| aux location | |
+2Cosmic_Jumper EAGLEWINGS 10 6 posters |
EAGLEWINGS 10 Scooter Rider
Number of posts : 15 Location : South Jersey Points : 2959 Registration date : 2016-08-24
![aux location Empty](https://2img.net/i/empty.gif) | Subject: aux location Thu Sep 22, 2016 10:13 pm | |
![aux location Empty](https://2img.net/i/empty.gif) | Subject: Re: aux location Thu Sep 22, 2016 11:03 pm | |
| Nope. No power outlet in US models. However the is a blanked hole in the left cubby where you can add an outlet. Of course you'll also have to wire it up to the battery or a switched power source.
bicyclenut Maxi-Scooter Rider
![bicyclenut](https://2img.net/u/3413/63/00/33/avatars/4095-79.jpg)
Number of posts : 141 Age : 55 Location : Chicago Suburbs Points : 3491 Registration date : 2015-09-04
![aux location Empty](https://2img.net/i/empty.gif) | Subject: Re: aux location Thu Sep 22, 2016 11:11 pm | |
![aux location Empty](https://2img.net/i/empty.gif) | Subject: Re: aux location Fri Sep 23, 2016 8:42 am | |
![aux location Empty](https://2img.net/i/empty.gif) | Subject: Re: aux location Fri Sep 23, 2016 12:54 pm | |
| Thought I'd jump in here. When a bought this used Swing and got it home, I installed three DC outlets. One in the provided mounting hole in the left glove box. One water proof unit under the mounted leather center glove box. One more water proof, short body, non-switched, Honda unit on the left wall just above the battery compartment under the seat. This arrangement works for me. This was the tricky install because of all the relays in this location and the amount of room for the length factor of the unit. I needed to take the left rear cover off to make the judgment call of this location. |
![aux location Empty](https://2img.net/i/empty.gif) | Subject: Re: aux location Fri Sep 23, 2016 3:12 pm | |
| - DennisB wrote:
- Thought I'd jump in here. When a bought this used Swing and got it home, I installed three DC outlets.
One more water proof, short body, non-switched, Honda unit on the left wall just above the battery compartment under the seat. This arrangement works for me. This was the tricky install because of all the relays in this location and the amount of room for the length factor of the unit. I needed to take the left rear cover off to make the judgment call of this location. Dennis, what/where " leather center glove box."? |
![aux location Empty](https://2img.net/i/empty.gif) | Subject: Re: aux location Fri Sep 23, 2016 4:11 pm | |
![aux location Empty](https://2img.net/i/empty.gif) | Subject: Re: aux location Sat Sep 24, 2016 5:55 am | |
| Thanks Dennis for the info. |
| aux location | |
