| Second Tail Light | |
+5Winger61 dalehazelton Gustafa Old Limey Kenjj50 9 posters |
Kenjj50 Super Scooter Rider
Number of posts : 220 Age : 74 Location : Naperville, Illinois Points : 3577 Registration date : 2015-09-28
| Subject: Second Tail Light Sun Feb 07, 2016 3:33 pm | |
| A while back I bought a Perfect Connector made up by Cosmic_Jumper for a project I wanted to do this winter. Today, I finished the project. I have added a 48 diode brake light (including a 19 diode running light) to the underside of my Swing spoiler. I really like my '02 Swing. I bought it with the HID low beam headlight conversion. I was not satisfied with the tail/brake lights. They are low and angle downward. I thought I could modify this and improve my visibility from the rear. After a lot of Google work, I found a LED light from etrailer.com that satisfied all my requirements. The Optronics STL70RB light was $25.00 and the mounting bracket, grommet and pigtail cost another $5.00. I spent about $10 on miscellaneous hardware. Most of which I still have! I mounted it to the underside of the spoiler on my Swing. The two rear bolts that would be used to mount the anchoring frame for my Givi topcase were positioned really close to where I needed them to mount the bracket for the tail light. I had to elongate the predrilled holes in the bracket about 1/4-inch and use 2-inch bolts to penetrate the spoiler. I added lock nuts, and the mounting position was perfect. I drilled a 1/2 inch hole through the rear body cover into the underseat storage and another through the removable panel to in the seat storage to feed the wires to the Perfect Connector. I had removed the left side body cover to install the Perfect Connector. It wasn't too difficult to remove left rear body cover and removing the spoiler is really easy. The spoiler had to be removed to mount the bracket. I connected the wiring with 18/22 butt end shrink wrap connectors and covered all the wiring with 3/8-inch black plastic flex tubing. The flex tubing fit snuggly into the 1/2-hole in the rear panel and I sealed the penetration with clear latex caulk. The mounting bracket was black powder coat, the grommet was black and my scooter is black, so it looks pretty professional. I have some photos of the running light and brake light, but I can't get the "Host an Image" function to let me insert them in the narrative. I can send you the photos if you want to email me. |
| Subject: Second Tail Light Mon Feb 08, 2016 10:11 am | |
| This should be a photo of the tail/brake light in running light mode... |
| Subject: Re: Second Tail Light Mon Feb 08, 2016 10:13 am | |
| This should be a photo of the tail/brake light in braking mode... |
Old Limey Silver Wing Expert
Number of posts : 921 Age : 80 Location : BOLTON LANCASHIRE ENGLAND Points : 6292 Registration date : 2010-06-09
| Subject: Re: Second Tail Light Mon Feb 08, 2016 12:10 pm | |
| I have the Honda topbox,it has a large area in the centre that is red plastic. I wired a "tigers eye" light into the upper sectiion from the brake lightThis is more or less on a motorists eyeline,so I feel a bit safer. |
Gustafa Super Scooter Rider
Number of posts : 218 Location : Cordova, TN Points : 3596 Registration date : 2015-10-10
| Subject: Re: Second Tail Light Mon Feb 08, 2016 12:28 pm | |
| It is, we see it twice.
Care to share a link to what you've got there? thats pretty nice! |
| Subject: Re: Second Tail Light Mon Feb 08, 2016 12:33 pm | |
| I detailed the installation and links related to the hardware under "Second Tail Light". If you do a Search for that phrase it will bring up the narrative. Thanks. |
| Subject: Re: Second Tail Light Mon Feb 08, 2016 12:35 pm | |
dalehazelton Scooter Rider
Number of posts : 80 Location : Hudson Valley NY Points : 3468 Registration date : 2015-08-18
| Subject: Re: Second Tail Light Mon Feb 08, 2016 2:05 pm | |
| Can we see what the housing looks like from the side? |
Winger61 Silver Wing Rider
Number of posts : 452 Age : 75 Location : Louth, Lincolnshire, UK Points : 5630 Registration date : 2010-10-15
| Subject: Re: Second Tail Light Mon Feb 08, 2016 3:05 pm | |
| I put a set of Admore led strip lights behind the reflectors in my Honda top box, wired in for running and stop lights, using one of DerekB's connector. Option was there for turn signals also, but red turn signals are illegal in the UK, so didn't use that wire. As Old Limey says, the lights are in the drivers eyeline, just makes you feel a bit safer.
