| New battery installed wrong | |
rmsdvm Scooter Rider
Number of posts : 3 Age : 75 Location : Arizona Points : 3196 Registration date : 2016-02-27
| Subject: New battery installed wrong Fri Aug 19, 2016 1:38 pm | |
| 2009 HSW 600.
OK; I hope you all are done laughing. In my very weak defense I'm old and don't see too well up close. The pole indicators being on the outside of the cover didn't help.
I tried to start it and (obviously) nothing. There was a clicking noise under the instrument panel that sounded wrong (duh!) so I unhooked the battery. Now it is in correct, but still nothing.
What have I probably done to the bike, to say nothing of my pride.
Thanks. |
| Subject: Re: New battery installed wrong Fri Aug 19, 2016 1:50 pm | |
| It would be courteous if first you went to the Introduction section and, ahem, introduced yourself to the forum.
You probably blew the 30amp main fuse.
| Subject: Re: New battery installed wrong Fri Aug 19, 2016 2:53 pm | |
| Subject: Re: New battery installed wrong Fri Aug 19, 2016 3:25 pm | |
| Sorry about the missing introduction. Thought I did that when I signed up a few months ago. Will do now. And thanks for the info on getting to the main fuse.
Bob Shull Prescott AZ |
| Subject: Re: New battery installed wrong Sat Aug 20, 2016 3:44 am | |
| 2 yrs ago I did the same mistake and blew the fuse in the coil.To see the fuse remove the coil dust cover. The fuse is there ( hard to see ) |
| Subject: Re: New battery installed wrong Sat Aug 20, 2016 8:02 am | |
| - tinman wrote:
- 2 yrs ago I did the same mistake and blew the fuse in the coil.To see the fuse remove the coil dust cover. The fuse is there ( hard to see )
Your post, though well intended, is misleading. As far as I am aware there is no "fuse in the coil". The coil is located on the right side beneath the floor step. There is no dust cover on the coil. Perhaps you are referring to the fuse near the starter solenoid or relays which are located on the left side as Dennis' photos & post (above) show. Using the correct terminology lessens the confusion. Tim |
steve_h80 Silver Wing Guru
| Subject: Re: New battery installed wrong Sat Aug 20, 2016 3:24 pm | |
| - rmsdvm wrote:
- 2009 HSW 600.
Thanks. Call yourself several rude names. Have a beer. Then check the fuses. And good luck :-) |
| Subject: Re: New battery installed wrong Sat Aug 20, 2016 3:26 pm | |
| Main fuse A under left side panel was burned. Replaced and I'm back up!.. Thanks to all. |
| Subject: Re: New battery installed wrong Sat Aug 20, 2016 6:30 pm | |
| Yes my mistake on the left side .sorry for the confusion. Thanks for the correction. |
