration date : 2010-06-04
| Subject: Rough starting, not going to warmup revs Thu Nov 19, 2015 6:50 am | |
| Hey guys, my 2003 SW has lately not been starting with the normal warm up revs, but staying at low revs and struggling to stay running. I usually hold the throttle open a bit and start riding rather quickly and often at the first light it's revving like it's warming up...??? Any insight into this? Otherwise it runs great. thanks Dan |
| Subject: Re: Rough starting, not going to warmup revs Thu Nov 19, 2015 8:02 am | |
| First of all 12 years old, How many miles, maint. history? How much ridden?, fuel? Taken care of by Honda shop or self? |
| Subject: Re: Rough starting, not going to warmup revs Thu Nov 19, 2015 9:30 am | |
| 17k miles, just had new belt by dealer. Other than oil changes, and not often:) I have not done anything else except tires since I got it with 6k. |
| Subject: Re: Rough starting, not going to warmup revs Thu Nov 19, 2015 9:57 am | |
| I would say fuel/fuel injection-----probably related to sitting around---try Honda dealer....have to leave overnight cold start problem can be duplicated. |
| Subject: Re: Rough starting, not going to warmup revs Thu Nov 19, 2015 10:49 am | |
| Replace the Fuel Pressure Regulator (FRP) --easy DIY job for most guys. Add half a bottle of Techron. Replace sparkplugs.
Kindly come to terms with your ašš for it bears you --Fra Junipero Serra c.1760 |
Old Limey Silver Wing Expert
| Subject: Re: Rough starting, not going to warmup revs Thu Nov 19, 2015 2:11 pm | |
| I agree about spark plugs, and would advise a new Air filter, or at least have a look at it. |
| Subject: Re: Rough starting, not going to warmup revs Thu Nov 19, 2015 4:52 pm | |
| I spoke to the dealer and he recommended trying sea foam. I put some in and rode 50 miles. We'll see in the am how it starts...i'll let you know...thanks for the input!! |
| Subject: Re: Rough starting, not going to warmup revs Thu Nov 19, 2015 6:52 pm | |
| I'd give Sea foam or Techron a try before doing much else. Your air filter might be a bit on the dirty side but probably not a factor since a restriction in the air intake would tend to richen up the mixture and it sounds like your scooter is running too lean when cold. I don't know if disconnecting the battery for a minute or two will reset the ECU or not but it's worth a try. |
NWSSC Silver Wing Rider
Number of posts : 418 Age : 87 Location : Mt Prospect IL 30 miles west of Chicago Points : 5848 Registration date : 2010-03-03
| Subject: Rough starting, not going to warmup revs Thu Nov 19, 2015 10:33 pm | |
| The Sea Foam will probably not hurt anything but the symptoms sound like old or bad gas. I would try some fresh gas(highest octane) and put at least 100 miles before doing any repairs. Howard |
Number of posts : 247 Location : Hocking Hills Points : 3850 Registration date : 2015-02-08
| Subject: Re: Rough starting, not going to warmup revs Fri Nov 20, 2015 4:09 am | |
| - ridr44 wrote:
- I spoke to the dealer and he recommended trying sea foam. I put some in and rode 50 miles. We'll see in the am how it starts...i'll let you know...thanks for the input!!
50 miles is not likely to do much, perhaps 500 to do a good job, once clean if it's ridden regularly should do the trick, there after a bottle of Techron concentrate once a year. That 500 miles is only a two tank treatment on a S'Wing |
Number of posts : 461 Age : 71 Location : Nova Scotia Points : 4593 Registration date : 2013-09-12
| Subject: Re: Rough starting, not going to warmup revs Tue Nov 24, 2015 7:08 am | |
| To offer my 2cents ..... Over the summer I've had similar issues .... here's what helped : as was suggested here by the wise and experienced (thanks again guys!) ..... some high octane gas, new spark plugs and giving the S'Wing some hard riding. Get her up to higher speeds for a while. These all helped mine -- which would idle to stall or needed some throttle to get her started, at times. And other times she started just fine. But the one thing that has seemed to make the biggest difference was the installation of a new battery.
Check your battery ... maybe on the way out like mine was.
Hope this helps. Good luck !
Mike |
| Subject: Re: Rough starting, not going to warmup revs Tue Nov 24, 2015 7:47 am | |
| I have had my doubts about the battery but how would that effect this issue? Thanks dan |
| Subject: Re: Rough starting, not going to warmup revs Tue Nov 24, 2015 1:23 pm | |
| Not sure how a new battery may affect the issue but in my naivety I like to think the power to the fuel pump may be less than adequate in an older battery. HOWEVER !!! When getting a quote on a battery from the dealer I question them about a weak or failing battery affecting the slow idle to stall and the rough starting I had experienced. The reply was there may be a fuel issue and this problem is likely not the fault of the battery. And .. however , again ... It runs and starts much better with the new battery and there have been no further slow idle issues or rough starting problems. So, I'm just going with the observation that it works better since installing a new battery.
How old is your battery Dan? I was told the good ones may last 6 - 7 years and the cheaper ones may last 3. I think the one in my bike was 10 years old and the original battery in the bike - a 2005.
The easiest (and the most fun) way to fix the idle issue to is take your Silverwing for a fast ride. That had an immediate fix to my problem .... but it returned.
Mike |
| Subject: Re: Rough starting, not going to warmup revs Tue Nov 24, 2015 3:35 pm | |
| A ten year old battery should be replaced and with another of the same brand. That's a very good battery to last that long. I never let 'em get much older than five years. If your battery is iffy it's likely to show up in the colder weather. |
dalehazelton Scooter Rider
Number of posts : 80 Location : Hudson Valley NY Points : 3471 Registration date : 2015-08-18
| Subject: Re: Rough starting, not going to warmup revs Fri Nov 27, 2015 8:51 am | |
| My Silvewring ran kinda rough when I first got it. It was 7 years old with 1,800 miles on it so obviously it sat a lot. I put 93 octane in and added Seafoam and it started to even out in a couple of tankfuls. 93 octane is supposed to have ten times the amount of detergents as the lower stuff. In a bike that only holds a few gallons I don't think the extra expense breaks the bank and it's well worth it. |
| Subject: Re: Rough starting, not going to warmup revs Fri Nov 27, 2015 2:12 pm | |
| I use 93 octane in my bikes often instead of 87 mainly because in OR you can only get 93 without ethanol all other grades have the damnable stuff. I can see the mileage improvement and feel the better running when I use ethanol free. All my vehicles get a dose of Sea Foam every other month or so. Some times it seems to make a difference, sometimes not, but often makes for a smoother idle and faster starting. |
