Windshield garnish I_icon_minitimeby xwelder Today at 12:31 pm
Windshield garnish I_icon_minitimeby GHM-PM Today at 8:06 am
Windshield garnish I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Windshield garnish I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Windshield garnish I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Windshield garnish I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Windshield garnish I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Windshield garnish I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Windshield garnish I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Windshield garnish I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Windshield garnish
4 posters
mlapoint
Number of posts : 24
Registration date : 2015-05-04
Windshield garnish Empty
PostSubject: Windshield garnish   Windshield garnish I_icon_minitimeWed Mar 02, 2016 2:03 pm
I'm trying to remove the windshield garnish and get to the headlight. It took all the 4 screws holding it on, and I tried pushing it down and pull out. It doesn't seem to go down like it should. It is a 2004 Silverwing no ABS. Please help!
Thank you,
Mike LaPointe
terrier
terrier
Number of posts : 302
PostSubject: Re: Windshield garnish   Windshield garnish I_icon_minitimeWed Mar 02, 2016 2:21 pm
Mike....If you use a thin piece of plastic, something like a credit card, and slide it under each front edge of the garnish and push down gently with a bit of a wiggle it should come off. There's a bit of a knack to it but once you've done it you'll do it better next time.
Den
mlapoint
PostSubject: Re: Windshield garnish   Windshield garnish I_icon_minitimeFri Mar 04, 2016 10:18 am
Thank you for the reply terrier. I am still having problems getting the garnish off. Is the credit card supposed to help me get the garnish off of the windshield? I already have it loose from there but it won't come off the hooks underneath. I am getting so frustrated with it I am considering pulling it off and breaking the dam hooks and fixing them again with JBWeld. I'm not going to do this of course, but I'm very tempted to.
What I am trying to do is find out why my headlight goes out once in awhile switching from hi to low beams. I am planning to check the headlight first and see if it has proper contact. When I'm there, I can also check to see if the wiring to the light works.
Thank you,
Mike
terrier
terrier
PostSubject: Re: Windshield garnish   Windshield garnish I_icon_minitimeFri Mar 04, 2016 11:02 am
Ok Mike...The idea is to slide the plastic/credit card under the loose edge of the garnish to ease the hooks up. I didn't find it easy the first time I did mine but I've done it a couple of times since and it gets easier. There's a knack to it. Just persevere it's better than breaking the hooks off and giving yourself more work. Once you get it off you'll find there's not a lot of room in there. More so if you have the ABS model as the ABS module is also tucked in there. Small hands and patience needed. You can get at the high beam, the lower light, from under the front of the fairing. You'll find that most things on a SWing can be difficult to get at.
Den
Tommo
Tommo
Number of posts : 94
Registration date : 2015-10-01
PostSubject: Re: Windshield garnish   Windshield garnish I_icon_minitimeFri Mar 04, 2016 11:51 am
May be if you used the credit card to pay someone to do it, it would work better :lol!:
Windshield garnish 510-80
PostSubject: Re: Windshield garnish   Windshield garnish I_icon_minitimeFri Mar 04, 2016 12:10 pm
There are pictorials available to help with this procedure.
Any cussing and breaking is strictly self taught. Laughing
mlapoint
PostSubject: Re: Windshield garnish   Windshield garnish I_icon_minitimeFri Mar 04, 2016 1:28 pm
Alright, I got it removed. There were two screws that I was not counting for. Thank you for all your help though.
Mike
terrier
terrier
PostSubject: Re: Windshield garnish   Windshield garnish I_icon_minitimeFri Mar 04, 2016 1:57 pm
Aha, you fell for the illusive two hiding screws trick Rolling Eyes Anyway, glad you got it figured out Mike.
Den
mlapoint
PostSubject: Re: Windshield garnish   Windshield garnish I_icon_minitimeSat Mar 05, 2016 4:50 pm
Yes, and I think my headlight issue was just due to a bad connection between the wire plug and the low headlight. It seems fine now.
Windshield garnish
» Windshield Garnish Screw and Washer - Need to ID Part #
» Tip for removing windscreen garnish?
» Windshield woes?
» just ordered new Winfdscreen
» New windshield
