Dr Pulley Slider Question I_icon_minitimeby john grinsel Yesterday at 4:14 pm
» Rear wheel valve stem
Dr Pulley Slider Question I_icon_minitimeby JohnyC Yesterday at 11:53 am
Dr Pulley Slider Question I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Dr Pulley Slider Question I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Dr Pulley Slider Question I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Dr Pulley Slider Question I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Dr Pulley Slider Question I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Dr Pulley Slider Question I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Dr Pulley Slider Question I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Dr Pulley Slider Question I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Flyingpanman
19basketball89
bicyclenut
mike712
12 posters
mike712
Number of posts : 95
Registration date : 2013-06-28
Dr Pulley Slider Question Empty
PostSubject: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeWed Aug 10, 2016 6:09 pm
I hope I am posting this in the correct place so here goes. I have installed 26G sliders on my 2012 SW. I have called up Dr Pulley Sliders and there are a lot of entries but can any one tell me in 25 words or less what I should expect if I install 24G or 22G or 21G sliders on my SW.
Number of posts : 2598
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeWed Aug 10, 2016 8:19 pm
I had 21 grams and they raised the rpm's too much for my liking. The interstate rpm's were about the same but the 55 mph and under was just too high for me. But the acceleration was great.
bicyclenut
bicyclenut
Number of posts : 141
Registration date : 2015-09-04
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeThu Aug 11, 2016 12:45 am
Before I put 26G sliders in mine I did research via the web and I determined the lower weight, the better and faster acceleration, especially off the line, but as you went lighter, the gas mileage suffered. It seemed that most found 26G or 24G to be the sweet spot, maybe 24G if acceleration was your main goal. With 26G I found better acceleration and lower highway RPM's as well as improvements in gas mileage over stock. Sorry, think I went over 25 words...
http://www.MarkNovackPhotography.com
Number of posts : 921
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeThu Aug 11, 2016 4:31 am
A lot of people have done comparison tests with the sliders. I have 26grm sliders in . The main benefit I find is in the acceleration. If you are overtaking someone and they start to accelerate, the sliders give you that extra push to get past safely. MPG is the same as with rollers, in my case 64mp (imperial)g.
mike712
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeThu Aug 11, 2016 6:58 pm
I just ordered a set of 24g. It seems they are in short supply.
19basketball89
Number of posts : 2
Registration date : 2016-08-24
PostSubject: Link   Dr Pulley Slider Question I_icon_minitimeSun Oct 16, 2016 3:01 am
Where did you find them? Can you post a link? I am in the US and am not having luck finding them.
mike712
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeSun Oct 16, 2016 10:08 am
I ordered them off of ebay. I can't remember the name of the seller. I just searched ebay for Dr Pulley sliders.
Number of posts : 693
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeMon Oct 17, 2016 10:20 am
I started with 26g sliders, but because I live at high elevation (>5,000 ft) I still wasn't getting enough umph to climb over the high mountain passes with authority, so I installed 22g sliders. The lighter ones allow the engine to immediately rev onto the power band upon acceleration which is what I wanted. I have been to the top of Pikes Peak and Mt Evans, both well over 14,000 feet as well as many other high passes. I still average in the low 50 mpg range, so for me this seems like a good fit.
Number of posts : 1013
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeMon Oct 17, 2016 11:09 pm
I installed 26 sliders to reduce the vibrations my 2002 Swing had when accelerating from a stop. I was not happy and went to the 24 sliders and was happy. Another benefit was acceleration. WOW! Moved the 24 to my new 2013 Swing. Love the acceleration.
Flyingpanman
Flyingpanman
Number of posts : 237
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeTue Oct 18, 2016 5:03 am
A few have mentioned 22g and 26g sliders. I found the list below on the Dr Pulley web site. You'll find they recommend 24 or 25g sliders.
Dr Pulley info
Davefirestorm
Davefirestorm
Number of posts : 94
Registration date : 2016-05-29
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeTue Oct 18, 2016 5:57 am
My Swing has done 16000 miles and considering Dr.P sliders instead of rollers plus new belt when winter arrives,can't decide which ones to use though
mike712
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeTue Oct 18, 2016 2:07 pm
HELP HELP HELP HELP
Not sure where to post this but I am trying to install sliders and I can't break loose the 14mm bolt holding on the variator. Any suggestions????????
Number of posts : 1037
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeTue Oct 18, 2016 3:51 pm
You need the acme pulley tool Mike, basically a lump of wood with three holes. You need it to hold the pulley to torque up the central nut anyway.
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeTue Oct 18, 2016 4:24 pm
That variator bolt is torqued to 77 lbs ft, but some nimrod mechanic may have torqued the bejesus out of it with an air ratchet. Hopefully the same klutz didn't also put Loctite on the bolt threads too. As already mentioned above, you'll need a variator holding tool to prevent the variator from turning while you remove and reinstall the bolt.