Pics are in my album |
| Subject: Re: Second Tail Light Mon Feb 08, 2016 7:25 pm | |
| This is a photo of the Second Tail Light from the left side. |
| Subject: Re: Second Tail Light Mon Feb 08, 2016 7:27 pm | |
| This is a photo of the Second Tail Light from the left side and below the spoiler showing the mounting hardware. |
| Subject: Re: Second Tail Light Mon Feb 08, 2016 7:44 pm | |
| - Old Limey wrote:
- I have the Honda topbox,it has a large area in the centre that is red plastic. I wired a "tigers eye" light into the upper sectiion from the brake lightThis is more or less on a motorists eyeline,so I feel a bit safer.
I have a Givi top case that looks like it could be modified for a second tail/brake light. I don't plan to ride with it unless I'm on a multi day trip. I have one planned for June. I thought that the second tail light mod would work with or without the Givi case. I agree that having the elevated tail light will improve safety. |
bicyclenut Maxi-Scooter Rider
Number of posts : 141 Age : 56 Location : Chicago Suburbs Points : 3562 Registration date : 2015-09-04
gremlin Super Scooter Rider
Number of posts : 227 Age : 72 Location : Brisbane, Australia Points : 3778 Registration date : 2015-04-09
| Subject: Re: Second Tail Light Mon Feb 15, 2016 5:57 am | |
| That's a good one, bicyclenut ! One of my main concerns has always been that someone will rear end me. ( It has happened twice to me whilst driving a car and once whilst driving a 50 tonne mobile crane. It's one of the few risks that are hard to control and this might just make me a bit more visible. It is also not expensive and within my mechanical capabilities. Ordered the parts already, thanks. |
Number of posts : 3837 Age : 75 Location : Seaham, Co Durham, UK Points : 9702 Registration date : 2009-06-29
| Subject: Re: Second Tail Light Mon Feb 15, 2016 8:10 am | |
| Subject: Re: Second Tail Light Mon Feb 15, 2016 3:40 pm | |
| MikeO, thanks for the link to the photos for your light bar. That is my preferred mounting point too. |
| Subject: Re: Second Tail Light Mon Feb 15, 2016 4:42 pm | |
| Pleasure!
I mounted the bar under the spoiler so it would still be on the bike if I rode without the top box.
I have the Silverwing to Admore colour 'code' if anyone needs it. |
bikerboy Silver Wing Rider
Number of posts : 405 Age : 81 Location : Leyland England Points : 5367 Registration date : 2011-05-12
| Subject: Second tail light Mon Feb 15, 2016 8:55 pm | |
| Admore make an LED kit to fit into the Honda top box, I imagine it would also fit into the Givi box. |
| Subject: Re: Second Tail Light Mon Feb 15, 2016 11:43 pm | |
| MikeO, I mounted mine same as you did, think I saw your photos previously and that helped. I previously was looking at mounting to the plastic under the spoiler but no drilling needed to use the Givi plate, just remove the top and fit with some bolts. That also brought it up a bit higher and further back. Drilled a small hole to hide the cable as the mounting fasteners would not adhere in the cold and that ended up hiding the cable. Can still be used with the Givi box off as I leave the mounting plate on all the time. I have solid LED's in my Givi box that I run at night off a Lithium Ion battery pack. Don't have a photo of the all the lights working together yet. |
| Subject: Re: Second Tail Light Tue Feb 16, 2016 4:05 am | |
| Admore make specific kits for several of the Givi boxes:
http://www.admorelighting.com/ |
