Tyre Nozzle Connections I_icon_minitimeby xwelder Today at 12:31 pm
Tyre Nozzle Connections I_icon_minitimeby GHM-PM Today at 8:06 am
Tyre Nozzle Connections I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Tyre Nozzle Connections I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Tyre Nozzle Connections I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Tyre Nozzle Connections I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Tyre Nozzle Connections I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Tyre Nozzle Connections I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Tyre Nozzle Connections I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Tyre Nozzle Connections I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
gremlin
Seadog
Winger61
jd70
13 posters
jd70
jd70
Number of posts : 24
Registration date : 2013-09-02
Tyre Nozzle Connections Empty
PostSubject: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeWed May 18, 2016 11:58 am
Finding it hard to screw Tyre Pump onto nozzle because of so little room especially the rear.
Is there a long straight extension with fixed screw head that could be screwed on first and then attach pump to that
Number of posts : 3837
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeWed May 18, 2016 12:14 pm
I've got one of these - can't remember which one - but it does the trick:
https://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=right-angle+valve+adaptor
jd70
jd70
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeWed May 18, 2016 12:43 pm
Thank you but I have these. need one that is long and straight with the screw nut fixed not turning
Number of posts : 1037
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeWed May 18, 2016 3:43 pm
You could get a 90 degree valve fitted which might help. Tyre off job though...
Winger61
Winger61
Number of posts : 452
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeWed May 18, 2016 3:44 pm
I bought one of these from Amazon (on MikeO's recommendation) about two years ago. They seem to have gone up in price, but I find it useful.
Graham.
https://www.amazon.co.uk/Connect-35084-210mm-Michelin-Extension-Flexible/dp/B007SU940M
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeWed May 18, 2016 4:36 pm
Graham, you beat me to it! Smile
I find mine invaluable.
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeWed May 18, 2016 5:31 pm
I have a similar one as well. Still a PITA trying to wedge my fingers between the brake disc & wheel to screw on/off the valve stem though.
Seadog
Number of posts : 51
Registration date : 2016-03-25
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeWed May 18, 2016 6:56 pm
A friend made a good one by removing the flexible tube from a broken tyre foot-pump.
He has the tube (over a foot long) from the pump, complete with the original fitting with lever that latches on to the tyre valve on one end, and into the other end he has pushed a standard tyre valve which is held in place and sealed to the hose using a Jubilee clip (screw hose clamp).
Number of posts : 4218
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeWed May 18, 2016 8:59 pm
I've had this problem with clamp on connectors before, so when my last foot pump expired I bought a Michelin twin barrelled one that had a screw on hose connector and a digital pressure gauge. It works fine, the pump hose screws on and off securely as simple as a valve cap.
jd70
jd70
PostSubject: Nozzle   Tyre Nozzle Connections I_icon_minitimeThu May 19, 2016 4:21 am
Yes I find it hard to get in to screw nozzle on which is why I am looking for an extension that has a fixed screw on end. Saw this on ebay and sent for it. Tyre Valve Stem Extension Rod Copper Truck Lorry TWIN WHEEL 100 mm   (have attached photo)  Will see if it is the right thing. Just £1-40.
(22 Kb) Downloaded 22 times
Number of posts : 921
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeThu May 19, 2016 4:24 am
I use a small 12 volt compressor I got from Home Bargains for four pounds. I let more air out than I could put in with the angled valve that was fitted to the rear wheel, so, when I changed tyres I fitted a straight valve. I agree you have to lie on the ground to take a pressure check but, I accept that as part of owning a Silver wing.
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeThu May 19, 2016 9:37 am
jd70 wrote:
<>Saw this on ebay and sent for it. Tyre Valve Stem Extension Rod Copper Truck Lorry TWIN WHEEL 100 mm   (have attached photo)  Will see if it is the right thing. Just £1-40.
That's a teriffic idea. Sure it may only be ~4 inches long, but that's a big help. I'll have to look for an extersion like that here too. Thanks for the photo.
jd70
jd70
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeThu May 19, 2016 10:00 am
Will let you know how it does
gremlin
gremlin
Number of posts : 227
Registration date : 2015-04-09
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeThu May 19, 2016 4:29 pm
Those brass valve extensions normally can be bought in any tyre shop for a couple of dollars.
Number of posts : 1013
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeThu May 19, 2016 11:44 pm
You should get the Fobo TPMS system. It comes with a Bluetooth phone app that lets you monitor the tires. I have been using it for over a year and really liked it. So far it is accurate to +/- .5 lbs. The only negative feedback is that you have to remove the sensor to add/remove air. Fobo does offer a t-valve stem to avoid having to remove the sensor, but I don't know if it will have clearance problems with the small wheels of the Swing.
Number of posts : 1935
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeFri May 20, 2016 7:26 am
I understand what you guys are trying to do with the extenders, I have the same A.G.E problem. BUT are you leaving them on or just using them when needed? Are you re balancing the wheel if your leaving them on? If they stay on what's the effect of the added weight on the tire stem, extra weight on the stem is hard on the base of the stem, it's one reason the G.Wings have those supports on there angled stems.
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeFri May 20, 2016 7:53 am
I used my right-angle adaptor on my previous Silverwing, which ended up with a straight valve for the rear tyre, just when using a pump; it lived in the LH cubby.
I use the flexible extension in the same way. It lives under the seat.
Number of posts : 757
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeSat May 21, 2016 7:10 am
I bought a 14" flexible extension that screws on to the valve. It is a Harley product, cost $17.00 Cdn. It helps but you have to be quick removing it from the tyre. It lets some air out while you are screwing/unscrewing it. No shortcuts : you still have to get on your belly or knees !!!
Jay.
On the positive side, it keeps you fit !
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeSat May 21, 2016 2:50 pm
With my TPMS system, I only have to get on my belly once every two months to add air. The system will warn you if you need to add air. I think it is worth the $99. My knees appreciate it.
Seadog
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeSun May 22, 2016 5:40 pm
I picked up a flexible adaptor in a bike shop I was visiting the other day.
It's 'Oxford' brand (they sell all sorts of bike accessories, readily available in UK, perhaps continental Europe, but I'm guessing not further afield), and labelled 'Valve Access Tool'. The flexible tube is about 5" long (I'd prefer longer), and it looks quite adequately well made. (I was going to post a pic of it, but can't work out how. Maybe later.)
I haven't tried it out yet, but will report back when I do.
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeSun May 22, 2016 11:23 pm
I find a regular tire chuck that's designed to work with dual tires works well on the Silverwing. They won't work on a hand pump since you need a hand to hold it on the tire valve but do work well with a small compressor. I carry a small 12V compressor. I bought it when I had my first GL1800 since that Goldwing doesn't have an on board compressor. These little compressors really don't take up much room and work well. The CO2 cartridges are also a good thing to have along on a road trip. They work well to quickly fill most of a flat tire followed by a bit of air pumped in to bring the pressure up to the desired level.
jd70
jd70
PostSubject: Re: Tyre Nozzle Connections   Tyre Nozzle Connections I_icon_minitimeFri May 27, 2016 3:40 pm
Received this and it works a treat.
» Have you had a flat tire?
» Battery Chargers
» Delamination of Tyre
» Panel removal to get to right hand cluster connections
» new "old" tyres