The preferred tool is Bruce Kohler's inexpensive metal spanner tool: https://drive.google.com/drive/mobile/folders/0B-lQ7Ifo_iuqZVhweE0zclBNYm8?usp=sharing
But the quick,,dirty & inexpensive tool is the legendary Leroy Beal's plywood variator holder: https://drive.google.com/drive/mobile/folders/0B-lQ7Ifo_iuqZVhweE0zclBNYm8?usp=sharing
DO NOT REINSTALL THE VARIATOR BOLT WITH AN AIR GUN. Use a torque wrench. See JeffR's belt installation Pictorial.
mike712
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeTue Oct 18, 2016 5:47 pm
I have a variator holder made to Bruce Kohler's specs.  It just bent under pressure.  Bolt didn't budge.....I tried using an air impact wrench and it still didn't budge.  Any other suggestions other than live with what it is until the belt has to be changed????????
PS.  The last nimrod mechanic was me.  I installed 26G Dr Pulley Sliders and used a torque wrench set at 77 FT Lbs to re-install the bolt.  Alos NO loctite......
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeTue Oct 18, 2016 6:37 pm
Umm scratch, heat the bolt head. Then let it cool somewhat before you attempt removing it. "Live with it" isn't going to resolve the problem.
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeTue Oct 18, 2016 6:43 pm
Get a stronger (thicker) main bar. Mine is made of 1\4 x 4" aluminum bar stock and works fine. Your impact wrench should have removed the nut. Maybe your gun is too small. I have both an air and a battery impact gun. For most jobs the battery one from Sears works fine. Nothing beats the air gun also from Sears. Always use the variator tool and a torque wrench to install the bolt. Good luck.
mike712
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeTue Oct 18, 2016 7:23 pm
GOT IT..........Installed Dr Pulley Sliders 24GR......WOW. Well worth the effort.  Big difference between 24GR & 26GR.  I have a set of 26GR sliders used for only 300 miles that I would be willing to sell.  Someone make me an offer.......
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeWed Oct 19, 2016 8:03 am
thumbs up
So what did you do to remove the bolt?
PM sent
Lazyfox
Number of posts : 24
Registration date : 2015-04-07
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeSun Oct 30, 2016 4:57 am
I also started with 26g sliders. Then I have trimmed them by using Dremel (and a scales) to 25g, which is better.
I think I will trim them further to 24.5 g this winter as there is still too much vibrations to my taste.
Other than that sliders are much better than OEM in any case.
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeSun Oct 30, 2016 8:41 am
Can you please explain how you lightened the 26 gm sliders with a Dremel. Photos if ossinle too.
Lazyfox
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeSun Oct 30, 2016 12:29 pm
Sorry, but I don't have any photos.
The most difficult part is to remove sliders from the bike Smile
Then you will need: a scale with 0.01g accuracy, a Dremel (or similar) rotary tool and a sanding band. Don't use the stone tool, it is more for polishing than sanding.
A slider is made of nylon which is quite light. The brass (I think) sleeve is necessary to achieve desired weight.
What is need to do is to remove some ( I stress some) material from inside of the brass sleeve. Do not stay in one place but move your sanding band around. You will need to be careful and check the actual weight every couple seconds of sanding as there is no return. Always before putting the slider on the scale remove the dust so you get accurate reading. Trimming one slider by one gram should not take longer than 5-10 minutes. And the last advice: weigh all your sliders before. This will tell if your scale is calibrated properly. Sliders tolerance is usually +-0.05 g.
Please do not hesitate to ask if my explanation is not clear enough.
BR
Andrew
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeSun Oct 30, 2016 3:39 pm
Thanks Andrew
So you dont need to remove the brass sleeve from the nylon slider then?  It's more of a case of honing out the i.d. of the brass weight. I wonder if chucking a cotter pin with a strip of coarse sand cloth in a Dewalt drill --or a brake cylinder hone will work?
I do understand the need to continually monitor your progress.
Lazyfox
PostSubject: Re: Dr Pulley Slider Question   Dr Pulley Slider Question I_icon_minitimeSun Oct 30, 2016 4:41 pm
Thanks Andrew
Correct, the slider stays intact. No need to remove the bras sleeve (if it's possible at all without damaging the slider).
The tool mounted on the Dremel in the link is that what I was using successfully.
You can see also a stone tool (orange colour) which did not make any impression on the sleeve/weight.
http://www.electro.pl/narzedzia-wielofunkcyjne/narzedzie-wielofunkcyjne-dremel-3000-15,id-636476
BR, Andrew
» Dr Pulley rollers
» Dr Pulley Slider Installation
» Dr. Pulley slider weights?
» dr. pulley slider weights.
» 24 vs 22g Slider weights?
